Question about Dishwashers
After completing a load, water slowly fills the bottom and will not drain.
Hose has been checked for clogs. Maybe a reservoir issue?
  • 973 Answers
Sounds like its syphoning back. Check the hose where its end is. If fitted to the "P" trap under the sink, check to see if the outlet hole is clear, also check for kinks in the hose etc.
Posted on Apr 09, 2015
I have had my hamilton beach brew station for a year. The past 2 weeks, the water put in the bottom reservoir does not empty completely into the coffee reservoir. It leaves about 8 oz in the bottom water...
On your machine there is maybe inside water reservoir a hose or tube that goes down to bottom, or suppose to go down to bottom, to **** up all water. Look inside and see if hose is going all the way to bottom, maybe it got hung up or crooked. Please let me know, glad to help, thanks mike ( mr bean man )
Jun 08, 2011 | Hamilton Beach BrewStation 47214 Coffee...
Dishwasher has water on the bottom after the cycle is completed. May not be draining properly.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Jan 24, 2011 | KitchenAid Dishwashers
My bosch SGS3062GB is not draining the water away - the water is stagnent in the bottom of the dishwasher. I ran the rinse cycle and it left about 2.5inches on water in the bottom of the...
Hi
Daniel
Dec 13, 2010 | Dishwashers
D/W does NOT drain. Water remains in bottom after cycle is completed
Hi
Oct 20, 2010 | Whirlpool 24 in. GU980SCG Built-in...
Washer drains then spins then fills again and drains but no spin
Try this, unplug washer for two minutes, plug back in, open and close lid seven times slowly, this will reset the computer and the electronic motor. Also on water level switch, make sure hose from switch to tub is not plugged, blow it out, gets clogged with soap.
Sep 09, 2009 | GE WBSR3140DW Top Load Washer
Water goes in reservoir, not thru hose to sump pump, leaking
blow some air thru the discharge line,, thats all it is the line is clogged, if the pan is filling with water, it is working but they do get clogged with dust and lint in the air,,
Jun 11, 2009 | Maytag M3DH30B2A Dehumidifier
No drain or spin cycle
Check the following to address the issue--
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 03, 2009 | Kenmore 22422 Top Load Washer
After water drains, it slowly comes back and fills in the drum over time.
Use the attached video to show you how to access the inside of the machine.Ignore the other parts other than access and re-assemly.
Apr 30, 2009 | Whirlpool GHW9150 Duet Washer
Code i30 has been activated - can i solve it my self?
on several of models the water reservoir , the plastic house on the left side must be cleaned, and the big hose in the bottom from reservoir to the center is filled with fat so the water fills to slowly and it runs over in the reservoir overflow hole and down in the bottom. this , little by little fills up the aqua stop sensor system. This causes water in the bottom of your machine and water block system to trig..No not on hose but a float in the base of machine. Tilt washer on side to drain water out of base allow to dry and should cure the fault 30 prob.
remember to disconnect from the mains electricity before doing this..also clean out any hoses connected to this...as the fats accumulate it clogs the lines and water slowly starts to fill in the bottom which activates the float and thereby triggering the fault .30code..this should save you a call out charge
.Hope this helps...please rate me...the Fang
Mar 27, 2009 | AEG 23 in. Favorit 86070Vi Built-In...
Washing machine
Make sure you are using HE soap, regular soap will produce sudsing issues in front loading machines.
F21 indicates a clogged pump or a long drain. Since you are also getting a SD error indicating a sudsing issue, the water level switch (pressure switch) may have failed. If you would like to make sure the pump is not clogged, you can clean/inspect the pump filter;
  • Remove the bottom access panel (three screws along the bottom).
  • There you will find access to the pump clean-out. (Large,white screw cap)
  • BE PREPARED TO CATCH SOME WATER.
  • CAREFULLY AND SLOWLY unscrew the pump clean-out, catching and discarding the water.
  • When the water flow finally stops, completely remove the clean-out filter.
  • Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris
Jun 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dishwashers Logo
52 people viewed this question
Top Dishwashers Experts
