Question about Lands Phones
I do not see where telephone jack is plugged in, can you help.
    Top Expert:
  • 10,875 Answers
"like the other 98.5%,you give no info,
make,model or year and the problem in
detail,if you want a correct answer
,you should include that"
Posted on Apr 09, 2015
How do I connect the Norstar M7324 telephone to an expansion set?
Your expansion box is a CAP (central answer position) module. I will assume you are using the same jack as before. The line cord, from phone to jack should be 6 conductor (count pins on end). A short line cord runs from back of phone to back of CAP (plugs on CAP are labelled) then the longer cord runs from CAP to the wall jack.
Sep 12, 2014 | NorStar M7324 Telephone
I have an HP 2510 printer. I cannot use it to fax because once I plug the phone jack into the printer I get a busy signal. If I plug the jack into a phone, it works fine. How do I get the printer to...
Hi irwinbadin,
HP fax products are designed so that other telephone equipment can be connected on the same line as the fax. The unit must be connected first using a two-conductor fax/phone cable like the one that shipped with the HP product. Using a four-conductor telephone cable may cause problems receiving faxes or calls.
There are two different types of phone cables. There are two-conductor phone cables like what originally shipped with the HP fax product and there are four-conductor cables. HP fax products are designed to work with a two-conductor phone cable. Look at the end of the cable and verify that it has only two copper leads or wires. Replace any four-conductor cables with a two-conductor cable. Only two-conductor phone cables should be used to connect the all-in-one to the phone line.
Figure 1: The difference between a two-conductor phone cable and a four-conductor phone cable
Step one: Connect the phone line to the fax
The fax will have two or three sockets (or jacks) for phone lines. Some of these may have a removable plastic plug in them. These sockets will be labeled with text, To Wall Jack , or with a graphic of the wall jack. See Figure 1 below.
Plug the two-conductor telephone cable that came with the HP product into the telephone wall jack. Then, plug it into this socket as shown below.
In areas with above ground telephone lines and electrical storms (lightning), it is a good idea to purchase a telephone line surge suppressor and connect it between the telephone wall jack and the fax. This will help prevent damage to the fax from a lightning-caused power surge on the phone line.
Step two: Add other phone-line devices
To connect other telephone devices, use the other socket (or sockets) on the fax. These are identified by text or with a graphic of a telephone and/or computer.
Connect a caller ID unit between the fax and the telephone.
Use the information below that matches the devices you need to connect.
Fax and telephone
Connect a single-line telephone to one of the added sockets on the fax. The telephone will share the same phone line as the fax. See the illustration below.
Fax, answering machine, and telephone
When a telephone answering machine and telephone are connected, connect the answering machine to the fax and then connect the telephone to the answering machine as shown below.
Fax and computer modem
To use a fax and a computer modem on the same phone line, connect the fax to the computer modem. The modem socket on the computer may be labeled Line or Wall jack .
Fax, computer modem, and telephone
To use a computer modem and a telephone with the fax, connect the computer modem to the fax. Then, connect the telephone into the second phone line connector on the computer modem or the third fax socket (if it is available). The image below shows how to connect a computer and a telephone to a fax with two sockets.
Fax, modem, answering machine, and telephone
The image below shows how to connect a computer modem, answering machine, and telephone to a fax. Connect the computer modem to the fax, then connect the answering machine to the computer, and finally, connect the telephone to the answering machine.
If the fax has three phone line sockets instead of two, some of the devices can be connected to the other phone socket on the fax.
Hope it helps.
Thank you for using FixYa.
Jun 27, 2011 | Office Equipment & Supplies
I am trying to hook up my digital answering system with a multi line phone. I need step by step what I need to do. Thanks Ivy Hutchison
The answering machine would plug into the telephone jack on the wall, and the telephone would plug into the jack on the rear of the answering machine.
Now you do mention that the telephones are multi-line units. This could complicate things a bit because the 1739 is a single line answering machine.
If the telephone does not have individual jacks for each line (a jack for line 1 and another jack for line 2) you would need to purchase an adapter (maybe 2 of them...depending on the wall jack) that takes a 2 telephone lines and splits them into 2 individual jacks.
For example:
http://www.tti.net/computer-telephony/phone-accessories.html
After the lines have been broken out, you can connect the answering machine to the line that needs it. You would then either plug the lines into their respective jacks on the wall, or use a 2nd splitter to combine the 2 lines back at the wall jack.
May 23, 2011 | AT&T ATT1739 Digital Answering Machine
Cannot connect to my Internet. On my 2Wire modem at home, The Power LED light is solid green, the Ethernet LED light is green, the DSL LED light is continually flashing, and there is NO Internet LED...
With the DSL light always flashing, it means that either the ADSL signal (synchronization) does not reach your modem, or your modem cannot 'read' the signal.
