Question about Bernina Artista 180
My thread is caught in the upper tension and won't pull out up or down. How do I remove it?
    Problem Solver:
  • 13 Answers
What I am getting from your question is that you have thread caught in the upper tension assembly? If this is the case I would remove the top plastic lid on the machine. It's easy to remove as it is only held on by 2 torx head screws. Also remove the plastic end cap on the machine. Just one torx head screw holds on the end cap cover. Now with these two covers removed you can see the entire upper thread path and pull out or remove the thread from where it is caught. On a 180 it usually gets cought at the end of the take up arm where the thread passes through. Use some good tweezers to remove any cought thread. Also turn the hand wheel and inspect the moving parts for any thread that has broken off and gotten wrapped up in the moving parts.
Posted on Apr 09, 2015
Testimonial: "After reading your instructions, I was brave enough to take off the lid and side cap. I was able to lift out the thread. Thank you."
2 Suggested Answers
SOURCE: Thread loops in top of embroidery
If it was an upper tension problem your loops would be beneith the fabric. Since the loops are on top this tells me the lower tension is too loose. There is a small screw on your bobbincase that you need to turn clockwise to adjust it. Do the adjustment little by little until its good. I would do it like a clock. First turn the screw to one o'clock. Still looping? Go to 2 o'clock etc.
If this doesn't help you, a clean opikl, and adjust by your local dealership could be anywhere from 50.00 to 90.00.
Good luck
Posted on Nov 06, 2007
The tension on my Juki TL98E will not stay set. the top thread is really loose underneath, but if I tighten the top tension, it skipps stitches and the lower thread is not caught in the stitch.
Your top tension may actually be too tight! Try loosening it a bit instead. And check that the bobbin is correctly threaded and your needle in good condition.
Nov 25, 2015 | Juki Sewing Machines
Why is my bobbin thread tangling and binding up under the plate?
Check tension levels of both upper tension unit and bobbin case.
With machine threaded, pull the bobbin thread. There should be some tension/resistence. Lower the presser foot. Pull on the top thread. Again you should feel some tension/resistence. If you don't feel any, raise presser foot and test upper thread again. If no difference, it is an issue with the upper tension disks. Brush out any loose threads that might have gotten caught in the upper tension disks which is causing the disks not to close. If there is no difference with presser foot up or down and no threads in tension unit, the tension unit will probably need to be replaced. You should have the machine serviced at the local authorized husqvarna viking dealer. You can find the nearest dealer at the husqvarna viking website - http://www.husqvarnaviking.com/us
Apr 27, 2014 | Husqvarna Sewing Machines
I have a Bernina Deco 330, I am having issues with the Bobbin thread coming through on top of design. It is also tieing the knot in top of the fabric. The design will be flipped, the smooth side on back of...
A few things to check. Is the upper thread caught? You can test the upper tension, that could be pulling up the bobbin thread, by putting a size 80 needle in the machine. Put the presser foot down and pull on the upper thread it should bend the needle about an 1/8 inch when the tension is at 5. Also check the threading is done correctly and not catching on a thread guide.
Sep 02, 2013 | Sewing Machines
Top tension has to be turned all the way down to get good stitch, then thread gets caught in bobbin and lower hooping on thread..
Grab some scrap fabric of the same type you'll be sewing. Tighten your top tension and test sew until you see until you see the top thread of a seam go like a straight line and the bobbin thread loops on top of the seam. Then back off of the top tension until those loops disappear.
If you never see it the top thread go like a straight line... your top tension needs to be cleaned... and make sure you have the pressure foot UP when you thread the upper thread.
Aug 03, 2012 | Sewing Machines
I have a Brother sewing machine and whenever I try to pick up the bottom thread (or when I try to sew), the upper thread gets caught around the bobbin case causing a huge, knotted mess. It's just all...
Check your top tension dial setting is on 5, as this sounds like the thread is not in tension fully so is looping up around the rotary hook and not being held back by the tension device. Is the pressure foot lowered (this turns the tension on) fully and is the thread through the tension discs correctly. Lower the pressure foot and pull the top thread from below the tension dial, it should feel firm to pull, if it comes out easy, its not undertension, device could be faulty and machine will need to be serviced.
Also, check that the bobbin case is fully inserted into the rotary hook in the correct position, bobbin is in and rotating the right way and thread is into the tension spring fully.
If you have the manual pull it out, and carefully check the threading up instructions and follow on your machine - it is probably one of these things causing the jamming.
May 23, 2011 | Brother LS-2125 Mechanical Sewing Machine
When I am sewing, somehow the material gets caught in the bobbin area. The thread becomes entangled there and pulls the material down with it. How can I fix this?
Make sure when you thread the machine, that you have the presser foot (the foot that rides on the fabric) in the 'up' position.Also make sure you get the thread down between the discs of the upper tension. Set the tension on '4'. Usually when you get thread bunching up below it's caused by improper threading of the upper thread.
Hope this helps!
Bob
Jan 31, 2011 | Euro-Pro Sewing Machines
The bottom thread gets all knotted up when I sew... everything locks up and there is a mess of thread on the underside of what I'm trying to sew. help?
The tension in the top thread is controlled by a dial, and the tension in the bottom thread is controlled by a small screw on a spring on the bobbin. The tensions are supposed to be exactly equal in order to make the stitch perfectly in the middle of the cloth. Uneven tension will pull the stitch up or down from there. You can tug on each thread to feel how much tension there is. Often the bottom will get too much tension by just inserting the bobbin upside down. Leave the bobbin door open, and watch the operation. The top thread is pulled down around the bobbin. See if it is getting caught on anything?
Dec 18, 2009 | Singer 3116 Simple
Machine locking up after first stitch
Well I'm assuming this is not a 905 Serger. Here are some tips for bobbin problems on a Viking sewing machine:
Check that it is threaded correctly (both top and bottom) making sure that the upper thread is in the takeup lever. Watch the needle as you slowly turn the handwheel counter clockwise (toward you) and the needle point touches the fabric (make sure presser foot is down). Is the thread still relatively taunt? If it is loose, the upper thread tension unit does not have enough tension. Check the areas where the thread goes and make sure you remove any loose threads or fluff which could be inhibiting the tension discs from closing over the thread. If the tension unit still is not tightening enough, the tension unit may need to be replaced or the circuit board replaced. If everything is ok in the upper thread area, now look at the bobbin area. With no fabric, watch as the needle enters the bobbin area. Does it go down and the upper thread catch the bobbin thread and pulls it to the surface? Check for anything preventing the bobbin thread from being pulled up to the surface through the needle plate. If you have still not been able to resolve the problem suggest you take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Jun 29, 2009 | Husqvarna Huskylock Computerized 905
Thread is gettting caught in bobbin area of my esante ese2. HElp needed!!
It could be that your bobbin case popped out of position. Try removing and resetting it.
It could be that you have no upper tension, either lint in the tension discs or upper thread is mis-threaded and did not get down into the tension discs (make sure lifter lever is up when threading so the discs are open).
good luck!
Jan 31, 2009 | Baby Lock Esante
Sewing Machines Logo
124 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
