Question about Garden
After engine heats up, the PTO disengages and won't engage until I drop the throttle to its lowest setting, basically idle. Dealer advised it's not possible for the mower to do this. Solutions?
3 years old, belt is fine and correctly placed, tension pulley replaced, back up safety swithches have been checked, PTO switch has been checked, battery is fine.
panilling9
  • 284 Answers
SOURCE: engine stalls when electric PTO clutch is engaged
check your spacers to be sure you havent locked the clutch assembly directly to the motor shaft
you should be able to turn it fairly free less some clutch drag
Posted on May 26, 2009
  • 146 Answers
SOURCE: cub cadet pto won,t stay engaged
Sounds more like a PTO clutch failure, rather than the switch. The clutch is mounted on the engine shaft, between the hydrostatic drive pulley (nearest the chassis) and the mower deck belt pulley (farther from the chassis).
Since it's an expensive part, make sure the problem isn't in the switch or wiring first. You could do that by probing the wires to the PTO clutch with an automotive test light - they are inexpensive and handy. Clip the ground wire of the test light to the chassis, and probe the hot wire to the clutch (it's the one that doesn't connect to ground) when the engine is running and the PTO switch is engaged. Obviously a helper has to be in the seat, and you should be careful doing this. If the light glows brightly, and the clutch doesn't engage, you definitely have a bad clutch. Good luck! Please rate my answer if helpful, thanks.
Posted on Jul 07, 2010
  • 4044 Answers
SOURCE: My PTO will not engage
Check the operator presence switch located under the drivers seat. If that isn't mounted properly it will not activate like it should and will cause the mower to die when you try to engage the PTO or release the brake with it in gear.
Posted on Jul 06, 2011
  • 2239 Answers
SOURCE: engine runs but stalls when engaged
This sounds like a micro switch, or relay issue, it is not stalling it is being switched off, if there are some relays on the back of the bulk head replace them, they are just a push fit.
Posted on Feb 27, 2012
  • 6468 Answers
SOURCE: TROY-BILT Pony 13AN77TG766 - Brand new battery will not start
use jumper cables and jump t direct to the starter and see if it cranks over that will test the starter if it cranks look at the safety switches and battery cables
Posted on Apr 24, 2012
My new PTO belt has too much play when not engaged, gets off track
-Adjust the engine forward a little until it's good.
Good luck
Mai
Jun 25, 2014 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Why does my engine shut off after running for awhile with PTO engaged; will restart with PTO disengaged, but shuts off when i attempt to engage PTO?
Does this only happen when the engine is warm or at operating temperature or all the time even when cold? In older engines, a 'bad ignition coil' would fail when the engine warmed up and would not start again until cool or at ambient temperature.
Apr 27, 2014 | Garden
Mower runs great, until you engagew the PTO. Brakes open fully, any suggestion?
sounds like the seat safety switch is not working. Check to see if both wires are connected to that switch. If they are.. then disconnect them, jump them together and see if mower runs Ok
Jan 03, 2014 | Husqvarna Garden
Kohler engine troubleshooting
check condition of air filters. check float level and flow of fuel to carby.
May 27, 2013 | Garden
On my 42in cut hydro. Husqvarna, The mower will not disengage until the speed is reduced to a low idle
Before you do anything else check to make sure the blades are engaged on thier seat ( the star) and the blade bolts are tight.
If you have an electric PTO this does not apply to you.
After confirming that your blades are tight check the operation of the PTO cable and the pivot bracket by lowering the deck all the way. Laying on the ground on the discharge side of the mower you will be able to look at the components and see and touch whats not moving freely as you engage and disengage the PTO lever. Look for a stiff PTO cable, stiff pivot bracket, missing return spring, broken spindle brackets and broken deck bracket welds.
Of course you should never work on any mechanical device while it is running.
Oct 31, 2012 | Husqvarna Garden
Husqvarna pto problem(?) disengaged blades to travel, would not engage after. Battery dead when checked after shutting off engine and wouldn't restart
Hi, first charge or replace the battery if necessary then check that the mower is charging the battery. The pto is probably fine but it needs battery voltage to engage. If the mower has stopped charging the battery may have had enough voltage to hold the pto in until you disengaged it but not enough to re engage it. Regards Phil.
Sep 06, 2012 | Garden
Engine runs but stalls when engaged
Feb 26, 2012 | Garden
Chain saw carburator settings for husqvarna 61
Turn both screws CW to stops (lightly), then back out CCW 1-1/2 turns each. This is a basic setting and the engine should start and run. Allow the engine to warm up, then pull the throttle full on. Turn the H jet screw CW until the engine starts to speed up, but still 4-strokes. Proper adjustment occurs when the engine is 4-stroking, but immediately 2-strokes when cutting. This gives best power and lowest heat. Release the throttle and adjust L jet CW until the engine idles fairly well, but will allow the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but the engine continues to run. Hope this helps!
Jun 06, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
PTO CONTROLS. How do you engage and disengage PTO.
The tractor is not a 6300 is it.If it' not you need to adjust the cable for the p.t.o. until it will stay down.Don't turn the turnbuckle too much at a time because there is a fine line between the won't engage and the won,t disengage adjustment.
Sep 06, 2009 | John Deere 6300,6300l,6400,6400l Tractor...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
