Question about Adobe PageMaker 7.0 for PC
What is this errors-1.Was created with a different character set and may compose differently.Proceed with open....anyway? 2.Cannot complete action Interanl error:Bad table index.
We are unknowingly deleted few page maker files. and we recovered with data recovery S/W. Now those files are not being opened.Above mentioned errors are coming one by one.How can we over come this problem. Those files are very impartent .Please guide us.
  • 883 Answers
SOURCE: Unable to use file save or file save as without getting dialogue box with error 15 or 43
someone has placed a read-only password on file
Posted on May 21, 2007
SOURCE: Getting a message about and error on page.
Dear Wendy,
This can happen because of multiple reason:
a) It isn't your fault. The file publisher has not correctly made pdf or its corrupt and won't work on your system because all pdf files can be opened in almost all versions.
b)You might like to check your adobe 8.1 settings for complete installation. Have you correctly installed the program. Also check if you are able to other pdf files on your system or not.
c) you can also try an older version of acrobat, which i doubt should affect the problem.
Finally check the file extensions and password protection problems.
If that was helpful please press solved.
Posted on Nov 26, 2007
SOURCE: Nero Vision Express 3.1.0.25
same problem, did a lot of research, no fix found, problem with nero dropping frames and not recovering. xvid codec not the issue, many people have the same problem with nero vision. bummer :(
Posted on Dec 23, 2007
SOURCE: java install 1101 error
Download Full Manual Install here
http://java.com/en/download/manual.jsp
Disconnect your internet. Then install. Works like a charm now. I had the same issues with Vista. :)
Posted on Aug 29, 2008
pankaj_dic
  • 1250 Answers
SOURCE: Photoshop's Primary Scratch & Windows primary paging file on the same volume
this is not a hardware error actually photoshop writes temporary files, for which it uses hard drive, its alway a better to have scratch disk other then the drive where its installed, you can change this, by going to edit, preferences, then check plug ins-scratch disk, check your first scratch disk other than c, say the drive which has the maximum space, then select any drive
how do you like the solution please rate it i will appreciate your comments
Posted on Oct 28, 2008
I want to put a password at my lexmark printer could that be done.
The User guide has all the information you need to perform thsi action.
Setting Password Protect for the menus
Apply an administrative password to restrict unauthorized users from making changes to the MFP configuration from either the control panel or the Embedded Web Server (EWS).
1 Touch the Menus button on the home screen.
2 Touch Settings.
3 Touch the down arrow and then touch Security.
4 Touch the down arrow and then touch Create/Change Passwords --> Create/Change Advanced Password.
5 Enter and reenter a password of both alphabetic and non-alphabetic characters. The password must be a minimum of 8 characters.
6 Touch Submit.
7 Touch Settings --> Security --> Password Protect to view what configuration settings are protected by the
Advanced Password.
Note: Settings --> Security --> Password Protect and Settings --> Security --> Create/Change Passwords --> Create Change user Password can be used to restrict access with a different password than the Advanced Password. Use Settings --> Security --> Password Protect to select the menus that are accessible with both an Advanced Password and a User Password.
Note: The Advanced Password and the User Password protect the menus on the touch screen control panel of the MFP and the Configuration section of the EWS pages.
Restricting Function Access
The MFP supports a variety of methods for authenticating users prior to allowing access to functions.
1 Open a Web browser. In the address line, enter the IP address of the MFP being configured using this format:
http://ip_address/.
2 Click Configuration.
3 Under Other Settings, click Security.
d Select an authentication method.
e Click Submit.
4 Click on the setup link for the authentication method previously selected in step d.
a Fill out the appropriate information for the environment.
b Click Submit.
5 Click Function Access.
a Set the function authentication level for each function. Select Off to prevent anyone from using a function.
b Click Submit.
Preventing access to the menus from the control panel
It is possible to prevent access to all the menus using the control panel touch screen. To prevent access:
2 Touch Settings.
3 Touch the down arrow.
4 Touch Security --> Function Access --> Menus --> Disabled.
5 Touch Submit.
Apr 16, 2013 | Lexmarkr X646E Multifunction Printer -...
