Water problem 2nd bad sound 3rd burning smell
    Top Expert:
  • Washing Mach... Master
  • 10,875 Answers
"like the other 98.5%,you give no info,
make,model or year and the problem in
detail,if you want a correct answer
,you should include that"
Posted on Apr 09, 2015
HI. My Yamaha D80 while playing gave a burned smell and than sound quit. Rest works. I opened rearcover and notice 3rd fuse in the back was blown. Changed it. Blew again. So I stopped fidling around.
If the fuse blows and a smell of burning is present then its obvious there i a fault somewhere ahead of the fuse, the fuse is a protection device.
Oct 08, 2016 | Yamaha Cars & Trucks
What is causing transmission to only work in 2nd and 3rd and reverse.? in 2nd and 3rd it feels like its trying to downshift into 1st. In 1st there is a little resistance but it doesnt move
How does your transmission fluid look and smell? If it is dark and smells a little burnt, the transmission is very likely toast. If it is still clear and red, you should let a transmission specialist diagnose it.
Jul 20, 2015 | Cars & Trucks
2000 CHEVY TRACKER **** AND SPUTTER IN LOWER GEARS. WHITE SMOKE FROM EXHAUST, BAD SMELL UNDER LOAD.
bad shift solenoid in transmission ,and white smoke is because you need head gasket,it is broken and you are mixing fuel with coolant,that will cause bad cat converter soon,and your engine will die soon due oil and water mix ,will kill your crank shaft and cam shaft bearing,(check your oil see if it look like milk shake,that is very bad)
Oct 15, 2014 | 2000 Chevrolet Tracker
What would cause the automatic transmission on a1.8L mirage shift harshly from 2nd to 3nd and stay in drive all the time even when taking off from a stop until the ignition is turn off. Stsrt it back up...
Sounds like its in "limp" mode. The first step is to ensure that the fluid level is correct. There's a dip stick on the side of the transmission. Smell the fluid. If it smells like badly burned toast, its overheating. SOMETIMES a tranmission service will fix it, but since the Neutral light is flickering, I'd surmise that the transmission is about to give up, and is likely high mileage.
Have it assessed by some service shops. If the car is more than 10 years old, its probably cheaper to get another car than having the transmission replaced/rebuilt.
SD
Jul 08, 2011 | Mitsubishi Mirage Cars & Trucks
Starting when warm
make sure that the 2nd and 3rd plugs are the right ones possably get all new plugs
Jun 03, 2009 | 1990 Toyota Pickup
Automatic gear box
yes it can be checked and if you can get any oil on the dip stick smell it if it smells bernt or bad smelling the trany is prob no good
Feb 02, 2009 | 1999 Volkswagen Passat
Automatic transmission is stuck in 2nd gear (limp mode)
most newer vehicles  have transmission control modules,that go to a default of 2nd or 3rd gear when they go bad!  I had a 91 plymouth stuck in 3rd gear because of this module! could be your problem!    when mine went out, it smelled like something electrical burned inside the the passenger cabin! I would check all the electrical connections on the transmission first    good luck
Jan 02, 2009 | 1998 Chevrolet K1500
Hearing fuel pump turn on there is power to parts of the van but
Its your mobiliser by the sounds of it.
1st check your key there should be a little glass chip in it.
2nd check your engin bay fuses the starter solinoid my have gone (if it smells like burn toast it has)
3rd check the starter motor is turning freely and has no sign of burning.
if none of these work try this link to download mauals on your car http://www.pdfoo.com/google.php?cx=001873139426500648621%3Adroflb2xhnc&cof=FORID%3A10&ie=ISO-8859-1&q=plymouth+voyager&gl=US
good luck ;-)
Jan 01, 2009 | 1992 Plymouth Voyager
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
