Question about Garden
The LH drive stopped working and got really stiff. What are some of the possible things wrong?
  • 2,760 Answers
Not sure why this is in leaf blower topic line ? but what I think you have there is a zero turn mower ? and one side is not working , im further gonna guess that it's a snapper or some clone of a snapper due to them using two separate hydraulic pumps for each side (how this problem can happen) things to look for on non working side , OIL level in reserve oil tank for that side, broken lever linkages to oil valve on top of pump , pump not turning on that side (wouldn't be the first hex key id ever seen drop out )
Posted on May 29, 2015
My saturn runs wide open when i go to stop
wow wide open throttle thats strange but its one of two things the throttle body linkage is really stiff and would need to be rebuilt or the cable that runs to the pedal is fraying and is getting stuck. it could be other things but with out more information its hard to diagnos
Apr 04, 2013 | 1999 Saturn SL
Just put kingpin and bushings in on 3500hd chevy steering is so stiff you cant hardly drive it.is it possible we could have put knuckles on upside down or on the wrong side?
No, But you might have put the bearing in the wrong spot. Or did you have to drive the pins in the bushings? You have to hone the new bushings after you press them into the knuckles so that the new pins fit right.
Oct 13, 2010 | Chevrolet C3500 Cars & Trucks
Turns on and makes noise but drum dosent move what is wrong . the drum wont move to wash or anything.
Check that the drum is free to move - by rotaiing it by hand. If it rotates very freely - it is likely you need a new drive belt. If the drum is very stiff - and won't move, it is possibly a faulty rear bearing. If both these checks are not the problem, it could be a motor or control board fault. It can be a cheap set of brushes needed for the motor - or a new control board.
It really needs investigation to identify which part is needed before replaements are ordered.
Turn off and unplug before investigating further.
Sep 30, 2009 | Washing Machines
Air conditioner, fuel gauge, and temp gauge all stopped working at the same time
Three possibilities;
All related to blown fuses,
1- Fuse blown in the engine compartment LH.
2- Fuse blown in the cabin forward LH below the dashboard (below your legs left hand).
3- Fuse blown in the harness (wire bundles) below the dashboard very easy to reach with your hands “just look underneath steering wheel ".
U said " The air conditioner blows, but the air is not cold.
" Yes only the fan working which might receiving power independent all from those other mentioned things.
If all fuses OK. Then look for broken wires.
Regards;
MAR
Jun 03, 2009 | 2003 Saturn L-Series
I have the Lite On DVDRW LH-20A1H it shows the DVDs are full and will not record on them will play a dvd that I have previously recorded but shows all DVDs as full works fine with CDs. Recently had to...
Try to isolate the problem by using the drive with another computer. If its showing the same problem then your drive is probably busted. Also, try to change data sables, see if that will help. Have a good one.
May 14, 2009 | Lite On LH-20A1H DVD RW Dual Layer Burner
Front tires balding from middle to the inside, and the steering gets real stiff when trying to turn hard. there also is some noise coming from the front end! please help!!
sounds like you have a front suspension issue, there are alot of parts it could be, the first thing I would do is jack the front up to get tires off the ground and shake all the suspension parts really good, they should all be stiff, another option is take it to a shop that does alignments, they will quote you what is wrong and what will fix it :)
Jul 21, 2008 | 1997 Oldsmobile Cutlass
Amplifier stop working
this problemis your amp is dead powerflux you need the asistance techinic
May 27, 2007 | Crunch BlackMaxx BLX2000D Car Audio...
Garden Logo
128 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
