Question about Dryers
Hoover Dryer Model D6792A. Trying to find a user manual or find out how to use the rear vent once its panel is removed
  • 960 Answers
If I remember correctly, there is a venting kit that you purchase which consists of a fitting to go on the back of the dryer and a large diameter hose which you put out the window or door to vent the hot air from the dryer. There used to be another kit which allowed you to connect to a wall outlet which vents directly outside.
Posted on Apr 09, 2015
My dryer, model Mdg6800aww, currently vents to the side but I need to change it to the back but the installation and user manuals do not say how to do it. Any ideas?
You need to take the dryer apart to do that. You would have to reroute the vent internally to go to the back of the dryer. http://parts.sears.com/partsdirect/part-model/Maytag-Parts/Dryer-Parts/Model-MDG6800AWW/3048/0151200/W0703640/00001
It's piece number 17. You have to get started by taking the screws out of the left and right side of the door hinge. Then open the door and pull the front panel forward. There are two 5/16 on the bottom of this model you'll have to remove, I'm pretty sure, too.
Nov 23, 2013 | Dryers
I have a Miele T9800 dryer and it stopped working and the vent/filter check light came on. I checked the filter and vent and both are clear and removed the rear cover and made sure the heating element...
Hi - it makes me wonder as why we always tend to do things first prior to seeking the right/correct advice.
A T9800 Miele is not your everyday cheap dryer as you will know - the questions is have you still got your user Manual and if you do - have you read it carefully - it will tell where the problem lies and how to clean it.
I cannot grasp the fact that you would remove the rear access panel for a heater bank to check the resetable over temperature unit.
The machine clearly indicated a vent/filter error not a heat error - I know at this moment you have and are swearing & calling me names...
I will let you cool down a little ....................and I will tell you what you should have done instead of removing that panel Ok?
Jul 16, 2011 | Miele T9800 Electric Dryer
Where are fuses located on Whirlpool electric dryer?
Check the internal thermal fuse, which is located within the back panel. The fuse is about an inch long and oval-shaped.
If your dryer is not getting hot, the thermal fuse may be blown. Instead of calling an expensive repairman, you can replace this simple part yourself in less than an hour. Make sure you purchase the correct replacement fuse for your make and model of dryer. Your owner's manual should have a list of compatible part numbers. You may also be able to order a replacement directly from your dryer manufacturer's website.
Things You'll Need
  • Hex nut screwdriver
  • Replacement thermal fuse
    • 1 Disconnect the dryer from the electrical outlet. Remove the dryer vent from the back of the dryer by loosening the retaining screw on the clamp attaching the vent to the dryer's exhaust port and sliding the vent off of the port.
    • 2 Remove the hex nuts holding the dryer's rear panel in place. Slide the panel off to the side of the dryer. Locate the thermal fuse on the heating element housing on the right side of the dryer. The fuse is an oval-shaped part located near the top of the housing.
    • 3 Slide the thermal fuse wires off of the contact terminals on the fuse. Remove the hex nut holding the fuse in place and remove the old fuse.
    • 4 Place a new fuse on the housing and replace the hex nut. Reconnect the thermal fuse wires. Replace the dryer's rear panel and plug the dryer back into the electrical outlet.
Jun 12, 2011 | Whirlpool LER8648P Electric Dryer
Model 87577800 sock went thru the lint vent
The model number you have listed has the dryer vent on top of the dryer. Small items commonly fall down into the vent chute on these dryers. Articles can easily be retrieved by following these steps:
1. UNPLUG the dryer. Dangerous voltage is still present inside a dryer even when it is turned off.
2. Remove the lint screen and remove the two screws that connect the vent chute to the top panel.
3. Turn the dryer around so you can access the rear, and remove the exhaust vent hose.
4. Locate and loosen all the screws from the perimeter of the dryer back panel.
5. Remove the back panel of the dryer.
The air blower assembly and dryer vent chute are located on the left hand side (as viewed from the rear of the dryer). Remove the screws that hold the vent chute in place and you will be able to access anything that has fallen into it.
NOTE: Anything left in the vent can eventually get caught in the blower fan. So, it is important to retrieve anything caught in this area to prevent damage to the fan and to ensure the dryer ventilates properly.
If you have any questions about these procedures, please let me know. I hope this helps you.
Oct 27, 2009 | Dryers
A sock fell into the lint resevoir; how do I remove it?
If your dryer is the model you have this listed under (lint filter on the top panel), then retrieving something stuck in the vent is pretty simple. Just follow these steps:
1. Unplug the dryer and remove the back panel. The dryer exhaust vent is located on the left hand side (as viewed from the rear).
2. Remove the screws that hold the vent in place and remove. NOTE: Make sure you remove the two screws located on the top panel as well. The entire exhaust vent will come out.
If this is not how your dryer is configured, please post back with your correct model number. If you have any questions, please let me know. I hope this helps you.
Mar 31, 2009 | Whirlpool LEQ8000JQ Electric Dryer
Trying to access the blower fan on a Kenmore 80
Remove the rear panel.
Then remove the screws that secure the blower fan vent on the left side to access the blower wheel.
Mar 08, 2009 | Whirlpool LER4634J Electric Dryer
LG DRYER DLE2532W DISASSEMBLY INSTRUCTIONS
DLE2532W is an electric heat model. (a gas model would be a DLG......) To get a rear control LG dryer apart: Open door and remove two phillips head screws at the 5 and 7 o'clock positions. Use a putty knife to release the clips holding the top panel to the dryer front by pushing the clips in at the seam of the dryer top and front, a couple inches in from each side. Swing top back. Remove two phillips head screws at the top, allowing front panel to pull forward. Unplug drum light and door switch and drum sensor plugs, allowing front panel to be completely removed and set aside. Now, look at the burner area at the lower right. Behind the gas valve you will find a small (about dime sized) high limit thermostat on the left side of the burner cone. It has two wires attached and has a small pin in the center of it. (Only on gas models) Push the pin in.
Now, if that get's you ignition again, CORRECT VENTING ! Get rid of flexible vent material. (use only rigid aluminum vent pipe and elbows) Clean out vent pipes and outside vent hood. Outside vent hood should be the kind with a four inch flap for the opening, not a two inch flap. Tripping of the high limit thermo is almost always caused by inadequate air flow.
Dec 28, 2008 | LG DLG5932W Gas Dryer
User manual needed for Hoover washer/dryer
Hi.
In you browser box type in Hoover user manual.
Then scroll down to Hoover after sales service instruction manuals.. Click on this, and then on Laundry.then on Waher -dryers, follow instructions
You will find your model listed there,.
Please leave good feedback.
Thanks
Nov 29, 2008 | Hoover Washing Machines
Dryer not heating Enough
Ceck the vent hose and vent. Make sure these are clear of obstruction. This is tipical of poor venting. The dryer can`t remove the moist air to dry the clothes properly.
Nov 14, 2008 | Hoover HDC6 Electric Dryer
Dryers Logo
106 people viewed this question
Top Dryers Experts
