Water not sucking in to do a load of washing - Washing Machines
    Master:
  • 443 Answers
Water sensors may be bad also
Posted on Apr 09, 2015
  • 38 Answers
Turn off water supply have towel handy for spill ,slight, unscrew hose, like garden hose, may need adj. pliers, remove hose check./ clean filter in hose reconnect turn on water test. hot water may also need to do same turn off water behind mach. repeat as for cold.
Washing machine will not drain
Check the pump. It may be disintegrating and heading for failure.
May 27, 2016 | LG Washing Machines
Your machine does not suck water from the main tap. If the water supply is turned on, water is supplied under pressure to the fill valve which must open electrically to fill the machine. Your water supply may be turned off or the fill valve may be failing to operate
Jun 27, 2013 | Kenmore 22942 Top Load Washer
Water stay in drum took drain hose off water still in drum
Probably sucked up a small sock or clothes in the water pump.
Apr 22, 2010 | Maytag Neptune MAH5500B Front Load Washer
Indesit washing machine model wn 665 ss not sucking water
this sounds like you have a blocked pump or broken pump this video might help
You-Tube video "19uprIcreD8" placeholder (do not delete)
You will find this link helpful
We have a Free full video library on appliance repair video’s
Jan 13, 2010 | Indesit WA 125 Front Load Washer
Lots of pressure with hot water sucking away when you load the detergent, but very little pressure with cold water
have you pulled off the hoses and check for deposits. other wise the fill valve maybe sticking.
Nov 01, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Water isnt sucking out
code 21 means
Long Drain
if the drain time exceed eight minutes,"F 21" will be displayed, the water valve will turn off and the pump will stop running.
Press PAUSE/CANCEL to drain the machine.
The display will cleared and the machine will turne off after a maximun of eight minuts.
Was this helpful?
May 11, 2009 | Kenmore HE2 Plus Front Load Washer
Washing machine leaking
is the drain hose sucking water backin at the end of the cycle,otherwise turn the one tap off at a time and see if water gets in.but its normal to have water in the fill nozzle which can run in,but not normally that much.
Mar 03, 2008 | Washing Machines
Doesn't suck up the soap from the tray while washing
Try to open your water tap to full or check the filter in the inlet valve or hose. There seems to be a problem with the water pressure entering the machine.
Oct 30, 2007 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Frustrated with washer
sounds like the water level sensor is faulty on the 'high level' setting. If you disconnect the sensor & blow & suck up the small pipe, you should hear 2, or maybe 3 clicks as the internal switces operate, if you dont hear the clicks, this could be the problem
Oct 24, 2007 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
