When I turn on my projector it almost works then shuts off.
When I turn on my projector, the fan comes on and the lamp comes on a little bit (if you but your hand close, you can see some light coming onto it). The blue light around the power button flashes like it powering up for about 10 seconds. Then the entire bank of lights around the buttons both red and blue flashes once and it shuts down. The fan keeps going for about 10-15 seconds and then it shuts down completely. We have replaced the lamp and tried different outlets.
smeago1
  • 136 Answers
SOURCE: No light come on from the projector
Thats the projector telling you that you need to replace the lamp. Lamps usually lasts for about 2000 hours so if you had it for a while you may need to replace it.
www.froogle.com and enter your make and model or go to www.projectorcentral.com and find a few retailers in the US that sells lamps.
good luck
smeags
Posted on Jan 02, 2008
  • 9 Answers
SOURCE: Lamp
red light indicates lamp is expired. even though you get temporary light, the lamp is shot. Try BULBMAN.COM for a new lamp.
Posted on Jan 22, 2008
SOURCE: Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Posted on Feb 20, 2008
SOURCE: dell 2300mp projector
check this out...
http://www.ihatedell.net/forum/phpBB2/viewtopic,p,36316.html
have almost the same problem. lamp light turned on-->replaced the bulb, now when you turn it on tryies to boot and then the lamp light is on again (but the bulb is brand new).... and no light at all coming out of thing... I guess dell just don't know how to built projectors right way.... and theirs tech support guys are.... they just don't know about projectors more then manual
Posted on Jun 27, 2008
dhiman
  • 115 Answers
SOURCE: flashing green light
1. Pls check and inspect the Lamp unit.
2. If Lamp unit is okay, Then the Problem is with
either with Ballast unit or the DMD Module.
Regards
Viren
Posted on Jul 26, 2008
Bulb works, projector turns on, though it immediately shut
check the fan if it works as will as clean the filter.
Aug 18, 2012 | Epson EX31 Projector
Optoma MovieTime: The Lamp that Won't stay on
its definitly a cooling issue.the temp sensor is working because it shuts the unit down.when a lamp goes it goes just like a light bulb.you can open up the unit and locate the fan take it out and go to a radio shack a match it up to a universal fan.
Aug 22, 2007 | Optoma MovieTime DV10 Multimedia Projector
Epson Powerlite 830p lamp light comes on and turns off projector with new bulb.
Clean the fans and filters. Check the lamp door switch is making contact.
Jan 27, 2018 | Epson PowerLite 830p Multimedia Projector
NEC VT595 Projector - Status light blinks red constantly
We had this same problem. In our case it turned out that a little bit of plastic broke off of a tab on the inside of the plastic lamp cover. Without that piece it was not pressing against the sensor that tells the projector that the lamp cover is closed. Without that, it doesn't start. We got it working again by drilling a little hole and sticking a screw through that spot to replace the missing plastic, but I'd rather replace the cover if I could. Really dumb that a little piece of plastic can mess up thousands of dollars worth of equipment (Smartboard 2000i).
May 26, 2010 | NEC VT595 LCD Projector
Optoma EP716 turns on but no picture displays
Don't ever just unplug the power cord while it is on. The bulb needs to cool down with the fan still on.
Did you ever connect a source?
Sep 17, 2008 | Optoma EP716 Multimedia Projector
Christie Roadrunner 100
check to see if the fans are moving. if not, replace the fans. if the fans don't come up, the projector shuts down to protect the circuitry and the lamp. if the fans are fine, most likely the power supply/ballast is not producing enough power to keep the lamp lit and shuts down.
Aug 14, 2008 | Christie LX45 Multimedia Projector
Projector keeps turning off
When i turn the projector on it only comes on four about a minute until the temp lights go amber and it turns off, the fan is working but the air coming out is a little warm. what if anything is making my projector overheat, or is it not heating at all?
Aug 07, 2008 | Dell 2300MP Multimedia Projector
Projector
A couple of things...
If the fan is not working, the lamp will not fire. If you have the owner's manual, it should indicate what the flashing lights mean. Check to make sure that the panels are seated properly. When you replaced the lamp, the outer cover was removed. If that is not seated back 100%, the unit will not work. There are a number of safety "checks" built into the unit to prevent damage and possibly fire as the lamps get really hot.
Check the items above and let us know your progress.
Dan
Jun 19, 2008 | Dell 2300MP Multimedia Projector
Projector shuts off after about 45 minutes
Just a long shot, but...
I have an epson 9000i that did the same thing. Turns out that unit has a small fan (I think 60mm) right next to the power supply to keep it cool, in addition to the large fan that exhausts past the lamp. The fan runs non-stop as long as the unit is powered-up for two reasons I can think of - keep the power supply a little cooler, and the lamp a little warmer so there's not such a temp difference when it powers-up. Long story short, that fan had died. I replaced it with an aftermarket 60mm fan and it's been working fine ever since. Hope this helps.
Bob
Jun 03, 2008 | Epson PowerLite 5550C Multimedia Projector
Toshiba TLP671 - lamp red LED
It is problem with temperature. So please check with filter and clean it. Other wise check any of the fans are not functioning properly. So check the same and replace
Nov 14, 2007 | Toshiba TLP 261 Multimedia Projector
90 people viewed this question
k24674
jasbo
jasbo
