Question about Zanussi Washing Machines
Remove knobs zanussi zwf 1621 w - Zanussi Washing Machines
    Genius:
  • Zanussi Master
  • 1,585 Answers
Some timer knobs had pop on front cover on knob the 2ba nut on inside of same.
Posted on Apr 12, 2015
5 Suggested Answers
  • 4 Answers
SOURCE: zanussi zwf 1415w become very noisy when it is running all time?
you have to call a technician to check the drum bearing
Posted on Jun 04, 2008
  • 67 Answers
SOURCE: Zanussi ZWF 1621 S Front Load washer - LED Lights are not lit up
WHAT IS WRONG WITH YOUR DISHWASHER?
small_9_26.jpg For a detailed Dishwasher illustration, click below.
Built in
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
There's an error code on the digital display
It doesn't work at all
It cleans poorly
There's no water entering the machine
The water doesn't drain from the machine
It's noisy
It leaks
The dry cycle has problems
The door has problems
The cycle doesn't complete
I see an error code
The detergent cup doesn't open
The cycle times are too long
Note: If your repair problem isn't listed, click here to email the RepairGuru. He will give you the help you need.
It doesn't work at all If your dishwasher doesn't work at all, check these:
Power from the house
Door switch
Wiring
Timer or selector switch
Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
if this helps please vote me a fix ya
Posted on Jul 18, 2008
  • 62 Answers
SOURCE: washing machine will not start
I don't think this is a GE model #, but any who, if you hear a humming <water valve sol> the product valve is not getting water to it, first, don' laugh, make sure both plumming valves are on..
If they are off and no one knows how they got turned off, it falls under the old "****-happens" deal !
Posted on May 21, 2009
apart4u
  • 213 Answers
SOURCE: how do i remove the door seal on the zanussi zwf 1220s
Follow these steps to replace your door seal:
For all Free appliance repair videos visit our VIDEO TUTORIALS Disconnect all power to the machine first!!
1 Locate the outer clamp band securing the seal to the door rim on the washing machine and examine it carefully for holes or tears. Many can be prised off with a flat-bladed screwdriver they have a spring system holding them, but some have a tensioning arrangement that has to be loosened.
2 After removing the outer clamp band, locate the inner one securing the seal to the drum and establish how this is secured. It may be necessary to loosen a clip, or you may be able to prise the band off with a flat-bladed screwdriver. Some are like very large Jubilee clips that you have to undo usually from the top.
3 Once the clamp bands have been removed, use both hands to pull the seal away from the inner drum rim. Some machines have a water spout holes that will have to be lined up. Others have a drain holes.
4 Rubbing a drop of washing up liquid into the groove on the door seal/gasket that locates on the drum makes fitting the new seal easier.
5 the new washing machine door seal should be fitted by locating the drain holes at the bottom of the seal first then push it on with both hands working opposite directions towards the top. This is quite hard if you have never done it before.
6 refit the inner band remembering this must be tensioned correctly for it to be water tight.
7 now fit the outer band and the test the machine for any leaks,
All washing machine spares featured in this article are available at apart4u with more video help in our tutorial section.
Information provided is a guide only. aPart4u accepts no liability for any problems occurring whilst attempting any advice shown. If in any doubt about fixing your appliance, always contact a qualified repairer.
Posted on Jan 19, 2010
Zanussi zwf 1221w drum bearing replacement, is this an easy job to do
This is not an easy repair to carry out, it involves a complete strip down of washer, and removing the whole drum assy from the washer, and until it is stipped down, you will not know if the drum shaft is worn, if it is, then this puts it way beyond an economical repair.
Feb 02, 2011 | Zanussi FLA1001W Front Load Washer
Zanussi ZWF 1621W - fails to spin
Unfortunately this fault sounds like it could be the timer, the PCB board or even the motor. A pressure switch fault or blockage in the pressure bottle would cause the symptoms that it washes and distributes perfectly OK, but just wont do the fast spin. It doesn't sound like the case here. The jerkyness of the motor implicates one of the above causes. It's possible for badly worn carbon brushes to cause a jerky motor. If you had water on the electronics too, there's no guarantee it hasn't caused some problem. It doesn't look promising I'm afraid.
The "two air pressure sensors mounted at the top of the frame connected by pipes to the nether regions" must be the pressure switches.
Sep 26, 2009 | Washing Machines
My problem is the machine makes a noise as if a piece of cardboard is rubbing at one particular point each revolution of the drum it has now become quite loud on my zanussi zwf 1632 w can anyone help ?
I may just be lucky or it might just be temporary but the fault has cleared on my zanussi zwf 1632 w. washing machine thanks for the offers of help if needed in future i will certainly contact FixYa."Bill 34"
Sep 19, 2009 | Washing Machines
Washing machine will not start
May 20, 2009 | Washing Machines
Zanussi zwf 1440
Something wrong with the pump,leave out let hose down as flat as possable into a basin or whatever,to drain water,remove pump test and check it.
Sep 05, 2008 | Zanussi ZWF1440 Front Load Washer
Washing Machines Logo
57 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
