Question about Refrigerators
Change bulb on a frigorex retro
Need to change light bulb inside fridge not in doors
    Top Expert:
  • Refrigerators Master
  • 10,875 Answers
The cover needs to come off and then you need a 25 watt appliance bulb.
Posted on Apr 09, 2015
Fridge light not working
door light switch Need full model # for better idea .
but normal switch should be at bottom of door or at hing side of ref
some model have at top it may be broke off and thats why you don't see it send us a full model number we will find for you
Feb 28, 2015 | Hotpoint Refrigerators
Have a frigorex coca cola fridge in my shop, at the moment it is not cooling stock, what are the usual problems with this fridge
fridges not cooling regardless of make suffer from several problems.
low gas from a leak door not closing properly/leaking door seals
compressor motor not running from low gas /overload/burnt out
faulty thermostat /settings. In a business because you need the unit to operate all the time ,get a fridge mechanic in to fix it
Dec 23, 2014 | Refrigerators
My sub zero 690 has the fridge & freezer light out as well as the screen
Well the most likely cause is 2 bad door switches, though I rarely see the door switch go bad in the freezer. At the top of the door openings you will see 2 switches in the freezer and the fridge. If you pull down the grille and remove the cover over those switches, the light switch will be the one with the white back, and the fan switch will be the one with the black back. I would try changing the switch in the fridge, and maybe start in the freezer by changing at least 1 bulb before blaming the switch. If that 1 new bulb doesn't light, change that switch too.
Mar 24, 2013 | Sub-Zero 690 Side by Side Refrigerator
Fridge light does not work nor the display inside fridge is the bulb fused so when blown display goes out
Yes , the bulb lights up a fiber optic strand , which runs to the display . No light , no lighted display .
Sep 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Light bulb gone out and fridge freezing
Hello there! When you close the door the light goes out anyway. Food does not need to be in light to remain fresh as you probably already know. If the light is not working because the fridge is not getting power, the breaker is tripped or the fuse is blown, then fix those problems, your food may spoil. A bulb is easy to change and only costs a couple of bucks. It is just like changing any other light bulb. Good luck xoxo
Jun 07, 2009 | Refrigerators
Fridge light not shutting down, alarm on, temperature heating up
you do have a switch at the top door hinge . make the phillip screw are tight at the top of the door . if they are loose the door will not align in order make contact with that switch. or you may have a faulty light switch
Oct 20, 2008 | Viking DDBB363 Bottom Freezer Refrigerator
Smeg Fridge light
What you need to locate is the door switch mechanism for the fridge. These are normally located towards the top of the door and protrude so that when the door closes the switch is pushed in. To find out if you have a problem with the switch just press it when the door is open and the light should go off. The switch itself can appear in various forms either as a protruding rod or a curved plate which pushes upwards against the door side when it closes. If I could draw in this section it could be better explained. But if you look around the inside of the fridge on the side away from the door hinge then you should find something you can push. Sorry to be this vague. If you do need a replacement switch they are normally quite simple to change depending on where they are located, most are two screws, or just a push in type. Hope this has been of some help.
Jul 04, 2008 | Smeg FAB28
BUZZING NOISE ON WHIRLPOOL GOLD FRIDGE/FREEZER
YOU MAY HAVE A BAD LIGHT BULB, SOCKET OR LIGHT SWITCH. TRY WIGGLING THE SWITCH TO SEE IF THERE IS ANY CHANGE IN THE BULB INTENSITY. IF NO CHANGE, TRY REPLACING THE LIGHT BULB. IF NO CHANGE, THE SOCKET NEEDS REPLACED.
Apr 08, 2008 | Refrigerators
Smeg Fab 32 door problem
Remove the lower hinge on the fridge door and pack out using a piece of cardboard resrcew the hinge onto the door, this will resolve the problem Regards Advisor Smeg Agent
Jun 08, 2007 | Smeg FAB32 Bottom Freezer Refrigerator
Refrigerators Logo
219 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
