Question about Video Game Consoles & Games
SOLUTION TO LEVEL 57 BLOCKS - Video Game Consoles & Games
2 Suggested Answers
  • 3 Answers
SOURCE: Stuck on level 57 in blocks game in the 50 Classic
so if the grid was counting down 1-4 and across a-f... here is the solution..... 1cr3, 2dr1, 2bl1, 2cl1, 2ar1, 2el3, 3dl2, 3el2, 3br1, 3fl4, 3fl1, 4fl1, 4cl1.... i hope this helps... for the first one, take the top most one (1c) and move it right 3 times..etc
Posted on Feb 18, 2010
If I tilt engine side to side or front to back it smokes excessivly. Otherwise runs good no smoke
is the oil level overfull ?blueish smoke or the float level off and it's flooding black smoke blackish smoke
Apr 28, 2012 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Tip
How To Fix Bad Sectors on the Hard Drive
Let's try to explain the question that grinds us all when in cams about the hard disk. Can we actually repair a bad block? Before of the answer you must find some information about what is a hard disk, how does it work, what are bad blocks. After that you must identify them because you will need the exact location of the affected sectors. After you have done that you must run a few steps:
- before you try to resolve the problem with the bad sector you must extract the data that was written to that block. To do this you must run a Recovery program that you can find freeware on the net.
- bad sectors are unreadable parts on your hard disk but the nature of them must not be always physically and that part of the platens to be destroyed. The bad sectors can be simulated by some programs. This means that some programs installed on your computer can interrupt the reading process on to another segment of the platens. That is in the most happier cases but the chances that the bad sectors are cause by this is less then 10 percent. In this case is difficult to resolve the problem because even the Scandisk or other identification programs used to discover bad blocks will give a rapport that nothing is wrong with your hard disk. The best way is to uninstall the latest programs applied to the computer.
- lets supposed that you have a 20 gigabits partition on your hard disk that has bad blocks. After the identification program it will indicate you where are the blocks situated on the partition. So this way you can isolate them in to another partition that you must never use again. Another scenario can be created and the bad sectors can be at the beginning of the partition in the middle of it and at the end of the partition. Know it's a little bit tricky because you can't just go on and create three new partitions to eliminate the bad sectors from use. In this case most of the new hard disk has a spare space available just for this type of scenarios. You must access the CASH memory of the hard disk and indicates to the hard disk that instead of writing down on the effected blocks it must write to the spare blocks.
- another to restore the hard disk is to use the low level format option. Many of you think that low level format is a program. Wrong, the low level format option is set for any BIOS and can be easily use if you know some command line programming. The low level format can take to be complete a very long period of time but in the most cases we can obtain marvelous results. Actually the low level option takes every cluster of the hard disk and identifies them again (throw a thermal process) and writes down on the memory of the hard disk what sectors can be written and witch blocks are un-writable. This procedure is the best that can be because it will need no effort from your side to try and avoid the bad blocks that already exists and the hard disk itself know where the bad blocks are.
In conclusion the bad blocks can't be fixed. The problem is a permanent one and we can only try to use the hard disk until it is broken down for good. But if you are having financial problem this is a best way to keep going with your old hard disk.
on Feb 03, 2011 | Computers & Internet
How to remove bad sectore of hard disc? s/n=0415j1ftc02540
Thank you for choosing FixYa! Your rating will help me succeed and continuously help a lot people.
Feb 03, 2011 | Maxtor Hard Drive
Blocks puzzle # 57 in Nintendo DS 50 Classic Games impossible?
  1. Top Icon right (3 moves)
  2. Left Icon left (1 move)
  3. Sedond Left Icon left (1 move) clears 2 Icons
  4. Left Icon right (1 move) clears 3 Icons
  5. Top Left Icon left (2 moves) ends up on bottom
  6. Middle row Second Icon left (2 moves)
  7. Middle row Third Icon left (2 moves) clears 2 Icons
  8. Middle row Second Icon right (1 move) ends up on bottom
  9. Middle row Right Icon left (4 moves) clears 3 Icons
  10. Top Icon left (1 move) clears 2 Icons
  11. The Rest Is EASY!! (2 moves) clears 4 Icons
Jan 24, 2010 | Nintendo DS Lite
Engine has seized up on snowblower. replace it?
either replace it or short block it, either way you will be re-newing the heart of your machine..... short blocks are typically less expensive
Nov 23, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Stuck on level 57 in blocks game in the 50 Classic Games, any solutions to this game so I can move on.
Sep 25, 2009 | Destineer Video Game Consoles & Games
Nintendo cheat
you have to jump on the blocks while running without hitting the blocks
Aug 10, 2009 | Nintendo NES Console
Hitachi 57swx20b Suddenly the convergence is out of wack, even the auto correct is messed up -- the blocks at top and sides are distorted. This was a sudden occurrence, connections are secure, broadcast tv...
you probably will have to change the convergence ic. normally there is 2 of those and repair would cost arround 200$
you have to try to solve this in the tv menu first and then consider a repair.
good luck!
Jun 23, 2009 | Hitachi 57SWX20B 57" Rear Projection...
I cannot find the 2nd coin in world 7-1
When you get on the board that goes around in circles, wait till the gold question mark flies by. Jump on it and wait till it gets to the wall. Now can you help me find the last coin in the last level of world 6 and how to get the last coin on world 7?
Feb 13, 2009 | Nintendo New Super Mario Bros. for DS
Video Game Consoles & Games Logo
235 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
