SOURCE: Red power button & "lamp" indicator blinks
Having similar issue with my PT-44LCX65. Lamp blew and replaced it (last month), never figured out how to reset timer. Now red indicator light blinks once every 5 seconds and after about 4 minutes TV goes black.... Any ideas?
SOURCE: 60" Sony KDF-E60A20 - Red Light Blinks 6 times
The problem you have is a failed thermal sensor. Depending on how tech savvy you are you can replace it.They have changed the way the thermal sensor looks but it isnt too bad too put in. Any repair shop should also be able to do this for you.
Part number is 1-910-006-44 Themal Fuse Sony Part.
SOURCE: I have a JVC HD52z575 that when I turn it on the
Power supply would be the issue the fix would be my good friends @ www.teexp.com I hope this helps.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: I have Sony tv model KDF-42WE655 which stopped
Its not the green light that you should be count but the red. How many times is it blinking? Here is a quick update of the errors that are most common.
3x - Lamp switch not engaged
4x - Fans issue
5x - Lamp
6x - Thermal fuse
