Question about Roku Televison & Video
Can't get the hdmi input to work?
Want to use roku on it
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 70 Answers
Try another HDMI cable.
Posted on Jun 04, 2015
How do I switch back to my regular dish service with roku
Usually it is a matter of changing the source or input on your TV from the HDMI or Video Input Port Used by Your type of ROKU to the HDMI or Input Port Used by Your Dish Converter box ( If You can't find them by scanning Your TV's Input ports You can follow the cables and see were they go if you can get to them)
May 18, 2016 | Roku Streaming Stick
How do I hook up a roku stick?
I am guessing you mean the HDMI connector type Roku?
You simply plug the Roku into a free HDMI port on your TV, then switch your TV input to the proper HDMI selection, then start your setup. I believe this also needs to be plugged into the wall for power as HDMI does not supply power.
If you have an iPhone or other similar devices, you can download the ROKU app to control the device.
The link I provided may help. Setup help
Nov 16, 2015 | Roku Televison & Video
Roku stick dosent do anything. ...? Plugged into hdmi slot on tv and also plugged in power cord to roku and nothing pops up on my tv...? Iv tryed to reset but dose nothing. ... help???
Did you change the TV input setting on your TV to the correct HDMI input? Most Televisions will take a few seconds to scan the input before displaying any image. Most newer televisions have multiple HDMI inputs, and you might need to select each one, wait several seconds to see if there's a signal, and then move on to the next input, until you find which HDMI input has the Roku start screen signal.
Dec 09, 2014 | Televison & Video
How do i get my roku to work on sharp aquos?
The Roku is an external media player designed to function with all TVs. Depending on the model of Roku you have you need to conext the video out whether it be RCA (the yellow red whit cables) or HDMI into the corresponding input on your sharp TV then with your remote or the input button located on the side of the TV you need to change the TVs input to the the same input you plugged your Roku into.
Jul 22, 2014 | Sharp Aquos Televison & Video
Www roku com link
This sounds like a basic setup, so correct me if I made any wrong assumptions.
You have 2 "output" devices: a Roku and a cable box. Both have HDMI outputs.
You have 1 "input" device (your TV) that has 2 HDMI inputs available.
So, you need one HDMI cable to connect your cable box to your TV. Remember what HDMI port it's connected to - the back of your TV probably says "HDMI 1" and "HDMI 2" or similar. That's the "input name" of your TV.
Connect your Roku to your TV with another HDMI cable.
Now turn on your TV and use the remote to change between the inputs. Most remotes have a button that says INPUT or SOURCE (or sometimes a dumb little icon with no writing). If you press that it should change inputs. Usually, each time you push the button will cycle to the next input, so sometimes you have to hit it a bunch of times until the on screen menu shows the input you want. Most TVs will automatically switch to the selected input after a few seconds, so you don't have to push any buttons on the remote to tell the TV to change inputs.
If "at the same time", you meant actually watching both Roku movies and your cable at the same time, you are talking about a TV feature usually called "picture in picture". That should be possible, but will depend very much on your TV. I'd suggest checking your TV manual, or calling the company's 1-800 number and asking them to talk you through it.
Jan 07, 2014 | Computers & Internet
WE JUST BOUGHT ROKU , HOOKED IT UP , CAN'T GET ANYTHING ELSE TO COME UP
You must match the TV's input connections and the Roku output on your remote. This means if the Roku's output is connected to your TV's "HDMI 2" (or A/V 2, etc.), you must be able to select HDMI 2 (or A/V 2, etc) on the TV - either with your remote or pressing a button on the TV itself.
Sometimes, the TV will skip over unused inputs when it was first set up. This is done to reduce the number of button presses to go from say "HDMI 1" to "HDMI 4" by programming OUT the HDMI 2 & HDMI 3 choices.
You'll need to program IN the input that your TV uses to connect the Roku if it isn't already available. You MUST connect cables properly if not using HDMI. RGB is Red-Green-Blue and must be connected to RGB jacks at the Roku and TV for a picture and the the White & Red (left and right) audio must connect the the corresponding Red / White audio jacks - or it will provide strange results.
Make sure the power plug is connected to an outlet that is ON and connected to the power jack on the Roku box itself. Unless you have a defective Roku box or TV, it SHOULD work. You can try using a different HDMI or A/V jacks on the TV to determine if it is the TV jacks or not.
Sep 10, 2013 | Televison & Video
I can't get the video to work so I can use my roku. How can I watch roku?
Which way did you connect the roku? HDMI or with the yellow,red and white RCA cable? If you used the HDMI cable, look on the TV to see what number is on the input port. Select that number when you use the input button on the tv or the remote. Same goes for the RCA cables. Each input has a number next to it.
Sep 01, 2013 | Insignia NS-RC03A-13 Remote Control...
TV doesn't recognize HDMI with Roku
The Roku is the problem, not the TV. You need to go to the Roku site and request download information to synch the Roku to an HDMI input.
Jan 13, 2013 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Sa-dx1040 dvd optical input works, tv and cd do not.
You have to manually select digital input on the receiver.
Jun 11, 2008 | Technics SA-DX1040 Receiver
Televison & Video Logo
81 people viewed this question
Top Roku Televison & Video Experts
David Payne
David Payne
ray gallant
tomar33
Are you a Roku Televison and Video Expert? Answer questions, earn points and help others