Disable the Key counter on my Konica 7130
HI,
Please refer the manual by clicking on the below link.This will solve your problem.
http://help.nceas.ucsb.edu/images/2/2a/Konica.pdf
Oct 07, 2008 | Office Equipment & Supplies
Tip
How to Set, Reset and Disable Windows Password?
Do you plan to update to Windows 7 or buy a new Windows 7 computer in 2011? Here are some quick tips on how to set password for your Windows 7 machine, <a href="http://www.windowsloginrecovery.com/reset-windows-password.html" style="font-weight: bold;">reset Windows password</a> if you <a href="http://www.windowsloginrecovery.com/forgot-windows-password.html" style="font-weight: bold;">forgot Windows password</a>, and disable Windows password if you want to skip the Windows logon screen in Windows 7.<br /><br /><span style="font-weight: bold;">How to set Windows password?</span><br /><br />To create a Windows 7 password, it just as easy as you create a Windows XP or Vista password.<br /><br />Step 1. Click "Start", "Control Panel", "User Accounts and Family Safety", "User Accounts".<br /><br />Step 2. Click "Create a password" under Make changes to your user account in User Account Window.<br /><br />Step 3. Input and enter your Windows password.<br /><br />Step 4. Enter your password hint or leave it bank and click "Create password".<br /><br />Please remember to create a <a href="http://www.windowsloginrecovery.com/windows-7-password-recovery.html" style="font-weight: bold;">Windows 7 password reset</a> disk, which can help you reset Windows password when your password get forgotten.<br /><br /><span style="font-weight: bold;">How to reset Windows password?</span><br /><br />When you forgot Windows password, you can use password reset disk to reset Windows password if you have one. Otherwise, you can resort to Windows Login Recovery, especially when you are locked out of computer.<br /><br />Step 1. Download and install Windows Login Recovery.<br /><br />Step 2. Burn a bootable CD/DVD or USB flash drive.<br /><br />Step 3. BIOS settings.<br /><br />Step 4. Reset Windows password under DOS.<br /><br />Windows Login Recovery is a safe and reliable <a href="http://www.windowsloginrecovery.com/" style="font-weight: bold;">Windows password recovery</a> tool which allows you to reset Windows password by burning a bootable CD/DVD or USB flash drive.<br /><br /><span style="font-weight: bold;">How to disable Windows password?</span><br /><br />There are many ways for you to disable Windows password if you are in need. Here shows how to disable Windows password by control userpasswords2.<br /><br />Step 1. Click Windows Key + R and enter "control userpasswords2" in the coming Run box.<br /><br />Step 2. Press Enter to pop up the classic User Accounts window.<br /><br />Step 3. Uncheck the box in front of users must enter a user name and password to use this computer, select the user name and click Apply to disable its password.<br /><br />Step 4. Enter and confirm the password for the selected user name. Then click OK button to finish your operation.<br /><br /><span style="font-weight: bold;">Windows Password Tips</span><br /><br />1. Set a strong Windows password composed of letters, numbers and symbols and it should be 8 characters long at least.<br /><br />2. Don't contain personal information or a complete word in your Windows password to in case that others easily guess your password.<br /><br />3. Avoid common password like "123456", "password", etc. as these passwords can be easily hacked.<br /><br />4. Change or reset Windows password on a regular basis, like every month or every 3 months.<br /><br />5. Don't use your Windows password everywhere. It should be different from other accounts.<br /><br />6. Never write your Windows password down on notes plastered to the computer screen.<br /><br />7. Create a password reset disk to in case you forgot Windows password.
on Jan 12, 2011 | Computers & Internet
Tip
Windows Password Lost? Suggestions for you on Lost Windows Password
Today computer has been a part of our daily life, where we have most of our secrets stored, like personal photos, bank account number and password, diary, MSN chatting records, etc. Obviously, no one wants to share these personal secrets with others. But in reality, incidents concerning privacy leakage happen every day. To avoid the hidden security breaches, Creating a Windows password appears a necessity. But sometimes, Windows password lost may ruin completely your day when you can not access your laptop again!
In the following article, it will relates to how to create a Windows password and what to do if you have Windows password lost.
How to protect your computer secrets?
Setting up a password on Windows is the most well-known way to secure your laptop. It can help you stop unauthorized users and hackers from accessing your computer data. Although users can set a Windows password within a few clicks, setting a proper and uneasy forgetful Windows password.
How to set a strong Windows password?
