Question about Motorola Radio Communications
My Motorola does not work. It turns on but when charging the charge lights stay red yet the battery meter on the radio reads full. I can not talk or receive on any channel
  • Motorola Master
  • 1,654 Answers
You need a new battery. Often a bad battery will indicate it is full, but in reality it will not hold a charge under a load, as when you press the PTT button.
Best regards
Posted on May 25, 2015
    Master:
  • Motorola Master
  • 541 Answers
Your battery does not have enough current to allow the radio to transmit. The meter is an indicator, but not accurate. Get a new battery.
Posted on Apr 15, 2015
  • Official Brand Answer
  • 3,100 Answers
Contact Motorola Solutions. Get Support .
Mark
Motorola Mobility Support
Posted on Apr 10, 2015
eradiostore
  • 1654 Answers
SOURCE: won't receive or transmit
Here is a link to the user manual: http://www.motorola.com/mdirect/manuals/T56XX_57XX_User%20_Manual_E.pdf
Posted on Aug 21, 2008
eradiostore
  • 1654 Answers
SOURCE: Motorola Talkabout FV700 not transmitting nor receiving
To troubleshoot: Unlock your keypad lock, then reprogram your radios to the following settings. (Check function after each change)
1) Shut off the Interference Eliminator (set to zero).
2) Turn off the Qt filter.
3) Vox setting to off.
By shutting off all the "bells and whistles" of the radio, you will take it back to being just simply on a frequency. If your radios do not communicate with one another then, or with your friend's radios, you have radio which is failing to operate.
If the radios do work in this simple mode. One by one add the special features back until you discover the culprit.
Posted on Dec 26, 2008
eradiostore
  • 1654 Answers
SOURCE: How to charge battery in Motorola Talkabout Distance DPS
You can obtain a wall adapter style charger for your radio at your local Motorola dealer, or online at http://www.eradiostore.com/cart/index.php?target=products&mode=search&subcats=Y&type=extended&avail=Y&pshort=Y&pfull=Y&pname=Y&epcode=Y&q=htn8232
Sidenote: The rechargeable battery is good for about 2 to 3 years. You can tell the age of your battery by looking at the date code on the back of the battery above the stop sign. The first number is the year, the next two numbers are the week of the year. 915 would be 2009 the 15th week. (Or if very old it could be 1999 the 15th week.) A good battery, when charged will go an 8-10 hour day.
Keep both of your charge trays, replacements for these are no longer available.
Posted on Apr 12, 2009
eradiostore
  • 1654 Answers
SOURCE: problem charging
If you are referring to a flashing yellow light on the charging base, this is an error code. Either the 1) battery is bad, 2) not making good contact in the charger, or 3) very very low on charge. The solution for this set of problems is as follows: 1) have the company you purchased them from replace them, 2) clean your contacts with a pencil eraser, 3) leave the battery on the charger with the yellow light flashing for an hour or two. If the battery is just very low on a charge, it will come back to life and the light will change to be constant. If the battery is bad or shorted out, the light will continue to flash and you will need to get with the vendor you purchased the batteries from.
Other things which come to mind are compatibility issues such as you are using a different battery chemistry than you had before. NiCd batteries can charge on either of the two chargers available for the P110 (slow rate or fast rate). However, NiMH and Li-Ion batteries require a fast rate charger.
If you are referring to a yellow blinking light on the radio while it is in the charger. You need to shut your radio off. Radios should always be turned off when charging. If the radio is left on you will never have a full charge. Also, if you inadvertently press the PTT while the radio is turned on, while on a charger, you can cause damage to the radio.
FYI: There is no light to show "out of range" on the radio, unless you are possibly using a trunking or repeater system. A blinking light on your radio indicates the radio is turned on and/or there is traffic on your frequency. Your charger base light can be red, yellow or green. This indicates the charge cycle status. Flashing most always means some type of error.
Best regards
Posted on May 20, 2009
  • 14 Answers
SOURCE: what channel do I put the radios on to charge it
Turn the radios off when you are charging them. The charger may not have the current flow to effectively charge the radios when they are on. If you need to monitor a channel, try charging them one at a time.
Regards,
Longshorts.
Posted on Jul 24, 2009
How to check charging system on a kohler 17.5
This is an easy check if you have a cheap, simple volt meter. It's much better to have an old fashioned needle meter rather than a digital. The needle is more sensitive, much quicker, and makes a clearer diagnostic tool. But not to worry, for you fancy folks a digital still works (sometimes the results are not as clear).
  1. Set the meter to DC Volts.
  2. Attach the red and black leads of the meter to the positive and negative posts of the battery. Most modern day digital meters don't care if the polarity is correct or not. However, if you have a needle meter, best to put the positive of the battery with the red wire of the meter; otherwise the needle will not be happy with you.
  3. Note voltage. It should read near13 volts if the battery is good and fully charged. If it reads below 12 volts it needs charged or it has bad cells. If after charging a few hours, the voltage is still below 12 volts then the cells are bad, replace it.
  4. Turn the key to crank the engine while keeping your eyes on the meter. Whether the engine cranks or not, the meter should not fall much below 11 Volts. If it falls below 10 volts or worse yet below 9 volts, the battery has a bad cell or two. Replace the battery, charge it, and repeat the test.
  5. If the engine starts, rev it up and watch the meter.
    1. If the charging system is working the voltage on the meter should quickly rise above 13 or 14 volts.
    2. If it rises up strongly towards the 14 volt range this indicates the charging system of the machine is working.
    3. If it plays around down near 12 volts you are reading the recovered voltage of a good battery, but the charging system is not working.
