Question about Logitech 250 Headset
Logitech Bluetooth Wireless Headphones 980397
I recently bought the above item and did not receive any instructions on how to set it up, please help. I have tried to charge it up and can't seem to even get that done. Also I have tried to find instructions or a manual on the internet and can't. Please help!!!! and Thanks so much!!!!
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Logitech Master
  • 94,099 Answers
Re: Logitech Bluetooth Wireless Headphones 980397
Posted on Dec 02, 2010
0 characters
3 Points
I go to set up my wireless headset with my playstation 3 but it won't pick up any devices.
You must put both the PS3 and the Backbeat into pairing mode. See your instruction manual for the PS3 for pairing. Once you have both devices searching for each other they should pair right up.
Instructions for putting the Backbeat 903 in pairing mode:
With the headphones powered off, press and hold the Power/Pairing button until the LED indicator flashes blue and red.
Use the PS3's menu to search for the Bluetooth headphones and select 9xxBackBeat.
If prompted, enter 0000 for the PIN code/passkey.
Here is a link for the User's Guide:
Plantronics Backbeat User's Guide
Good luck from Headsets Direct!
Mar 23, 2011 | Plantronics Backbeat 903 Bluetooth...
In recent days my headset (590A) has only been transmitting sound on the right ear via bluetooth connection, when I use the 3.5mm jack (connected to left ear) both ears work. Is there a fix for...
Your headset can be used as stereo headphones or a wireless microphone for a bluetooth enabled device like a cell phone or a computer. When you plug the headphones into a device with the 3.5mm jack the headset automatically turns into stereo headphones and disables the microphone(headphone mode). It sounds like whatever device your headset is connected to via bluetooth is using the wireless microphone protocol where sound only comes through the one speaker and the microphone is on(microphone mode). The bluetooth protocol settings of your device may have been changed accidentally. You will need to go into the bluettoth settings of your device you are using with your headset and change the protocol. If it is a cell phone you will need to go into the bluetooth settings in the settings menu. If it is a computer your can adjust the bluetooth settings in the control panel.
You can download the pdf file of your instruction manual for your headset here
I hope this was helpful and let me know if you have any other questions. Thanks for using FixYa
Oct 15, 2010 | Plantronics Pulsar 590A Wireless Headset
I have a Logitech bluetooth headphone. And I had to buy a new PS3. I threw away the manual to setup the headphones. Can you tell me how to set it up?
Your passcode should be 0000 (four zeros)
Please review this guide for connecting a bluetooth headset to a PS3:
(Click here)
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!!
Jan 15, 2010 | Motorola Mobility Logitech Mobile...
Hi, I purchased two units of logitech cordless
Your friend should be able to use the headset if your friend's computer has Bluetooth feature. THe computer will send and receive the Bluetooth signals with one transmitter/receiver like your computer does and then connect to the wireless lan with a different transmitter/receiver system on a different frequency. Just make sure your friend's computer has Bluetooth feature turned on and then setup the headset by the "pairing" process.
Jun 15, 2009 | Logitech Cordless Headset for PC & Mobile...
How do you pair your Insignia Headphones/ Headset with a PS3? It is called an insignia NS-BTHDP/NS-BTHDST. In the instructions it only talks about pairing it with a computer. Can someone help me?
Go to Accessory Settings on your PS3.Then go to mange bluetooth devices and hit register new device. while doing this take your headset and put it in discovery mode. You do this by holding the power button and the it alternates between blue and red lights.It should work after that.
To test it go to audio device settings and see if it shows up.
Mar 26, 2009 | Insignia Bluetooth Wireless Headphones...
Wont recognize the headset
Make sure the Headset it charged, driver is fully installed, and you have it in pairing mode...but I was going nuts over the same thing, then i remebered that I had to allow my Laptop to be seen by it and even then i had to allow it to connect...both those options are easy to the 'Bluetooth Settings' in the bar just above the main window, and be sure to check the 1st, 2nd and 3rd boxes, Now it can see you, request connection and hookup. Dont forget the PASSKEY is always '0000' by default, and you also have to make them the default devices by R clicking the volume icon and going into 'playback' and 'recording' tabs...dont forget to apply THEN exit, lol...Merry Christmas
Dec 16, 2008 | Insignia Bluetooth Wireless Headphones...
Lost Disc
I bought this headset from Best Buy and it came with a usb dongle.  I also lost the disc.  Insignia's website is useless, and the Broadcomm update website is down at the time of this writing.  After hours upon hours of scouring, I found a working driver, which works perfectly.  This works on Windows XP, but I can't verify that it will work for Vista.    I hope this helps you.
I will never buy Insignia products again because of their lack of driver support.
Best regards, RobotJay
Aug 21, 2008 | Insignia Bluetooth Wireless Headphones...
Insignia disk does not read from Playstation3
if the headset is bluetooth then the ps3 should be able to connect with it while its in pairing mode form the settings menu. if the headset will not function without other software then the ps3 cannot use them. the ps3 will only read the select music, video, and game discs.
Jul 25, 2008 | Insignia Bluetooth Wireless Headphones...
Won't charge!
HEADPHONES AND SPEAKERS Hi There Try this, VOLUME Try Adjusting the vlume on your PC first. Check the volume on the Headphone too if there is one. CLEANING Using a dump clothe. Wipe the plugs with a twisting motion. WIRELESS\BLUETOOTH Check your battery if it is drained. Try replacing them witha new one or charge them if they are rechargables. If all fails then You may have a Sound Card problem. Using a spare Speaker or Headphone check it if it works. If its not then its Defective and needs replacement. If its working then your Speakers or Headphones are defective. Try fixing them by cleaning or checking the Continuity of its cables using a analog Multi tester. Hope This helps =============================================== If you are having trouble with a Newly bought items then return them a demand a replacement or a refund!You may have purchased a reconditioned\repaired\factory defect product.
Sep 19, 2007 | Motorola Mobility H500 Wireless Headset
Logitech 250 Headset Logo
53 people viewed this question
Top Logitech Headsets Experts
Brian Sullivan
Brian Sullivan
Jazz Boyce
Jazz Boyce
Level 1 Expert
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Logitech Headset Expert? Answer questions, earn points and help others
