Question about 1996 Ram 1500
1996 dodge 1500 intermittent headlight problem
Headlights go off and on intermittently
    New Friend:
  • 61 Answers
Most likely a loose wire, or a bad earth, check all earth wires including engine to chassis strap, car must have large earth to battery from chassis and engine, and/or an engine to chassis strap sometimes a relay needs replacing, does it happen the same on low as high beam? if it's ok on low then it's likely the relay probably near the fuses, if it's the same on low, then check the switch and plugs under dash and at light bulbs, light plugs often get corrosion as do the globe tags.
Posted on Apr 09, 2015
Why do my headlights go dim and high beams not stay on on my 1997 Dodge Ram 1500 sport then suddenly everything works again for a second?
your ground cable from the engine to the body is only making intermittent contact
make sure the cable is bolted to a clean (no paint) area on the body
Jan 26, 2016 | Dodge Cars & Trucks
Apr 09, 2015 | 1996 Ram 1500
Headlights intermittently turn on and off on a 1996 Chevy Blazer
I have a 95 blazer lt had same problem I went through complete wiring and found nothing took apart headlight switch found the copper diades corroded on entire switch I cleaned it with a small wire brush reistalled it and low and behold headlights work fine...
Nov 02, 2010 | 1996 Chevrolet Blazer
1996 DODGE DAKOTA pickup - headlights intermittently turn off then back on. can you help?
Your dimmer switch in the steering colum is going bad and needs to be replaced.
Feb 25, 2010 | 2003 Ford Taurus
Headlights go off after about 15 minutes, then come back on and off repeatadly.
check your headlight switch for being intermittent also check the head light ground wires on the front radiator support down to the lights
Jan 15, 2010 | 1991 Dodge Dakota
Headlights won't come on intermittently 2005 Dodge Caravan
Quite possibly the switch, Dodge minivans also have a front control module located under the hood, it attaches directly to the underhood fusebox, if a switch doesn't fix it I would look there.
Jun 24, 2009 | 2005 Dodge Caravan
1996 brake lights are out as well as headlight intermittant
For the brake lights check that no fuses are missing. Then check them all you should get a fuse tester. Go to the junk jard and get the cover if anything. For the headlights its common for moisture to get in the headlight bulb connector or harness and get corroded. Take the bulbs out and clean the connections with a wire brush or how ever you choose then put as much bulb grease as you want on the connection. This should take care it. Clean the inside of the harness too.
May 01, 2009 | 1996 Dodge Ram 3500 Club Cab
96 Dodge Ram 1500 wiring diagram for headlights.
Here's a link to a pdf file containing the headlight wiring diagram for your year model Dodge Ram 1500..
I can't help but notice that you say you've replaced the headlight relay? That's quite odd, because there is NO headlight relay on this vehicle- only a 40 amp fuse located in the power distribution box that sits behind the battery inside the engine bay.
The switch is notorious for burning out because there is NO RELAY on this vehicle, and there is a recall (#819) but this only affects 3500 models even though the headlight wiring is the same for 1500,2500 and 3500 model Rams.
Here are two more links that will help you troubleshoot your headlights problems.
HereInformation on Putting a Relay in the Wiring System
Mar 07, 2009 | 1996 Dodge Ram 1500 Club Cab
99 Dodge 1500 will not turn over
Have your Starter Solinoid Checked. Sounds a lot like the Culprit!
Jan 05, 2009 | 1994 Dodge Ram 2500
1996 Ram 1500 Logo
85 people viewed this question
Top Dodge Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Ruben Diaz
Colin Stickland
Colin Stickland
Are you a Dodge Vehicle Part and Accessory Expert? Answer questions, earn points and help others
