Question about TP-LINK TL-WR740N 150Mbps Wireless Lite N Router IEEE 802.11n IEEE 802.11g IEEE 802.11b Built-in 4-p... (813120016543)
Works poorly. Regularly turned off and gives the reason as limited
    Top Expert:
  • TP-LINK Master
  • 10,875 Answers
Get a new power supply,one that goes to it
Posted on Apr 09, 2015
My Singer model 600 will not give me the medium or wide zigzag widths. It is set on al and is stuck on the small width. Help?
It is a metal mechanical machine and could very well need a good cleaning and oiling (if not done regularly). The old oil solidifies and turns to glue. The following may be helpful:
Berninamatic 910 is frozen Where can find manuals so that can service it
If the machine continues to have limited zig-zag motion, it could be an adjustment.
Oct 11, 2016 | Singer Sewing Machines
Mitsubishi dion poor idle or rpm stops at 4000
tuneup time skipped? the 60k miles tuneup?
scan it? if there are DTC errors, it might in LIMPHOME mode, with RPM limits dropped for good reasons.
or is misfiring. that too can be felt or seen with the scan tool.
the poor idle proves its running bad, no other symptom better prove this. its misfiring, only queston is , why.
50 reasons
or 1 to 10 simple tests to find true cause, ask.
after a full 60k tuneup,(repeats)
Jul 09, 2014 | 2000 Mitsubishi Galant
Painfully slow dell mini netbook
A slow Dell Mini computer can be caused by many many reasons such as outdated hardware, overload start up programs, corrupt registry issues, too many junks, virus attack, poor security software taking too much system resources, remnants of uninstalled applications etc. The fact is, you should keep some system maintenance job regularly. If you don't want to do the job manually, try the Dell speed up solution available here: http://www.speedupslowdell.com/dell-pc-tune-up.html
Jan 04, 2012 | Dell Inspirion Mini 884116022442 Notebook
Hp mini 210 too slow
Well, the issue can be caused by many many reasons such as outdated hardware, overload startup programs, corrupt registry issues, too many junks, virus attack, poor security software taking too much system resources, remnants of uninstalled applications etc. The fact is, you should keep some system maintenance job regularly. If you don't want to do these manually, try http://www.speeduphp.com/speed-up-slow-hp-mini.html to give a free & full scan of your slow HP PC to find & fix all possible issues. Best regards!
Feb 18, 2011 | HP Mini 210-1030NR Netbook
2001 harley xlc1200
I know this sounds crazy and the only reason I am giving this as a solution is because it happened to me. Even though the electrical system has enough power to turn the engine, it does not have enough power to turn the engine and power to spark. Correct any poor connections at the battery terminals, etc. Try jump starting the bike. If it works, you know the problem is a weak battery and/or a poor connection.
Feb 02, 2009 | Harley Davidson Harley-Davidson Motorcycle...
Arcoair central heat /air conditioning unit
The blower motor kicks on when there has been a 24 volt control failure.
This usually means that a limit switch has tripped.
Most likely that would be a high temp limit switch or a rollout switch.
First, make sure the filters are clean. and the evap coil is clean. If eaither are dirty/clogged, it will partially block airflow, causing the furnace to overheat, causing the high temp limit to trip.
A rollout switch typically trips for three reasons.
1 flame rollout into the burner compartment due to poor airflow.
2 overheating af teh metal plate the rollout is mounted to, due to dirty, old, rusted components.
3 a bad limit switch.
If your unit has an LED light, count the flashes and it will hepl popint out the problem.
(locate the wiring diagram/flash code list, and correspond the flash count, with the code.)
First, check filters.
Jan 14, 2009 | Heating & Cooling
Polaroid 37"
The reason for the first failure is use of very poor quality or LOW voltage caps.The 35 volt Radio Shack caps will work fine and will give no future trouble.Too low a voltage rating or poor manufacturing leads to leakage and drying out of electrolytic caps.35 volt versus 10 volt is a higher rating and,within reason,will not cause a problem.For technical reasons don't go extremely high(such as 150 volts).This might cause a problem down the line.
Aug 25, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
HP Pavilion Slow boot up
Well, that's absolutely abnormal. Generally the problem can be caused by many many reasons such as outdated hardware, overload startup programs, corrupt registry issues, too many junks, virus attack, poor security software taking too much system resources, remnants of uninstalled applications etc. The fact is, you should keep some system maintenance job regularly. If you don't want to do these manually, try the hp speed up tool http://www.speeduphp.com/ to give a free & full scan of your slow HP PC to find & fix all possible issues. Regards!
Oct 18, 2007 | HP Pavilion dv4000 Notebook
TP-LINK TL-WR740N 150Mbps Wireless Lite N Router IEEE 802.11n IEEE 802.11g IEEE 802.11b Built-in 4-p... (813120016543) Logo
182 people viewed this question
Top TP-LINK Computers & Internet Experts
Martin Murray
Robert
Level 1 Expert
Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
