Question about Vacuums
How to replace belt please - Vacuums
What is the replacement belt number?
Shop for Eureka Vacuums What is... on Google
Eureka® Replacement...
$2.89
Staples Eureka Upright Vacuum Clea...
$5.99
Eureka Eureka Hand Vac Belt
$2.49
Eureka Eureka R Type Replacement...
$5.99
Bed Bath & B...
(4) Eureka AS1104 Drive Belt
$3.49
Google Trusted StoreeVacuum... Search Results
    Belts - Eureka
    www.eureka.com/en-US/Vacuums/Accessories/Belts/
    EurekaWith high-quality vacuum cleaner belts from Eureka, you can get better performance from your ... For optimum performance replace belts every 12 months.
    Eureka Replacement Belt for Upright Vacuum ... - Walmar
Jan 19, 2016 | Eureka Vacuums
Replacing belt
Hello Cheryl,
Please see detail instructions here.
Good Luck,
Rocky
Nov 15, 2011 | Kirby Ultimate G Bagged Upright Vacuum
Hoover Ultra U6430-900 WindTunnel Bagged Upright Vacuum what belt # do I need both belt # please
The wider belt is # 38528035,( package # 40201170 ), and the v-belt is # 38528034, ( package # 40201200 ). The wide belt should be replaced twice as often as the v-belt.
Jul 06, 2011 | Hoover Ultra U6430-900 WindTunnel Bagged...
What belt do I purchase for eureka whirlwind litespeed
If you have the exact model Eureka that this repair was listed under, model 4388 then please find a link to the belt you need below. If you'd like to verify the model number, please check the back or the bottom of the vacuum for a sticker that also will contain the serial number, and look for the word Model Number. If you don't have the 4388, please just add a comment with the model you have and I'll be more then happy to verify these two models take the same belt, or give you a link to the belt that goes to your model if they are different.
Here's a link to the exact belt called for on the model 4388:
Eureka Extended Life Style U Belt, Part 61120
Here's step by step instructions on how to replace the belt:
How To Replace Brush Roll Belt
NOTE: Turn off the switch and unplug the electrical cord
before replacing belt. Belt pulleys can become
hot during normal use. To prevent injury, avoid
touching the motor pulley when checking the belt.
1. Lower handle to floor to change belt.
2. Loosen, but do not remove, two screws to release hood.
Lift hood to remove.
3. Lift left end of brush roll.
4. Remove and discard belt.
5. Place new belt around motor pulley.
6. Place belt around brush roll pulley.
7. Align left end cap with square in base. Push
end cap into place; see left side view.
8. Pull right side of brush roll to stretch belt.
Secure right end cap into base.
9. Rotate brush roll to seat belt.
10. Replace the hood. Make sure hood front is
behind furniture guard. Hood should seat
onto self-locating screw tabs.
11. Tighten screws.
I hope this information was helpful to you in changing the belt. If you have any questions about how to change this belt, please just add a comment here on the repair page of Fixya, and I'll be happy to answer any follow up questions you might have. If you found this helpful, please be so kind and rate my repair helpful and / or leave feedback for me.
Thanks so much,
Chris Jones
GoVacuum.com
Apr 21, 2010 | Eureka Whirlwind 4388 Bagless Upright...
How do i replace my belt on my kirby vaccum cleaner
Please see the following video we've shot on how to replace the belt on a Kirby Generation vacuum cleaner. This should explain to you step by step the procedure to replace the belt. If you need to purchase a belt, we can also help you with this.
Feel free to request a repair clarification if you have any questions I can answer.
If you found this repair helpful, please be sure to rate the repair by clicking the 4 Thumbs Up Icons in the top right hand corner of the repair. Thak you so much.
Chris Jones
GoVacuum
Mar 20, 2010 | Kirby G4 Bagged Upright Vacuum
Makes a loud noise like a grinding noise then smokes comes out and it smells like burning rubber? When I take the (rod) brush off with the belt then run the vacuum there is no more noise? Please help me...
Your belt is worn and stretched and so it is slipping on the motor drive shaft. That is why it is noisy and smells like burning rubber. You simply need to replace the belt. You can get replacement belts here:
Replacement Vacuum Belts
Nov 30, 2009 | Vacuums
Replace the belt
I dont have an answer for tha specific model but most machines all have the same set up when it comes to belts, so please feel free to check this video out belt replacement.
hope this helps...
Sep 15, 2009 | Regina ElectrikBroom RG100 Vacuum
How do you attach the belt for the roller-brush on a Kirby Generation 3, up-right vacuum-cleaner?
Greetings,
Please see the attached video on how to replace the belt on a Kirby Generation Vacuum Cleaner. This is an easy to follow step by step direction on the proper way to replace the belt, as well as do basic maintenance on your Kirby's roller brush which will prolong the life of your belt greatly if done regularly. I you find this video to be helpful, please be kind and rate it well by clicking the thumbs up icon below.
Feel free to request a repair clarification if you have any quesitons on how to replace the belt on your Kirby.
How to Replace the Belt on a Kirby Generation 3 (G3) Vacuum Cleaner:
Thanks for watching!
Chris J.
Jun 14, 2009 | Kirby Generation 3 Bagged Upright Vacuum
How do I replace the belt on my DD Featherlite Vacuum cleaner?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=853915
Generic problem for all Vacuums
Posted by kt87saints on July 30, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Knowing the brand name (Royal) and model number for the vacuum but I can give you a generic way of changing the belt. You 1st need to remove the bottom plate by screws, levers or clips, then you can get @ the belt, if not then you should remove the top cover and then you can get @ the belt. 1st remove the belt from the brushroll and install the new belt on the pulley side of the brushroll and then use a belt puller or a screwdriver with a bend on the end and then stretch the belt onto the motor pulley and then track the belt in a straight line so that is running in a straight line. Replace the bottom plate and the belt change should be done. Please feel free to contact your local vacuum cleaner dealer in your area.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://royalvacuums.com/ Customer Service 1-800-321-1134
Hours are: 8:00 AM to 7:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 30, 2008 | Vacuums
Need a replacemnet belt for upright hoover durabrand
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=723179
Need a replacement belt for
Posted by madasalorry on Jun 30, 2008
Need a replacement belt for upright Hoover durabrand
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The best place to get a replacement belt for a Hoover DuraBrand vacuum is to contact your local vacuum cleaner dealer in your area or to contact the factory @ Hoover listed below and call cust serv and they will direct you to the parts dept. but, please use the genuine belts instead of replacement belts and the average belt change for flat belts is every 4 to 6 months and if it is a geared belt than once a year for the best cleaning. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
Jun 30, 2008 | Vacuums
Vacuums Logo
35 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
