Question about Tecumseh Garden
Hi I need a schematic of the carburetor of a Tecumseh BVS 143. Thanks
I was retired the carburator and not know how to reinstall it. I need a picture or schematic view about this carborator and the control bracket. Thank you
    Top Expert:
  • 1,144 Answers
Posted on Apr 09, 2015
  • 3,960 Answers
Here is the link to the service manual:
http://nerecfarm.com/docs/t/tecumseh-bvs-143-service-manual.pdf
Tecumseh engine model tvt691-600811a---i need a diagram of the carburators numbers on carburators are 5172DOB
You may already know that Tecumseh ceased business about 2008. It seems Barrett Small Engine has some of the literature on Tecumseh engines & parts. Try this link: http://www.barrettsmallengine.com/tecumseh/parts.html
Hope this helps,
bxn545@gmail.com
Oct 08, 2015 | Tecumseh Garden
Tecumseh model#OHH60-7193d. Need a carburator
These are readily available on Ebay for less than $20.00.
http://www.ebay.com/itm/TECUMSEH-CARBURETOR-640025A-640014-640004-640025B-640025C-OHH55-OHH60-I-GCA68-/221505055854?pt=LH_DefaultDomain_0&hash=item3392baec6e
TECUMSEH CARBURETOR 640025A 640014 640004 640025B 640025C OHH55 OHH60 GCA68
May 29, 2015 | Tecumseh Garden
Mower starts and runs for 10 - 15 seconds, then dies. Will almost start again, but soon will not even kick over. After a while, it will start for a few seconds. This is a 15 horse Tecumseh that looks...
It sounds like a carburetor issue. The jets are probably gummed up from the old gas that was in it. Remove the carburetor and clean it out with a can of carb cleaner. Then reinstall.
May 22, 2011 | Tecumseh Enduro Vertical Engine 16 HP 1in...
Have a Troy-Bilt Chipper/Vac model # 47282 5hp sp, the Carburator needs to be replaced, I cannot find a part # for it, or where one can be purchased, please help
I believe the carburetor part number for your model is 632631. I have the same TroyBilt chipper/Vac. It has a Tecumseh H50-65582W engine. A good parts diagram can be found at
http://www.outdoordistributors.com/pdf/Tecumseh/TECUMSEH-MODEL-H50-65582W-PARTS-LIST.pdf
If this is the right part, you can buy it at Jacks Small Engine parts for $79
Good Luck!
Dec 12, 2010 | Troy-Bilt Chipper Shredder
Looking for carburetor assembly drawing thanks Tecumseh 4hp TVS105 53048D SER. 4159B
I didn't find a schematic, but here is a site that may be able to help you:
www.lawnmowerpros.com/Tecumseh/tecumseh-Carburetor-Kits.asp
Contact the number at the upper right of the page if you can't find a schematic close to yours. They may send you one for free if they have it.
Good Luck!
Jim
Oct 10, 2010 | Mtd 22" Yard Machine Push Mower
I have a Tecumseh 12.5 hp vertical ohv engine Model OV358EA (OHV110-135) The rocker has come loose, pushrod jumped out and stopped engine. I need to reset valve clearances, I have no manual to give me...
My 13.5hp ov358ea is .004 both valves. Would like to know model of your engine. I want to replace the non-adjustable carburetor of my 13.5hp ov358ea with an adjustable carburetor.
Retired Airline Mechanic
Jun 26, 2010 | Mtd LAWN MOWER PART # 683-04163B FRAME...
6 HP Tecumseh Engine won't stay running
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
May 09, 2010 | Garden
Tecumseh Carburator Adjustments settings
Usually a Tecumseh with these symptoms has a clogged jet somewhere. If you dismantle the carburetor and clean out all of these tiny holes with a wire or something and spray it off with carburetor cleaner and reassemble it, it should work. Turn the adjustment screws in just until they touch the seats counting the turns and reassemble it with them the same number of turns off of the seats. Also, put fresh gas in it if you haven't. Gas being left in them is the main cause of this. If you put Sta-Bil in the gas before putting it away or run it out of gas it should prevent this from happening in the future.
Mar 06, 2010 | Impact 1/2" Cordless Wrench Nikota...
Looking for a carburetor for a yard machines mtd
You may have better luck in identifying the engine type and manufacture (Briggs & Stratton, Tecumseh, etc) and get the number of the engine vs the machine itself, if possible. If you are able to do this, you can search ebay or the net for a wider range of possibilities for a purchase.
Feb 19, 2010 | Measuring Tools & Sensors
Garden Logo
220 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
Jim Parker
Jim Parker
lnbn1975
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
