Question about Pioneer VSX-523-K 5.1 Channel AV Receiver Featuring Made for iPhone Co
My Pioneer AV Tuner Model No. VSX-523-K, will pause briefly during a playback of a CD or DVD from a component player. Pause is random and not at same point each time.
Have checked CD/ DVD's which are not damaged. Component players were moved across from an older AV Receiver, and prior to this worked without problem. All components are hooked up via HDMI cables
4 Suggested Answers
SOURCE: Video issues w/ Pioneer VSX-816 AV Receiver
Receivers generally cannot or will not convert from one input type to a different output. That's not to say there may not be some high end models around that do that.
I have this receiver and have it setup as follows. Monitor out Component, S-Video, and the Composite video channel (since I have surround sound I have no interest in getting audio to the TV since I keep its speakers off anyways) to their different inputs on the TV. Warning on some TV's if you plug in S-Video you cannot then use composite on that same input channel as it will override and disable the composite. Then you only need to choose the appropriate input on the TV when you switch sources. In my case Tivo is S-Video, DVD is component, and most of my older video games and VCR are composite.
Having a TV that allows you to change the labels for the input channels is helpful with teaching others that may be less adept, or a snazzy remote that you can program to do everything at once.
Posted on Nov 25, 2007
issy2
  • 462 Answers
SOURCE: pioneer 92txh component to hdmi passthrough
check for input...? if so then connect to it and bring it to the mode...!!!
Posted on Feb 15, 2008
AJIN G
  • 6694 Answers
SOURCE: pioneer audio video receiver VSX-D710S but there is sound to the speaker, but no audio coming from the player
Try to check the audio setting of the player. If you user using optical or coaxial then the audio out put format setting should be Raw other wise it should be PCM. You will see the setting if you go through the menu of the player
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Posted on Jan 07, 2017
What's the remote model on Pioneer VSX 523 k?
The Pioneer VSX-5523-K came with the AXD7690 remote control. Remotes.com has a replacement remote in stock here: http://www.remotes.com/SearchResults.asp?Search=VSX523k .
I hope this helps.
Apr 09, 2017 | Pioneer Audio Players & Recorders
The HDMI light on my receiver is flashing. The power button does nothing, and no other inputs do anything. There is nothing on the screen, and neither of the knobs do anything. I unplugged it for a...
For model vsx-523-k with HDMI light flashing.... PLUG THE UNIT IN AND WITH THE HDMI LIGHT FLASHING "PRESS THE POWER AND THE AVANCED SURROUND BUTTON SIMULTANEOUSLY. .. AND HOLD FOR 5 SECONDS this clear the error. .
Aug 22, 2013 | Pioneer VSX-523-K 5.1 Channel AV Receiver...
Pauses randomly during films, all front buttons play/pause the dvd
Maybe one or more buttons jammed or wet inside.
Try opening front panel and clean the contacts. If problem persists then it is the buttons controller IC/PCB faulty.
Feb 04, 2018 | Televison & Video
Dear Sirs, I have a Pioneer AV Receiver model VSX-817 and is connected to Monitor Audio Speakers (Fronts: BR5, Center: BR-LCR, Rears: BR1), Sub: MS309 (Mordaunt Short). I have connected each front...
Did you remember to remove the shorting link on the MA BR5 speaker terminal ..When you biwire the speakers you should remember to loosen the speaker terminal nuts and remove the shorting link plate between the HF and the LF terminals or you will short the amplifiers two channels together through the link. And modern amplifiers will take a lot of abuse at low volumes but at high volumes the protection circuit will turn off the device.
Apr 10, 2011 | Pioneer VSX-817-S
Av illiterate
Make sure your cables are all properly connected
Jan 28, 2008 | Pioneer VSX-455 Receiver
Pauses during playback on home dvd player
Im using Verbatim discs and they work fine... try those
Jan 05, 2008 | Canon DC210 DVD Camcorder
Overload
Ok, how much is "a bit"? If you are operating your unit at the 50% or more level, your unit is working as it should, as DVD and CD players output more signal than other sources...accordianman
Nov 26, 2007 | Pioneer VSX-D307 Receiver
Pioneer VSX-523-K 5.1 Channel AV Receiver Featuring Made for iPhone Co Logo
51 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
