Question about Garden
Strimmer will not switch off
When switched on at the mains the strimmer starts
    Top Expert:
  • Garden Master
  • 51,191 Answers
???????? MAINS STRIMMER ?????? come on make sense on the questions
Posted on Apr 09, 2015
Ryobi Li-ion strimmer
check that you are using the correct line in the head
if it is too thick , the load will be causing the thermo switch for the motor to stop operation until it cools down
Jun 16, 2017 | Ryobi Drills
How to replace the switch on a flymo grass strimmer.
Hi Johnstone
Before replacing the power switch, try some other approach or you have need to analyze first. I have a question for you, Is your strimmer a cord less unit ? or with ac cord? If its cordless unit so its a battery operated, if so, try to check the battery. But if its with cord or ac cord, try to check the continuity of ac cord by using multimeter or ohm meter,
Jun 04, 2015 | Cars & Trucks
Door open but door is closed
Sounds like child lock us activatedTurn off power at socket wait ten seconds then hold the start button for five seconds whilst switching back on at socket.you should hear a click to indicate child lock off.
Jan 18, 2015 | Washing Machines
Starting up Ryobi Petrol Strimmer
full choke on , push petrol bubble 5 times then pull starter cord., with luck it will kick in to life after a 20/30 secs put on half choke , run again for 30 secs the no ckoke.
The main problem with Ryobi products is that they flood very very easly. So the more time you try and pump petrol into the carb the more it will flood . If that happenes then choke off and switch off and then just pull starter cord for about 30 secs then switch on and it could start if not prime it again as above good luck
Dec 24, 2011 | Ryobi Garden
Petrol strimmer,, spark at plug,, petrol & 2
I have a flymo 430 petrol strimmer and cannot start it. ive cleaned the filter, put in new plug it went first time and then stopped and wont start again the plug seems to get wet all the time any ideas
Jul 03, 2011 | McCulloch Heavy Machinery
Can't start the strimmer. It is a petrol strimmer, Partner Colibri. Is there a technique other than pulling the cord? Does it need more than just petrol? would be pleased if you could help. Regards...
Start procedure, switch the ignition switch on, press the primer bulb as many times as it takes to 3/4 fill the bulb, put the choke to the full position,hold the throttle trigger open, crank the engine until it fires once, move the choke to the centre position, crank the engine until it fires up and runs, once warm move the choke to the open position.
Jun 11, 2011 | Garden
My strimmer wont start
Well i am hoping you have checked the spark plug, HT cable, clean fuel mix, air filter, and on/off switch make sure switch is free from water and rust. Does the trimmer turn over if not the piston may have sized up. If it has then sorry time to buy a new machine
Jul 13, 2010 | Ryobi Garden
My Makita Petrol Strimmer won't start
If it is a gas (petrol) trimmer...then most often it is in the on/off switch on the handle. Before you go tearing anything apart...rock the on/off switch a few times to see if it helps. www.nnyparts.com
Jun 01, 2010 | Black & Decker String Trimmer Cordless 12"...
I have changed the plug, what elso shoiuld I do? the strimmer is about to years old and there is no local agent.
Are you certain that you have no spark?
If so then you can disconnect the slip connector from the kill switch to see if it will start... if it does start then the problem was obviously a bad switch if it does not start then the problem is deeper possible coil or ignition module related.
Aug 20, 2009 | Ryobi Garden
Garden Logo
63 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
