Question about Kyosan Fuel Pressure Regulator 1993-1994 Lexus SC400 Fuel Pressure Regulator, 93-94 Lexus SC400 Kyos
What is the problem with my lexus sc 400 no signal coming out ecm to fuel pump relay
1993 lexus sc 400 chokes and quits
check fuel pressure possible fuel pump issue
Apr 01, 2014 | Lexus SC 400 Cars & Trucks
Remove ecm 1996 lexus ls 400
run fault codes and replace faulty sensors. have a fuel pressure . Check injectors for correct operationtest done on the fuel manifold to test fuel pressure regulator. pump and filters/
Dec 23, 2013 | 1996 Lexus LS 400
Where is the fuel emergancy shut of valve in a lexus 91 Ls 400
Toyota products usually don't use a shut-off for the fuel system.
If the fuel pressure is low, you would need to check the fuel pump relay for power and then the pump.
Sep 21, 2012 | 1991 Lexus LS 400
Lost power to fuel pump
the oil pressure sensor has a 3rd wire which feeds to the fuel pump .. If you turn the ignition key on and do not hear the fuel pump running for 5 seconds, replace that oil pressure sensor. That sensor does turn the fuel pump circuit off once oil pressure is acheive and the the computer switches the fuel pum relay on to take over running the fuel pump
May 04, 2012 | 1999 Buick LeSabre
Where is the fuel pump relay on a 1993 lexus 400
The fuel pump relay is located at the front right inner area of the engine compartment just past the strut tower. it should be in a box by itself labelled fp relay.
Have a nice day!!!
Aug 04, 2010 | 1993 Lexus Ls 400
1992 lexus sc 400 headlights only work on highbeam flash position? could it be the switch
try checking the fuse first highbeam and dipped use different fuses.
Jul 29, 2010 | 1992 Lexus Sc 400
Is the fuel pump located in fuel tank in trunk of sc 400 1993 lexus
You are correct in locating the fuel pump. It is inside the tank on the car. Hope this will help you.
May 18, 2010 | Cars & Trucks
The traction control light is on, my lexus sc 400
It is contained in the ECM and The ABS controller
Apr 25, 2010 | 1992 Lexus Ls 400
Kyosan Fuel Pressure Regulator 1993-1994 Lexus SC400 Fuel Pressure Regulator, 93-94 Lexus SC400 Kyos Logo
487 people viewed this question
Top Kyosan Fuel Pressure Regulator Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you a Kyosan Fuel Pressure Regulator Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
