How do you pull the filter out after turning it.
    Top Expert:
  • Washing Mach... Master
  • 50,411 Answers
Sorry but without a make and model we can not assist
Posted on Apr 09, 2015
How do i release the water filter so i can twist to the left to remove it?
Usually the filter is attached to the cap just turn it to the left and pull the filter out with the cap. Be sure the water to the machine is turned off before pulling it out.
Dec 26, 2015 | Refrigerators
I have a Whirpool sxs model GS5SHAXNL01. I can't get the water filter our. The handle turns slightly, not enough to pull the filter out. What do you suggest that I do to remove the filter and
Hi my name is Chris
If your water filter is hiding inside a tilt down cover, just pull the filter out with the tilt down cover all the way down. No turning required :-)
Jan 04, 2015 | Whirpool Refrigerators
How to remove water filter do i have to rotate it or just pull it out
Open the door, this shuts off the water supply to the filter reach in and turn the filter counter clockwise a 1/4 to 1/2 turn and pull the filter down. Replace filter the same way, close the fridge door and away you go! Takes about thirty seconds to complete.
Oct 14, 2012 | KitchenAid Superba KSRG25FK Side by Side...
I have been unable to remove the wter filter. I have tried to turn it 1/4 of an inch clockwise as described in the owners manual but the filter won't budge. any suggestions?
OK maybe try 1/4 inch counterclockwise and pull down. Here is what the service manual quotes.
That is easy for anyone to misread.
Water Filter Removal
The water filter is located in the upper right-hand
corner of the refrigerator. The water filter filters water
for the ice maker and the water dispenser.
1. Turn the water filter 1/2 turn counterclockwise and
pull it down.
2. To install the filter, align the indication mark
(unlock position) and push it up while turning 1/2
turn clockwise until the lock position is aligned.
Do not over tighten.
That would be to the left while facing the filter and opposite for installation. Note where and when to push up. Please let me know if you have any questions and please rate if I am able to help you, Thanks, Sea Breeze
May 08, 2011 | Samsung RS2556 Side by Side Refrigerator
I can't get the water filter out of my Whirlpool gold side by side. Help
The water filter should be at the bottom of the refrigerator. You don't even have to open the doors.
You will either have a push button filter or a twist filter. I will walk you through the twist filter first.
At the bottom of the front of the frig, you will see a turn handle. This is the filter. What you need to do is turn the handle a quarter turn (90 degrees) counter clockwise. This will release the filter. Simply pull it out. the handle will slide off the front (this is what you were using to turn the filter). You must keep this and put it on the new filter in the same fashion.
The push button filter is in the same spot, only instead of turning it you push the button and it should pop out. Pull it out and save the cap! The cap goes on the new filter you install.
If you have located the filter but are having actual difficulties removing it because it is stuck, the only advice i have is be careful not to hurt your fingers! Applying slow pressure in a pulling fashion will generally relieve it. If I can be of further assistance let me know!
These filter generally cost between $35 and $40 at your local retailer.
May 29, 2010 | Whirlpool Refrigerators
I can't pull out the filter
Make sure the filter is turned all the way to the unlock position, then get some pliers and grab the turning bar, and pull.
Make sure there is nothing in front of the filter that you have not removed yet.
Jan 29, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Cannot remove water filter from LG 26 cu ft side-by-side in the d
Here's the only thing that worked for me in getting the water filter out of my LG refrigerator after trying for three weeks, pulling hard by hand, using high-grip gloves, and trying an oil filter wrench. You have to break or lessen the suction created by the water in the filter. Do this by first turning the filter to the Removal position (in my case, a quarter-turn to the left). Then grip the filter tight and rock it back and forth slowly as far toward the back and front of the refrigerator as possible, while keeping a bit of downward pressure on the filter. This lets the two O-Rings "walk" their way down the insert tube. After only a few pushes and pulls - voila! -- it lets go and will drop right out.
Nov 24, 2008 | LG 26.0 Cu. Ft. Side-by-Side Refrigerator...
Change the water filter
Most are ok to pull as there is a shutoff in combination with feed lines... If in doubt and the water shutoff is convienient to get to turn it off. Otherwise just pull the filter...especially if it simply snaps into place as it should take care of turning off the water as the filter comes out....
Feb 15, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Cant remove water filter
jgray11111,
I am guessing you know to turn the filter fully counterclockwise, to remove it.
My first suggestion would be to turn the filter fully counterclockwise until the dead stop, then while holding the filter with one hand you would push and release quickly the water dispenser lever. The pressure should pop the filter out of its socket.
My second suggestion is turn filter counterclockwise to dead stop, then take a very hot towel (protect your hands and to not touch towel to any glass shelves) and wrap it around the filter. This method will hopefully warm the water in the filter causing the water to expand and help push the filter out of its socket.
My third suggestion would be more extreme. Turn the water supply off. Turn filter counterclockwise to dead stop, then drill a hole in the side of the filter to allow air into the filter to release any vacuum in the filter allowing you to pull it out of the socket.
If none of these work then the filter socket probably will have to be disconnected so you can get it out of the compartment and get a better grip on all.
I have never had to go that far myself.
I hope I have helped you and please don't forget to rate me.
supertechks
Jan 23, 2008 | Maytag MFD2561HE Stainless Steel Bottom...
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
