Question about Yamaha Audio Players & Recorders
Power outage so Yamaha htr3064 won't turn on. is there a reset procedure for this receiver?
  • 960 Answers
Unplug the unit for 30 minutes and try again. It may reset. If you had a power cut, there may have been a surge just before the power went off and electrically damaged something in the unit.
Posted on Apr 09, 2015
What does a Red X with a 6 underneath it mean?
Try soft reset by unplugging power cord on all components (tv, receiver, all source, router and modem) for a few minutes then reconnect.
Mar 27, 2016 | Yamaha RX-V375
I have a Yamaha htr-3065 HDMI receiver that won't turn on after we experienced a power outage. When I plug the unit in I get a buzz sound from transformer but still won't come on. The fuse and power supply...
If you have any electronics experience you should check the diodes or the bridge rectifier in the power circuit. Look for burned components or bulged capacitors.!!!Always unplug the unit and wait a few minutes before attempting any procedure!! I have found that capacitors usually fail due to voltage spikes which can happen when power is reinstated after an outage. Always use surge protectors on electronic devices. They have a component called an MOV that will absorb voltage spikes and save your equipment.
Oct 03, 2014 | Audio Players & Recorders
Yamaha RX-A1010 will not turn on anymore after a power outage
1st I would check to make sure that the outlet has power by using something other than your receiver to test it. Then turn your receiver to the backside and see if there is a reset breaker on the backside. Also make sure your receiver is plug directly into the outlet. If it still fails you might have a blown a fuse some receivers may have a barrel type of fuse holder that you can turn the cap till it spins off and you can replace the fuse but be sure to match it with the same exact kind with the numbers that the fuse is labeled with. But if your receiver doesn't have any type of fuse holder then you might have to open its case. If you think you could handle the next step then continue reading . Once you unplug the receiver and removed all the screws which hold the case usually are under and on the backside where you would connect all your inputs. Looking inside your gonna be looking for a small tube glass with silver chrome caps at the ends . If you know what they are you can test them with a volt meter or if you can visually see that the string or flat metal looking bar inside fuse broken. If it is than replace with the same info as I said before in my answer. If it's still looks good then you can test for further area like the switch point but before you do that please know your way around a circuit board because you can seriously get hurt otherwise bring it in to a service center. Good luck
Aug 04, 2014 | Yamaha RX-A1010
Yamaha RX-V375 display internal error after power outage and everything works except radio tuning.
something wiped out the memory and the region code needs to be reset. I would suggest taking it into a shop that knows how to do this as I'm not sure that Yamaha wants the procedure sent out to the general public
Apr 09, 2014 | Yamaha Audio Players & Recorders
Yamaha rx-v767 factory reset
HI
Procedure for resetting the unit
To reset to the original factory settings
select this sub-menu and
press the "MAIN ZONE "(power) key to turn off the power. Any protection history also will be initialized at the same time.
hope this helps
Kind regards
M.Mathis
Jun 22, 2012 | Yamaha Audio Players & Recorders
Yamaha RX V671 will not turn on anymore after a power outage
The protection mode has activated.
Reset the protection mode as follows and see what happens.
Connect power cord to mains and wait 5 seconds or so. While holding down "info" and "tone control" buttons, press "main zone" power button briefly and release, but keep "info" and "tone control" buttons pressed for at least 3 more seconds. The unit should power up. Assuming the reason for the protection has passed or been fixed, the unit can now be turned off and then back on with the "main zone" power button to restore normal operation mode.
If the protector activates again, the fault is still present and the unit needs to be repaired, ideally by a Yamaha authorised repairer.
There are dangerous voltages present in high power amps and a lot of grunt in terms of stored energy - best left to trained technicians.
Apr 10, 2012 | Yamaha Audio Players & Recorders
How do I reset my yamaha receiver htr5730
http://www.retrevo.com/support/Yamaha-HTR-5730-Receivers-manual/id/1075bh230/t/2/
Page 52
1 Hold down STEREO on the Front Panel
"Factory Preset" appears on the front panel
2 Press STEREO to select the desired setting.
'Reset' To reset to factory presets
'Cancel' to cancel without making changes
3 Press STANDBY/ON to confirm your selection
Jan 15, 2011 | Yamaha HTR-5730 Receiver
Yamaha HTR-5990 Receiver
I JUST EXPERIENCED THE SAME SITUATION HERE IS THE SOULTION YAMAHA SENT ME TO RESET THE SYSTEM HTR-5990 YAMAHA HTR-5990 FACTORY PRESET PROCEDURES All models require the STANDBY/ON button to be turned OFF to start the reset process. NOTE: The remote control cannot be used during the reset procedure. All necessary buttons to complete the reset process are located on the front panel of the receiver. This procedure is not intended to correct intermittent shut-off symptoms or problems MODEL: HTR-5990 (U.S.A. model/s) (BEFORE YOU CONTINUE, PLEASE READ THE ABOVE NOTES!) 1. Before you start this procedure, locate the MASTER ON/OFF button and the STRAIGHT/EFFECT button on the Front Panel of the unit. 2. MAKE SURE THAT YOUR RECEIVER’S MASTER ON/OFF HAS BEEN TURNED OFF. 3. With the Right Hand, press and hold the STRAIGHT/EFFECT button. With the Left Hand, press the MASTER ON/OFF button and HOLD both buttons for no more than “3” SECONDS, AT THE SAME TIME. SP IMP. * 8 MIN. will appear on the display, which indicates you are in the Diagnostics Mode. 4. Rotate the PROGRAM KNOB to the right (ONCE) until the display reads PRESET *CANCEL. 5. Press the STRAIGHT/EFFECT button (ONCE) and the display will change to PRESET RESET. 6. Turn the unit off by pressing the MASTER ON/OFF button. 7. Wait 5 seconds, then turn the unit on by pressing the MASTER ON/OFF button. You have now reset your component to the factory settings. NOTE: Yamaha receivers don’t have to be reset during normal operation. It is not recommended that you reset the receiver unless a setting has been changed that you are not aware of, or the receiver is not operating properly. The reset procedure will clear an incorrect setting that might be causing abnormal operation. GOOD LUCK
May 01, 2007 | Yamaha HTR-5990 Receiver
239 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
