There is a lot of water on the floor this happens 2 to 3 days after the last wash. After washing I check daily to see if there is any water on the floor. Also checked the inlet&outlets
    Top Expert:
  • Washing Mach... Master
  • 44,284 Answers
Sorry but no make no model no help can we be
Posted on Apr 09, 2015
Kenmore washing machine 2 year old is now flooding my floor every 20 loads happiend 4 times. Please help.
Is the water flooding coming from the top of the washing machine?
Check the drain pipe in the back to see that it's not loose. Also, look inside the drain pipe and make sure there is no algae. Algae might cause low flow through the drain pipe and it will overflow.
Hope this helps.
Feb 07, 2014 | Washing Machines
My washer sometimes ends up with a couple inches of water in the tub a day after last used. Also, at times water leaks on the floor. Neither of these things happen consistently.
It is likely that the fill valve located inside the rear panel is leaking, especially if you leave the supply lines turned on all the time. One annoying fix is to turn off the water supply after each laundry session but than you have to remember to turn the water on again next time
Dec 28, 2012 | Maytag PAV3240A Top Load Washer
I ran a rinse cycle on my washing machine (top load) last night. When it was done, I went into the laundry room, and there was water on the floor, in the hall and in the adjoining bathroom. The water was...
check your connections on your hot and cold water taps that connect to your machine check youy drain connection if all is ok then it is your pump
Feb 27, 2011 | Washing Machines
I have water leaking onto the floor from my LG Tromm washing machine. I tried to check for blockage of the hose but it is still leaking.
Check the connections on the back of the washer for the cold & hot water connections. This just happen to me last week. My husband tighten them and resolved the problem. Good Luck !
Jan 16, 2011 | LG WM-2277HW Front Load Washer
Washing machine candy grand'o 1400 has stuck, vanish stain light
Ok, turn the washing machine off and unplud. Open the flap at the bottom left of the machine. Put a bucket underneath it. Unscrew the cap. Water will pour out - lots of it and very quickly - so make sure you have a bucket underneath it and lots of towels round that.
Once the water has drained out, check there are no blockages in there. You may find that some coins or buttons flush out with the water. That will be your problem.
Once clear, screw the plug back in and turn on machine.
Dec 23, 2009 | Candy Washing Machines
Standing water in washing machine
The inlet water valve is not shutting off completely. Replace the valve, which is the part the inlet hoses screw onto.
Dec 09, 2008 | Whirlpool LHW0050PQ Front Load Washer
I have my setting on Warm wash/cold rinse. In the winter, I get cool wash/cold rinse but in the summer I get warm wash/cold rinse. This is just the opposite of what I want and this has done this since...
the hot water solenoid valve -
the hot water hose -
the filter screen in the tap /hose connector -
one of the above is likely blocked or restricted
check them in reverse order, the most likely and easiest is last
turn the water off before disconnecting any hoses to check, makes a mess
Jul 22, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
