Question about Dryers
Pump will just keep running after cycle is done and we cannot shut it off unless we turn breaker in our electrical panel off
    Top Expert:
  • Dryers Master
  • 44,232 Answers
Call a serviceman it sounds like a combo unit if the dryer has water in it
Posted on Apr 09, 2015
2 Suggested Answers
docjohn174
  • 943 Answers
SOURCE: DBXR453ET3WW Electric Dryer Won't shut off unless on timed cycle.
hi thanks for the question in the ge dryer theres 2 elements so if one is not working you only get half heat i would check the heater thanks the appliance doc
Posted on Sep 27, 2008
How do I fix my cycling dryer.
so you have not done any work on the electrical system at all changed anything or anything like that do you have a model number Appliance 911 Sea Breeze
Nov 15, 2015 | Maytag Dryers
Pool filter pump won't shut off.
I'm assuming it continues to run when you switch the system to "service" mode. You probably have a relay stuck shut. Unless you are very comfortable with working with high voltage it's best to get a tech out to verify the problem and switch out the relay. If you are okay with it the replacement isn't very difficult. You'll have 4 or 6 wires to move from the old relay to the new one, and switch out the small black and red paired wires that go from the relay to the control board. Make certain that your breaker is off while changing it out.
Apr 12, 2013 | Water Pik Aqualink Rs4 Package - Pool and...
Hi,I have a travel trailer 37ft. Problem with my ac, the fan starts good but my compressor does not kick on. My next door neighbour says it's the compressor that is done. Could you help me?
see this causes and fix it. God bless you
Motor Trouble Cause Diagnostic Procedure Repair Procedure Electrical Power is Off Check that all service switches for the equipment are in the "on" position.
Check for voltage at the pump motor or pump controls. If no voltage is found, check for voltage at the electric panel.
If power is on to the building, check fuse or circuit breaker serving the electric motor that won't run.
Check for local reset button on the motor (popped out = off )
Check for other power reset or power off buttons such as an access door compartment safety switch that turns off power to the equipment (found on A/C blower compartment doors)
Turn on "off" switches.
Replace bad fuse. Reset circuit breaker; if necessary replace bad circuit breaker.
Let hot electric motor cool down, then push in its reset button.
Be sure all safety interlock switches such as on compartment doors are depressed and that the doors are securely shut. Replace a bad safety switch.
See
ELECTRICAL POWER SWITCH FOR HEAT
FAN AUTO ON Thermostat Switch
WATER PUMP ELECTRICAL SWITCHES
CIRCUIT BREAKER FAILURE
ELECTRIC PANEL INSPECTION
Blown fuse, tripped breaker Replace fuse or breaker - does the pump run and keep running normally? Be sure proper breaker or fuse size in ampacity is installed - ELECTRIC PANEL INSPECTION Low voltage to the motor Check with VOM at the pressure control switch or at the motor wiring Be sure the proper size of wire is used for the ampacity and length of circuit; Test for low voltage to the building. Loose, improper, or broken motor wire Check wiring against the motor installation manual diagram, check all connections for tightness, shorts, burns, damage Rewire or repair or replace wWhen a sealed compressor motor has "burned out" this means that the internal wiring of the motor has become irreparably damaged: the compressor motor windings may be burned and shorted together or shorted to the steel shell of the motor, or the windings may have burned and simply become "open" or disconnected. If the motor has burned out in either of these ways it needs to be replaced.
Oct 08, 2012 | Dometic Rooftop RV Air Conditioner
Swimming pool pump problems
motor overheating replace pump if new install check wiring
Sep 15, 2012 | Pentair Pool & Spa
100 amp service. 2 breakers connected together 50 amp each. power was shut off. Had to shut off main before ir was turned back on. when power was restored, breaker would not stay on unless it was done real...
this you would need a meter to tell were the problem is you need to put the meter one on the netrual and one on the main to get a reading then keep doing this for all your breakers , one way to tell if a breaker is bad take it off the main panal put the meter to the screw and copper and see if your getting connuty to it good luck
Jul 29, 2011 | Your One Source 100 Amp Main Breaker
Why does my 100 amp main get so hot the black wire is starting to melt, should'nt the breaker trip if there is that much draw?
You need an electrician before there is a fire.
If the breaker is not tripping, then the breaker is bad.
Act now before the heat damages the box and you need full replacement.
Absolutely put the metal cover back over the breaker box and keep the door closed.
Move all flammables away fro breaker box area.
Put a smoke detector right there.
Put a fire extinguisher nearby.
You don't put water on an electrical fire.
Before the electrician gets there, turn off as many electrical devices as you can.
Don't run all at one time.
Run just when needed.
Electric water heater.
Space heaters.
Vent fans.
Electric Stove.
Electric Oven.
Microwave.
Heat AC.
Electric Dryer.
Washing machine.
Power tools.
Big screen TV.
The outdoor lights, and swimming pool pump.
Turn off as many indoor lights as possible.
Now the freezers and refrigerator have to stay on.
Clean out the grilles so they run more efficiently.
Reducing your power consumption will be good practice.
When you call the electrician, tell him the brand and amperage of your main breaker.
If the whole box needs replacement, you might want to upgrade the service to 150Amp.
Some areas, it's code that old panels have to be upgraded to more amperage ... but the electrician will know the details. Call local electric supply house to double-check what the electrician tells you.
Nov 08, 2010 | General Electric 100Amp 3-pole circuit...
Have Challenger Type C 2100 circuit breaker in residential home electrical panel. Manually turned to off position and now cannot turn back on. Pops back to off position. Also says HACR type and common trip...
First HACR is heating, air conditioning,refrigeration. So in other words you could use it on an electric furnace or air conditioning.
IS this the main breaker for the panel? or for and electric furnace. I'm assuming its for the furnace, perhaps back up heat for heat pump. See if there is another disconenct on the furnace, turn it off and see if the breaker resets. IF so you have a short or overload in the furnace.
If' it IS the main for the panel, turn off all the other breakers in the panel, and try to reset the breaker. If that works, turn the other breakers back on one at a time. IF it "POPS" then it is tripping. Don't keep resetting, find the problem.
Jul 19, 2010 | Challenger Connecticut Electric UBITB-A230...
Replace 200 amp breaker
If this is the Service Disconnect Switch or Main Switch for the panel, this job should probably left for an electrician to perform, as power should be shut off at the meter socket or at the roadside first. If this is not done, the work will be "hot".
Unlike most circuit breakers in electrical panels, Service Disconnect Switches and Main Switches have the power brought to the panel by entering terminal screws. Shutting the Main or Service Disconnect breaker off prevents the flow of current *into* the panel and other circuit breakers. The large wires that are connected to the terminal screws are LIVE, and will remain so until shut off *upstream*.
Working in a panel with two large diameter cables that do not move easily is a hazard and should not be done unless you are very familiar with this work - and of course, have shut the power off.
Please, reconsider doing this work yourself.
Sep 29, 2009 | Computers & Internet
Dryers Logo
52 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
