I getting static comeing through the speakers even at low volumes
  • 3 Answers
90% bad connections, wiggle turn connections even bad ground on power will cause, I found swiver or turn nob volume dials go first and do this also.
Posted on Apr 26, 2015
  • Dave Sattler
    Dave Sattler Apr 26, 2015
SOURCE: popping & hardly any volume
i had the first problem and you can probably fix it by turning the volume knob all the way up and down about 20 times. it worked for me. supposedly the potentiometers in the z-5300 get dirty or worn out, somehow this might fix it. for the second problem maybe try plugging it into the laptop and unplugging it again seeing if it goes back to normal?maybe its a problem with the amp?
Posted on Aug 14, 2008
SOURCE: Quiet, low quality sound from one speaker, static from both
Take your fist and cram it up your ***.
Posted on Feb 16, 2009
MPetro302
  • 298 Answers
SOURCE: Loud static sound comes from computer speakers and the phone
Uninstall and reinstall new drivers for your sound card from the soundcard manufactures website or if its onboards from the PC makers site. If your using vista their has been widespread issue's related to the static "bug" and numerous solutions that sometimes work or do not work have been tried. ex; if is a soundblaster card try Creative.com's forums.
Posted on Apr 16, 2009
sarasvatas
  • 329 Answers
SOURCE: There is a loud hum when volume is on low to high
go to control panel
sound and audio devices
voice
under voice recording clk volume and mute the mic phone...........
or
some how your mic is conflicting with speakers. Keep your mic away from your speakers..
Do reply if this woks
Posted on Oct 03, 2009
Actaviosan
  • 100 Answers
SOURCE: I have the Bose Companion 3 Series II speakers. I
I have had totally the same problem before, and I have discovered that it is actually because of the electric current running through the speakers when the volume is low or muted.
I am afraid to tell you that the only solution to this problem is to raise the volume, as it is not a malfunction in the speakers but in the electric current running through them.
Good luck.
Posted on Dec 16, 2010
Testimonial: "Thank you for the prompt response! I noticed that the static goes away completely at a higher volume. Thanks again."
I'm getting static comeing through my speakers on my Bose gs II cinamate at hi and low volumes. All help is appreciated
I personally would test them out of a TV and maybe even your phone to see if the problem is universal between different devices. If it isn't, then I probably would try different ports on your pc to test its not a fault with that specific port.
Apr 09, 2015 | Bose Audio Players & Recorders
Low volume nsm firebird jukebox
restore your Phone Settings
Aug 08, 2012 | Cell Phones
I have the Bose Companion 3 Series II speakers. I ordered them through the Bose website. However, I continuously hear static. Mute, low volume, with music, etc. I hear static noise. The only way to...
Good luck.
Dec 16, 2010 | Bose Companion 3 Series II Multimedia...
I am getting static out of all speakers in my Denon AVR-682 Home Theater system even at low volume. Connections and speakers are all good. Where do I start to look internally for a fix?
Static could mean a few things.
Magnets on or near (tube TV's) the system could disrupt the signal.
Try plugging the speakers in one at a time with music going to the AUX in. Run through all your settings to make sure that nothing is abnormal.
If it's plugged into a powerstrip, try plugging it into your wall outlet.
201-762-6500 is their main number.
Nov 17, 2009 | Denon AVR-682 Receiver
go to control panel
voice
or
Oct 03, 2009 | Bose Companion II Computer Speakers
Volume low on all four speakers, some static (amp or head unit problem)
I would check the amp first, especially if you have very low sound on the speakers. Before amps were made, bad output transistors would create the same effect.
Apr 13, 2009 | 1997 Chrysler Sebring
Blippy Sound
Sounds like the cords that are going into the PC/system have static. Remove the cords from the speakers and simply put your finger around the jacks to remove static. Push the cords and the jacks back in and switch on the speakers. Then twist the volume control, turning it up loud and then low, then loud and low again. That should cure the problem as it removes static that gets built up over time. Either that or your speakers could well be damaged.
Mar 28, 2009 | Altec Lansing VS4121 Speaker
Scratching (static) noise coming from computer speakers
I foudn this in anther forum:
I have an ASUS motherboard P5E3 Premium. The audio that came with it was the Sound Max audio. I also noticed abnormal sounds coming from the speakers. They included sounds during hard drive activity and also with mouse movement. They were not loud but noticable. I searched all over the web but didn't find the answer. I stumbled across the fix myself. I also have vista-64. In the sound control panel > speaker properties > levels... there is a pc beep slide bar. I noticed that if it is disabled then the abnormal sound went away completely. Problem solved. Hope this helps.
Nov 18, 2008 | Dell Dimension 4600 PC Desktop
Car stereo static
Sounds like you may have an output transistor/module about to go out.
May 10, 2007 | iLO XM-MP3-CD Car Stereo
Static from right from speaker
The noise is in the pre-amp stages of the Denon AVR. It might be caused by bad capacitors.
Mar 08, 2017 | Denon AVR-1803 Receiver
188 people viewed this question
 Grubhead
Grubhead
