If you smell gas, don't attempt to light the burner. Instead, turn the gas off and inspect the fuel tank, lines and burners once the smell of has has cleared. Always grill where you have adequate ventilation and perform all repairs only after the grill has fully cooled from use. home lights
Sounds like the pressure regulator is malfunctioning. Try disconnecting your gas line. Open/Close all burners then reconnecting gas. If propane, don't turn bottle off before burners. Always turn burners off first, then bottle. then bottle on before burners. This primes the regulator to the proper pressure.
Since the main burners and the rear infrared burner (if so equipped) comes already installed, I don't think your assembling it is the problem. It's probably the grill's gas regulator that is giving you the problem. That's assuming you are following the manual's instructions on how to light the burners, the first time. For now, Ill assume you did. If you open the gas tank valve to fast, it shoots high pressure to the regulator & locks it up.
So, to solve the problem, follow the directions below:
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's
Hose/Regulator Assembly (It's 's not under warranty). It runs about $30.00 at any home center or
hardware store that sells grills & accessories. If you replace it,
turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling!! And thanks for choosing FixYa.
If you don't smell gas, then it is probably electronic ignition and not a pilot light.
But if your oven and none of the range burners light, are you sure you are getting gas to the unit or from the range valve to the burners and oven? Can you light the burners with a match? If you can you can rule out the valve and incoming gas line, and concentrate on the ignitors.
First, consider how long you preheat the grill and to what temperature are you preheating? If it's not long enough to reach at least 350 degrees, before you open the hood to start grilling. You're not allowing the grill to preheat long enough.
Second: Have you looked at the flame height on each burner when they're turned to the highest setting? It may be that the burners need to be removed and properly cleaned. In addition, the venturi valve on each burner may be partially clogged with spiders or spider webs. When that happens, the burners do get the right air to gas mixture/ratio and the burners don't fully light and heat up.
If the burner flames remain lower than they should, the grills regulator may be locked up. In which case, turn the tank valve OFF, disconnect the hose from the tank and wait 5 minutes. Reconnect the hose to the tank and turn the tank valve ON VERY, VERY SLOWLY (Slow motion, slow). Once the valve is fully open, light the burner farthest from the tank first and turn it to high. Does the flame height now, appear to be normal? If so, light the remaining burner(s) the same way. The flame height on all should be the same on the highest setting. If they don't you'll need to replace the grills regulator/hose assembly. You can purchase one at just about any home center or hardware store that sells grills and grill accessories. Just take your old one with you for comparison purposes.
Any or all of the above should solve your problem. Please let me know and if you have any questions, don't fail to ask.
I don['t know the answer but I have the identical problem. 1st & 3rd burner lights but little if any gas getting to second burner. Might be blockage. How do you disassemble burners to clean?
Take the pot support and the burner cover off and clean all the slots out with a toothpick. Carbon builds up over time and the gas doesn't flow over the spark. Do not light until fully reassembled.
sounds like a bad switch in the knob, turn on the defective side, turn on the one that works and keep the clicking going then turn on the defective burner while "other" is clicking if this lights then it means you have a bad switch or loose connections
