The screen on my kyocera duraforce stopped working a red light blinks fast when I plug in charger it stops blinking seconds later please tell me how to fix thank you
SOURCE: Red power button & "lamp" indicator blinks
Having similar issue with my PT-44LCX65. Lamp blew and replaced it (last month), never figured out how to reset timer. Now red indicator light blinks once every 5 seconds and after about 4 minutes TV goes black.... Any ideas?
Posted on Jan 12, 2008
  • 113 Answers
SOURCE: 60" Sony KDF-E60A20 - Red Light Blinks 6 times
The problem you have is a failed thermal sensor. Depending on how tech savvy you are you can replace it.They have changed the way the thermal sensor looks but it isnt too bad too put in. Any repair shop should also be able to do this for you.
Part number is 1-910-006-44 Themal Fuse Sony Part.
Posted on Feb 04, 2008
  • 59 Answers
SOURCE: PT-60LC13
there are fans inside tv need to make sure they are clean and free of dust
Posted on Feb 05, 2008
rulds2008
  • 3866 Answers
SOURCE: I have a JVC HD52z575 that when I turn it on the
Power supply would be the issue the fix would be my good friends @ www.teexp.com I hope this helps.
Posted on Jun 13, 2009
  • 380 Answers
SOURCE: I have Sony tv model KDF-42WE655 which stopped
Its not the green light that you should be count but the red. How many times is it blinking? Here is a quick update of the errors that are most common.
3x - Lamp switch not engaged
4x - Fans issue
5x - Lamp
6x - Thermal fuse
Posted on Dec 15, 2009
MY LG TONE HBS-730 WILL NOT CHARGE
It is charged when the red light goes out. Press and hold the VOLUME DOWN button for one second and an audible will give you the battery charge level - high - medium - low.
Apr 20, 2013 | LG Tone HBS-730 Bluetooth Stereo Headset -...
My Kyocera Zio won't turn on. Red light flashing when plugged into charger.
I had the same problem but I held the power button for about 30 seconds or until it stopped blinking then I hit the power button again shortly after then it worked. I hope this solves your problem also.
May 02, 2011 | Kyocera Zio M6000 Cricket
TV was working fine when we went to bed Monday (August 30) night. Got up the next morning and turned it on. It appeared it was going to come on, the green light flashed and then the lamp indicator light...
1. Red status LED, self-diagnosis error 44, check for open F9A06 on the Power PCB part # 283P128050 on the Power PCB 2. Red lamp LED, self diagnosis error 34. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 930B921002 3. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature, this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 4. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector LE pin 3 and 4 on the Control PCB, if low suspect problems with the switches/buttons on the Control PCB part # 935D776001 5. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector LE pin 3 and 4 check good. Suspect the E2P PCB part # 934C121001 6. (LED does not stop blinking after plug in) Disconnect the USB connector from the card reader to the front from the Chassis, if the LED stops blinking after 70 seconds replace the Card Reader part # 299P271010. 7. (LED does not stop blinking after plug in) Disconnecting the USB connector from the Card Reader did not help. Remove connector FC from the FMT PCB and plug the unit in, if the LED stops blinking after 70 seconds with FC removed suspect a problem on the FMT PCB (part # 930B924002), if the LED keeps blinking with connector FC removed suspect a problem on the DM PCB (part # 934C116002). 8. (LED does not stop blinking after plug in) On the DM PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). See Service Tip VS-78A 9. (LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 UFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C) See Service Tip VS-78A
Sep 08, 2010 | Mitsubishi WD-52725 52". Rear Projection...
When i plug in my tv the screen stays black and wont come on
Hi my name is Roety,
I can help you with your issue ,
Your Mittsubishi has a system the will cause the green light to blink for 70 seconds when first plugged in, if the green light never stops blinking it is either a power supply issue or a stuck keyboard button.
So do the test and reset it to see if the light stops blinking or not.
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
Apr 15, 2010 | Televison & Video
My 2004 sony television wont turn on =[ .... please help fast ;]
What model? is it a tube or flat? count the number times it blinks- then go to the sony website find your model and look up blink codes- it will tell you whats wrong
Aug 20, 2009 | Televison & Video
Wont charge
There are 2 possible reasons. Charger is incompatible/defective or Battery is no longer charging due to its 500 cycles life. You may check the output of the charger with Voltmeter/Multimeter if its stable 5V, If its stable then best thing to replace the battery.
Good Luck
Jun 11, 2009 | Kyocera Finecam SL300R Digital Camera
Help w/ the flashing green light
Good Day;
Cause #1 1. Red status LED, self-diagnosis error 44, check for open F9A06 on the Power PCB part # 283P128050 on the Power PCB 2. Red lamp LED, self diagnosis error 34. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 930B921002 3. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature, this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 4. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector LE pin 3 and 4 on the Control PCB, if low suspect problems with the switches/buttons on the Control PCB part # 935D776001 5. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector LE pin 3 and 4 check good. Suspect the E2P PCB part # 934C121001 6. (LED does not stop blinking after plug in) Disconnect the USB connector from the card reader to the front from the Chassis, if the LED stops blinking after 70 seconds replace the Card Reader part # 299P271010. 7. (LED does not stop blinking after plug in) Disconnecting the USB connector from the Card Reader did not help. Remove connector FC from the FMT PCB and plug the unit in, if the LED stops blinking after 70 seconds with FC removed suspect a problem on the FMT PCB (part # 930B924002), if the LED keeps blinking with connector FC removed suspect a problem on the DM PCB (part # 934C116002). 8. (LED does not stop blinking after plug in) On the DM PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). See Service Tip VS-78A 9. (LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 UFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). Good Luck, big IRISH.
Oct 19, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Charger light
I had this same problem and all I did was to unplug the DC adapter at the phone and plug it back in after a few seconds. The solid charge light came on immediately, like usual. I let the battery charge for several hours before using the handset again.
Apr 06, 2008 | Uniden Cordless Phone
Televison & Video Logo
421 people viewed this question
Top Televison & Video Experts
Electro Med Services...
