Question about Water Water Heaters
Hi my vulcan gas hot water service isn't getting hot enough anymore? please help me?
  • 700 Answers
Check first if you have good water flow to and from heater. lift pressure release valve on inlet and allow few sec to flow, same with outlet hot water safety valve.
remove front cover from the heater, you should see your gas connection and thermostat knob.
check if gas is burning evenly and on whole surface, check for leaks on the heater and on the lines to and from the heater.
if you did not find any faults, no leaks, safety valves work correctly, check thermostats settings,
wind it down to minimal, then turn it to about 1/4 value (you did not specify model but this should do, widening arrow or numerical values ar self explanatory), lift hot water safety valve for few seconds, then open any hot water tap (faucet if you are an american...) and check if gas ignites and burns.
set thermostat to about 2/3 value and again, lift hot water safety valve for few seconds, then open any hot water tap. check if gas ignites and if water is sufficiently hot, if too hot - wind it down to say 1/2 way, if too cold, wind it till resistant and then back off a bit, DO NOT EVER LEAVE VALVE OR THERMOSTAT ON MAX!.
if none of these help - you need either, change the thermostat or heater itself.
if works - you solved the problem, close the tap, close the cover and use the system as you normally do.
i am always recommending use of insulation on the hot water system, it saves heaps of money over the life of the system.
hope this will help you - do not forget to vote... :-)
Posted on Apr 09, 2015
How to install a vulcan gas hot water system 260 model
This is a job for a plumber - especially where gas connection is involved.
Jul 31, 2016 | Water Water Heaters
To hook up gas, to an Vulcan 260 freeloader
best left to a pro . gas leaks cuase explosions when we certainly don't want one
Jan 21, 2015 | Water Water Heaters
I cant get heating but no hot water
Electric or gas? You can't get water out of the faucet at all or it just isn't hot? I just need more information to answer the question.
Jan 27, 2012 | Water Heaters
I just had a noritz tankless hot water heater converted from LP gas to natural gas, and had the hot water heater moved outside my garage. Before the gas change over and the move, I could turn on my garage...
One thing that comes to mind right off is did they use proper size orifices when they converted? L.P. uses a much smaller size then natural gas because it runs at a much higher pressure. Just a thought but I had a water heater from the factory for a mobile home that had the nat. gas sticker on gas valve and I hooked it up in town to nat. gas supply. Unfortunately it had L.P. orifices and I was in a hurry to get to another job ,lit it turned burner on and left. Two hours later my customer called to say they didn't have enough hot water. Didn't take long to discover what the problem was and correct it. Thank god for good customers. Hope this helps you. Thanks
Nov 24, 2010 | Bosch Indoor Gas Tankless Water Heater...
My Mum has a Vulcan freeloader 260 gas hot water system and it appears that the pilot light has gone out. The only problem is I can't find where it is to test how to turn it back on. Can someone please...
Remove the access panel lower right hand side and locate the pilot light re-igintion push button. The instructions are pritnted on the back of the access panel.
May 18, 2010 | Water Heaters
When we turn the hot water on, the water is warm but does not heat up anymore than that. We are not getting any "Hot" water, but if it was the pilot not lighting the water would be cold and its not.
there should be a dial of some kind on the front of the water heater that controls the water temperature turning it up a notch or two beyond its current setting should make the water temp hotter
Nov 29, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Running out of hot water with Vulcan Freeloader 300
hi i need help with mi Vulcan 300 hot water main gas pressure...
our kitchen tap got broken and we turn off our main water pressure in front off our house and now our hot water gas not working ....please help
thank you ...
Sep 24, 2009 | Water Heaters
Water too hot on a Vulcon Freeloader Super 10
Remove the cover and there should be a temp setting
Jan 31, 2009 | Water Heaters
Water Heaters Logo
108 people viewed this question
Top Water Heaters Experts
freddyfox
Kenneth Walker
Are you a Water Heater Expert? Answer questions, earn points and help others