You need to determine if the problem is from one of the following places :
  • outside of your house (your land line or ISP equipment) or from the modem;
  • your telephone-cable inside your house or
  • one of your equipment;
Try the following manipulations to determine from where the default comes :
  1. Determine if the problem is in your house or on the land line
    • Unplug each and every equipment which is connected to your telephonic installation (Fax, phones, answering machines etc);
    • Using the shortest telephone cable (RJ11) you possess, plug only your modem to the main telephone jack of your house.
    • If the DSL LED still flashes continuously, the problem is somewhere between your ISP's equipment and your house. You should call them and expose the situation. At this stage, you can't do much else.
  2. Determine if the problem is in your house installation
    If the DSL LED lights up when it is plugged to the main telephone jack, then it is either one of your equipment which is at fault, or the house installation. To pinpoint the problem, do the following :
    • With all the other equipment still unplugged, try the modem on all the other telephone jacks you have around the house.
    • If the DSL flashes continuously on one of the jacks, you will have found the source of your miseries. Depending on your ISP's terms and conditions, you will either have to call them of call for the services of a third-party technician to solve the problem.
    • If the DSL lights up correctly on all the telephone jacks, then your house telephone installation is good. Proceed to the next series of tests.
  3. Determine which equipment is at fault
    • Plus your modem to one telephone jack and wait for the DSL line to light solid.
    • Use a splitter (ADSL filter) to plug the equipments you possess (telephone, fax etc) one by one. Verify each time if the DSL LED is still lit or flashes continuously.
    • If one of the equipment causes the DSL LED to flash, it is that equipment which causes your problem.
    • If every equipment causes the DSL LED to flash, the it is the splitter (ADSL filter) which is causing the problem. You can confirm this hypothesis by testing each and every ADSL filter you have in your possession.
    • Replace any faulty equipment and you should have eliminated the problem.
If nothing of this solves your problem, you won't have any choice but call you ISP. Don't hesitate to tell them all tests you will have done.
May I also make some recommendations :
  1. Use a power surge protector (not a UPS though) to plug your modem to the electric outlet BUT plug it directly to the telephone jack;
  2. Make sure your modem is plugged in as far as possible from UPS, television, etc.;
  3. If possible, don't plug the modem in the same electric outlet as other equipments;
  4. Don't use any telephone extension cable to plug your modem to the telephone jack.
Hope this helps you. Let me know what happens next.
May 11, 2011 | 2wire (1000-000057-000) Modem
I am trying to use a plantronics headset system and cannot get a dial tone. Is this Norstar phone compatible?
You don't say what headset it is, but I will to help you.
If this is a Plantronics corded "H" series headset you will need to use an A10 adapter cord, which plugs into the headset jack on the phone.
If this is what you are using and you don't hear anything then you need to probably need to switch to an M22 amplifier box, which is then plugged into the jack where the telephone handset was plugged in.
If you are using a wireless headset it plugs into the handset jack where the handset cord was plugged into.
Good luck from Headsets Direct!
Mar 03, 2011 | NorStar M7324 Telephone
Hooking up cables and phone line to use the Fax on the P3150
Find a telephone wall-jack.
Buy a 1-to-2 telephone-splitter -- one end plugs into the wall-jack, and the other end provides 2 telephone-jacks.
Connect your telephone to one of those 2 jacks.
Connect your All-In-One to the other of those 2 jacks.
Be sure to use a 4-wire telephone-cable, not an 8-wire network-cable.
Feb 03, 2010 | Lexmark P3150 All-In-One InkJet Printer
No dial tone when connected to phone jack. Machine is plugged into power source and phone jack but doesn't work.
phone jacks are used for extension telephones. the line from telephone companies must be connected to tel jack......
Mar 19, 2009 | Panasonic Office Equipment & Supplies
Unable to use Fax machine with cable company telephone.
You don't have the cable plugged into the "telephone" jack instead of the "line" jack on the machine do you?
Mar 13, 2009 | HP OfficeJet 6110 All-In-One InkJet...
How to connect the answering machine to my telephone
You should have two jacks on your answering machine. One should be marked "Line". Plug the telephone cord from your wall into this one. The other jack should be marked "Phone". You will need another telephone cord to plug into this and then connect the other end to the phone.
Nov 13, 2008 | GE 29888GE1 Digital Answering Machine
Can't fax
You probably have the telephone cord patched into the wrong jack. Make sure it is plugged into the jack marked "line." If the problem persists, try doing this: 1. Unplug the power cord and the telephone line cord. Then wait for 30 sec or so before 1st plugging in the powercord. Wait until the display reads the currently set time, then plug the telephone line cord into the jack marked "line."
Nov 28, 2007 | Brother IntelliFAX 2800 Laser Fax
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