It is an art to set a Windows password. If you set properly, it will be convenient for you. Otherwise, it will never add your Windows security at all. Inversely, it will bring you great trouble. Actually, the principles for a strong Windows password can be very simple:
1. At least 8 characters long. 16 characters long is said to be very safe.
2. Composed of uppercase letters, lowercase letters, numbers and symbols found on keyboard.
3. Significantly different from previous passwords.
4. Do not contain your user name, real name, or company name.
5. Do not contain your birthday and telephone number.
6. Do not contain a complete word.
Remember that the stronger your password, the safer your computer will be from hackers and malicious software.
How to prevent your Windows password lost?
In addition to Windows password, today there are many other passwords surrounding us, like bank passwords, MSN passwords, and e-mail or forum website password. What a hard job for people to keep these passwords in heart.
Take Windows password for example, it turns into a hot topic in the internet that how to recover lost/forgotten Windows password or what to do if Windows password lost. Here are some tips & tricks before or after Windows password lost.
Suggestion 1: note and keep them in a safe place
To remember your Windows password, it is better to prepare a notebook and write all your passwords on it and store them in a secure place. Alternatively, you can also use a portable storage media like USB flash drive to store them.
Suggestion 2: Create a Windows password rest disk
As Windows password, one of the best ways is to create a Windows password reset disk which allows you to reset password when Windows password lost. It is very easy. For example, if you want to create a password reset disk in terms of Windows 7 password lost, you can follow the below steps.
1. Insert a removable media such as a USB flash drive or floppy in computer.
2. Open User Accounts and click Start -> Control Panel -> User Accounts and Family Safety ->User Accounts
3. In the left pane, click Create a password reset disk, and then forgotten password wizard comes up.
4. Click Next and follow the forgotten password instructions to create the password reset disk.
Suggestion 3: with some Windows password reset tools
Once the Windows 7 password reset disk is completed, please locate it in a safe place. It will be helpful if your Windows 7 password lost. Although it is simple to create such a simple disk, many users forget to create one. In that case, it is recommended to use some kinds of Windows password reset tool, like Windows Password Unlocker, which can breezily fix Windows password lost problems with a bootable CD/DVD or USB flash drive.
on Nov 05, 2010 | Computers & Internet
Error message 1324. The path My Pictures contains an invalid character. Version 2.5.2.36 Can I remove? Can I update so my Quickbooks program can update? Need help please!
There are 3 possible reasons why you are getting this error message:
1. An invalid character in QuickBooks installation path.
2. An incorrect path setting in the Windows registry.
3.Insufficient hard drive space available to install the QuickBooks program.
To fix this problem, please do the following:
  1. Restart your computer, and reinstall QuickBooks.
  2. Confirm that at least 2.5 GB of disk space is available for installing QuickBooks (Quickbooks 2010 requires 1.5GB of disk space):
    1. Double-click the Computer (for Windows 7 or Vista) or My Computer (for Windows XP) icon on your Windows desktop.
    2. Note the amount of free space shown in the window next to the drive letter where QuickBooks is being installed:
      • If the amount of free space is less than 1 GB, free up disk space before installing QuickBooks or install QuickBooks on a different drive.
      • If the amount of free space is greater than 1 GB, proceed with step 2.
  3. Remove invalid characters from the QuickBooks installation path:
    1. Right-click the Windows Start button and select Explore.
    2. Navigate to the path shown in the error:
      • If there are non-alphanumeric characters in the name of any folder in the installation path, right-click the folder and select Rename to remove them, and then reinstall QuickBooks.
      • If there are only alphanumeric characters in the installation path, proceed with step 3.
  4. Create a new user in Windows to rewrite any Windows registry settings that may be causing the error and log in as that user to install QuickBooks.
Note: You must be logged in as a Windows administrator or as a member of the Administrator group to add a new user.
If this solution does not resolve the issue, you can read discussions and post messages and questions relating to your issue on the Intuit QuickBooks Community site for free, or you can contact a technical support agent for additional guidance. Fees may apply.
Nov 30, 2012 | NTI Backup Now EZ
It shows format error when the player is switched on. it dosent play any song
I am pretty sure this is the answer you are looking for. Let me know how it goes!!!
