Question about Konica Minolta Office Equipment & Supplies
How can I install toner
215
  • Konica Minolta Master
  • 6,161 Answers
What model machine are we talking about?
Posted on May 13, 2015
Konica minolta bizhub 215 giving error c2558
C2558
Abnormally high toner density detected TCR sensor board
- The T/C ratios detected by the TCR sensor board (TCRSB) are above the threshold for the detection of abnormally high T/C ratio for three successive times.
- The connector between MFPB to TCRSB is disconnected.
Error Codes Konica Minolta bizhub 215
Mar 07, 2015 | Konica Minolta Office Equipment & Supplies
How to reset error c2558 in bizhub 215
I have solution for this problem now. I tried alot to sought out this C2558 error in bizhub 215 & 195 but i got failed. But now i have a solution for this error after wasting my 2 days & searching data, youtube, website, manual, installation guide & more. Here is solution for this C2558 Error in Konica Minolta Bizhub 215 & 195 :-
Step-1. You need to change your developer(a packet pouch of developer), if you have not done yet. if you have already changed your developer then jump to step2. (Note - for installing & refilling devloper into the cartridge check other guide on youtube for how to re-fill developer.
Step-2. Be Carful there should be no Toner bottle. Don't get confused with tonner bottle & developer both are different. so remove tonner bottel from machine.
Step-3. switch Off & re - switch on the machine .
Step-4. when machine finish warming after that - Press UTILITY (tool) button. Then Enter service mode by pressing the buttons [Stop], [0] [0], [Stop], [0] [1]. (Note you should press this sequence in continous). The display shows the service mode.On the menu SERVICE WITH chioce press [OK].Use the buttons next to the display and select menu FUNCTION.
Step-5. Press [OK].
Step-6. Use the buttons next to the display and select the menu AUTO ADJUST TCR.
Step-7. Press [OK] and set ATDC. For about 2 min. the following message appears: TCR TCR AUTO ADJUST GAIN: ### where ### is the number
Step-8. Turn the machine off the main switch.
(finished if there is no error message , you can check print without tonner bottel. after that if there is no error message of c2258 then you can put bottle inside)
If the machine displays an error message C2557 or C2558, check whether you have correctly connected terminal, which is detached when removing the developer.
Installing the toner bottle :-
Step-1. Before using the toner Shake the toner bottle.
Step-2. Open the front door.
Step3. Insert the toner bottle into about halfway with the label (Tape) on top of the toner bottle, and then slowly Just remove the label from the toner bottle.
Step-4. Align the toner bottle to mark the arrow and push the bottle to the far end of the toner bottle.
-----GOOD LUCK-----
Aug 13, 2014 | Office Equipment & Supplies
Error code c2558 for konika bizhub 215
I have solution for this problem now. I tried alot to sought out this C2558 error in bizhub 215 & 195 but i got failed. But now i have a solution for this error after wasting my 2 days & searching data, youtube, website, manual, installation guide & more. Here is solution for this C2558 Error in Konica Minolta Bizhub 215 & 195 :- Step-1. You need to change your developer(a packet pouch of developer), if you have not done yet. if you have already changed your developer then jump to step2. (Note - for installing & refilling devloper into the cartridge check other guide on youtube for how to re-fill developer. Step-2. Be Carful there should be no Toner bottle. Don't get confused with tonner bottle & developer both are different. so remove tonner bottel from machine. Step-3. switch Off & re - switch on the machine . Step-4. when machine finish warming after that - Press UTILITY (tool) button. Then Enter service mode by pressing the buttons [Stop], [0] [0], [Stop], [0] [1]. (Note you should press this sequence in continous). The display shows the service mode.On the menu SERVICE WITH chioce press [OK].Use the buttons next to the display and select menu FUNCTION. Step-5. Press [OK]. Step-6. Use the buttons next to the display and select the menu AUTO ADJUST TCR. Step-7. Press [OK] and set ATDC. For about 2 min. the following message appears: TCR TCR AUTO ADJUST GAIN: ### where ### is the number Step-8. Turn the machine off the main switch. (finished if there is no error message , you can check print without tonner bottel. after that if there is no error message of c2258 then you can put bottle inside) If the machine displays an error message C2557 or C2558, check whether you have correctly connected terminal, which is detached when removing the developer. Installing the toner bottle :- Step-1. Before using the toner Shake the toner bottle. Step-2. Open the front door. Step3. Insert the toner bottle into about halfway with the label (Tape) on top of the toner bottle, and then slowly Just remove the label from the toner bottle. Step-4. Align the toner bottle to mark the arrow and push the bottle to the far end of the toner bottle. -----GOOD LUCK-----
Jan 15, 2013 | Konica Minolta bizhub C450P Laser Printer
Minolta bizhub 164 error code C2558..how can I solve
Step-5. Press [OK].
THATS IT - YOU ARE DONE - FINISHED
DONE - ERROR REMOVED
-----GOOD LUCK-----
Mar 06, 2012 | Office Equipment & Supplies
I have konica #1212 and i have a problem of making clear coppies \r\nI fill with toner and still doing the same thing. My phone #215-784-0330 Thank you
if the toner ran out and you put new toner it is a good idea to run an f8 you can leave the toner in. also are the optics all clean mirrors ect
Jan 20, 2011 | Konica Minolta Office Equipment & Supplies
What is a service code c2558 mean on my copier?
C2558: Abnormally high toner density detected black TCR sensor
Reinstall imaging unit
Reinstall toner cartridge
Change imaging unit/K
Change PRCB
Sep 28, 2010 | Konica Minolta Bizhub c203 Copier
J3 error On Xerox WorkCentre Pro - 215
A J3 means the toner cartridge is not compatible. That is the what the J3 message means.
Make sure the correct cartridge has been installed. For example, a Pro16 Toner Cartridge looks very similar and will fit in the machine, but it will display a J3 fault. Install a known correct Toner Cartridge if you suspect the cartridge in the machine is the problem. If the wrong Toner Cartridge has been used, the correct cartridge needs to be ordered and installed in the machine
It is possible the chip on the back of the cartridge is bad. Have you tried reseating the cartridge? Maybe it is just loose.
Dec 19, 2008 | Xerox WorkCentre PRO-215 All-In-One Laser...
Toner
Open The front cover.
down the right hand side small gray or blue handle.
open the toner box.
insert a new toner.
end
Oct 09, 2008 | Canon imageRUNNER 400S Copier
26 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