    4. If it simply stays below 11 volts, the battery and the charging system are both suspect. Replace the battery first. Fully charge it, and then repeat the tests before worrying about the charging system.
Note:if the battery falls below 9 volts the fuel cut off, a black cylinder on the bottom of the carburetor (if your model has this), will cut off the gas supply to the carburetor.
Mar 15, 2015 | Garden
1989 buick park avenue battery wont stay charged
A possibility is an ignition fuse has blown when the radio was removed. Does the battery light light up when the ignition is turned on. The alternator needs that light to energise and charge, (without it you just run the battery flat), failing that charge the battery, connect an amp meter in series, with every thing switched off, should have a reading of about 0.5 amps (Time clock). If above 2amp that is what is draining the battery. Watch meter and pull fuses one at a time, when the reading drops, that is the circuit/equipment that's causing the trouble.
Dec 31, 2013 | 1989 Buick Park Avenue
Dock red light
Flashing Red Light is not charging and solid red light mean charging the radio battery.
Dec 09, 2013 | Motorola CLS 1110 (1 Channel) 2-Way Radio
I have quit a few talkabout T7400 we bought a few years ago. None of them are working. I can tell you that they were being put back in the chargers in the on position. Is there a way I can test the...
To answer your questions:
1) The light on the charger should come on and stay on, when a radio or a battery is charging. It is not likely all the chargers would go bad at the same time. With this in mind, check your charge contacts on ther radio and the charger. Clean with a pencil eraser if needed. Try charging a battery outside of the radio (if you have a drop-in base), just to see if you get a constant red light on the charger. If not, your charger or possibly the battery is bad.
2) If you have a voltmeter you can check for existing charge in the battery. It will not tell you charging capacity, but it will tell you if it is flat dead or not. Check the date code on the battery. It is a 4-digit number on the back portion of the label in the white area. It will read as 1121, 11 is the year, 21 the week of the year. NiMH batteries have a 2 year life expectancy. And as you indicated, charging with the radio turned on, will age the batteries quickly. It is not good to leave the batteries on a charger with the radio turned on, or for extended periods of time, such as weeks or months. A few days won't hurt occasionally.
3) Lastly, your radios may need serviced. You could have charge/accessory jacks which are worn out, if you are using the wall plug style charger only, and do not have a drop-in base. If they have been anywhere moist they could have grown corrosion and be non-repairable. However, if they are dry and otherwise free of defect they should be repairable. (Current expected flat rate repair is $69 at a dealer who works on this model.)
Best regards
May 23, 2011 | Motorola T-7400R GMRS/FRS 2-Way Radio...
When I plug my Motorola H710 bluetooth in to charge the light only blinks red and when I use it it never seems to turn on?!
Here's the instructions for charging.
Plug the Motorola charger into the end of
the headset.
The indicator light turns red when the battery is charging. It may take up to 1 minute for the indicator light to turn on. When the headset's battery is fully charged (about 2hours), the indicator light turns green.
From your information, it may very well be that the battery should be replaced if the red light doesn't go off as it should.
Here's a link to the full instructions. I hope this helps.
(Click here)
http://www.motorola.com/Hellomoto/Master%20Lists/Product%20Manuals/Static%20Files/US-EN/H710%20QSG%20EN%20Generic.pdf
Feb 06, 2010 | Motorola Mobility H710 Bluetooth Headset
Motorola talkabout sx900 will not communicate when i press the ptt button they just beep
Here is a link to the user guide. http://www.banoggle.com/Products/Motorola/manuals/SX900-manual.pdf Page two will be where you will find most of the instructions. Check your frequency, code and Qt filter. Make certain they match one another identically. If you continue to have difficulties, set the code and Qt filter to zero (or off), as well as the weather alert. Then try the units again. Hope this solves your problem.
Best regards.
Dec 26, 2009 | Radio Communications
Motorola s9 headset not charging
I had the same problem but instead of a red light it would flash green twice and stay off. I could not find the original charger and another plug in charger would not work. I plugged it into my computer with a usb cable and after several seconds it started charging.
Sep 16, 2009 | Motorola Mobility S9 Headphones
Problem charging
Best regards
May 20, 2009 | Motorola For RADIUS P110 7.5v 1200mAh NiCd...
GP 360 Radio Charger
On a Motorola charger, when the battery is charging the light should be a constant red (or amber depending on the charger). When the charge cycle is complete the light will change to solid green. Sometimes the solid green time is brief, as the battery will begin to lose charge, and the charger will go back into trickle mode and change once again to red (or amber). In most cases, a flashing light indicates a problem, such as a bad or shorted battery, an incorrectly seated battery, dirty battery contacts, or a bad connection with the battery. (Note: Batteries last 18-24 months typically. Check your date code for the age of the battery.)
There were several chargers made for the GP360, including but not limited to a 60-minute charger, a 90-minute charger, a 10-hour trickle charger and a 6-unit gang charger which would be a rapid rate, either 60- or 90- minute. If you would supply your charger's model number we could tell you which one you have.
Nov 02, 2008 | Motorola HNN9628A Two-way Radio Battery
My motorola H700 keeps staying red when charging
Wait, how long have you waited for it to charge? It's supposed to stay red until over 80% charge, then switch to yellow. When it is fully charged, it goes to green. When you mean it stays red when plugged in, have you waited the 2 hours?
Jul 10, 2007 | Motorola Mobility H700 Wireless Headset
Radio Communications Logo
440 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
