Question about Apex Digital PF3230 32" TV
Tv shuts off every 4-5 minutes. - Apex Digital PF3230 32" TV
    Top Expert:
  • Apex Digital Master
  • 74,377 Answers
Make sure that the timer is set to any pre-set time. If it is not set, the fault should be with its main power regulator section circuit. Contact any service technician. http://electronicshelponline.blogspot.com/
Posted on Apr 09, 2015
Shuts down after 5 minutes blinks green
Once the set shuts down, wait for the unit to stop blinking. Once it stops hold in the input and menu buttons for 5 seconds. The TV will then give you an error code. A 6-1 or a 1-8 error code would indicate a bad Color wheel. Which I think is the problem you have.
Jun 19, 2012 | Mitsubishi WD-65735 Television
I have a Samsung HL-R5678W DLP TV that is acting up. When I first turn it on everything works, after 5 minutes it shuts itself off. After 2 minutes it will come back on without sound. It will do this a...
U turn tv on hear any squiling,grinding or motor noises?Picture show up before it shut down picture have flashes of black&white within the picture?Yes,to all of these,this tv have a colors wheel and it dead,require the colors wheel replacing.No,none of these problems.The tv projection lamp,if in this tv like a 1 1/2 or 2 years,tv ben on an watches like 4 or 5 hours a day?The "LAMP" LED light indication lite up or flahes,the projection lamp life is over.Require a new projection lamp.
Oct 22, 2010 | Samsung DLP HL-P5663W 56" TV
Mitsubishi 65" LCD (1080P, DLP) keeps shutting down until it "warms up". After shutting down the power led flashes yellow for a minute or so, at which time I power it up again. This cycle repeats 1 to 4...
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV may require service.
Jul 27, 2010 | Mitsubishi LT-40133 40 in. LCD HDTV
My Magnavox digital converter box shuts itself off every 5 minute
Check that you have not got an auto power off setting on. Check that the aerial connections are good. That the signal is strong from the stations it is picking up. Weak signals can cause the box to shut down.
It the box is very hot when it shuts down, you might have a fault on it.
Apr 04, 2017 | Philips Magnavox M61117 (DBM61117)
TV does not turn on. Stand By LED blinks 4 times and pauses and blinks 4 times again Tv will not turn on...when plugged in the red stand by light flashes 4 times...you can hear the tv turn on but a black...
On older Sony, sometimes a power surge causes the set to be in shut down mode. Try unplugging for 5 minutes and then plug in and try. This many times will fix.
May 31, 2009 | Sony KV-27S42 27" TV
Shuts off after 20min
found cold connection on board at tuner
Feb 14, 2008 | Televison & Video
T V Shuts off by itself, after a couple of minutes.
here is some tips for ur TV which blinks 4 time.
1 Probable
Cause
Location
Solution • +13V is not supplied.
(A Board)
• IC503 voltage list is faulty.
(A Board)
Detected
Symptoms
• Has entered standby state
Solution after horizontal raster.
•Vertical deflection pulse is
stopped.
•Power line is shorted or power
supply is stopped.
this info must remady ur problem.
Dec 03, 2007 | Sony KV-36XBR400 36" TV
Apex Digital PF3230 32" TV Logo
42 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