1. Format the player, in rockchip devices this haven't any risk, firmware is located in a different chip than data, so proceed formatting it (if you want you can WRITE DOWN your folders structure and SAVE the data you want to keep). No risk in this.
2. Create the folders structure you has. At least create a \MUSIC folder
3. Copy a small set of mp3 files and test them. Choose mp3 files you have played in your PC before.
Jan 22, 2011 | Sony NW-E002BC Walkman MP3 Player
How do I do a full recovery with the disc
Turn your computer on.
Insert the Disk and choose to enter BIOS, should be F2 but watch the screen to see the right function key.
Change the boot device order to: CD-ROM, HDD in that order.
Save changes and restart the computer.
The Recovery Disk would boot up and a wizard will guide you through the recovery process.
Follow the instructions to recover your computer.
Apr 03, 2010 | Acer Aspire 3050-1733 Notebook
System is running extremely slow, when I tried to do a factory restore I get an error code 0xf00000005. I ran hardware diagnostics on the hard drive memory cpu and mobo, tests run extremely slow. I tried...
After using Darik's boot and nuke (DBAN) your hard drive will be wiped clean with little chance of recovery. This also depends on how many passes you used for the disk wipe. More passes = less chance of recovery.
Restore from backup
You can restore backups previously created (as stated in the Create backup
section) from hard disk, CD or DVD.
1 Boot to Windows XP.
2 Press <Alt> + <F10> to open the Acer eRecovery Management utility.
3 Enter the password to proceed. The default password is six zeros.
4 In the Acer eRecovery Management window, select Recovery actions and
click Next.
5 Select the desired restore action and follow the onscreen instructions to
complete the restore process.
Jan 17, 2010 | Acer Aspire 5500 5570-2609 Laptop
Install the eRecovery drivers for aspire 5715Z
First ensure you have enabled D2D from Bios, If bios settings are OK then that message often comes up when E recovery partition is damaged.
Possible solutions are calling Acer and getting a disk to restore recovery partition (best way to proceed)
Or downloading and installing drivers from acer website
Here is recovery procedure from manual, to ensure you are doing corrrectly:
Create backup
You can create and save backup images to hard disk, CD or DVD.
2 Press Alt + F10 to open the Acer eRecovery Management utility.
4 In the Acer eRecovery Management window, select Recovery settings and
click Next.
5 In the Recovery settings window, select Backup snapshot image and
click Next.
6 Select the backup method.
a Use Backup to HDD to store the backup disk image on drive D:.
b Backup to optical device to store the backup image on CD or DVD.
7 After choosing the backup method, click Next.
Follow the instructions on screen to complete the process.
Restore from backup
click Next.
Here Acer download page: Acer Service & Support
May 05, 2009 | Computers & Internet
CSV file to AS/400
FTP is "line oriented." It has no concept of 'database record formats.' It transfers strings of characters with essentially no knowledge of 'fields' or 'columns' that make up 'records.' A 'record' to FTP is usually just whatever string of characters that is found between record delimiters.
Trying to FTP into a DB2 externally-described database file requires having strings of characters that are (1) laid out to match the receiving record format and (2) either are already converted to the proper CCSID and transferred as BINARY, or are ASCII characters that would result in conversions to all the right characters and transferred as ASCII.
Regardless of which alternative is chosen for "(2)", the handling of record format positions that would match up with packed-decimal or other non-character type fields would be very tricky.
That's where a somewhat 'standard' file format such as .CSV comes in.
However, you don't transfer the .CSV file directly over the top of the DB2 file. Instead, you transfer the .CSV file into a simple directory on your AS/400 and then use it as the source for a DB2 import function. On your AS/400, the import function is most often the CPYFRMIMPF command.
The import takes the .CSV file and handles all of the mappings for field positions and data types.
As such, the sequence becomes (1) FTP the .CSV file to the AS/400, and (2) run CPYFRMIMPF on the AS/400.
Note that the format of the .CSV file makes a difference. You need to ensure proper CCSID settings, proper quoting where necessary, proper record separators, etc. Make sure that you generate a .CSV that can be converted to the record format of the eventual target database file. Lots of possible details, but _far_ easier than trying to construct a matching DB2 record format on a different platform.
Sep 19, 2007 | Computers & Internet
Adobe PageMaker 7.0 for PC Logo
44 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
