Question about Refrigerators
Cleaned frig several times-no real food in it wierd odor.
Turned it off drip pan is not removable, no dead rodent
Open a box of baking soda and put inside the refrigerator, it will draw out the odors.
Posted on Apr 09, 2015
Why does refrigerator have odor underneath
Odor from under frig can come from the fresh food drain into the evaporator drip pan or from spillage of food under the refrigerator. If it is a high temperature smell, it can be due to accumulation of lint and dirt on the coils and fan under neath the refrigerator. All refrigerator need a yearly cleaing done underneath the refrigerator, both the floor and the components.
Hope this helps
Feb 15, 2015 | Refrigerators
Chemical smell in frig permeating food taste. Is it dangerous
First remove all the food and produce and thoroughly clean the fridge with disinfecting wipes, then put a couple of boxes of Arm And Hammer Baking soda in the fridge to absorb the odors. And no it is not dangerous in my opinion. I have smelled fridge odors that would gag a maget
Apr 25, 2017 | Refrigerators
There is a bad smell that I get a wiff of when I walk by. The smell is on the right hand side of the frig. Sometimes it can be smelled for a short distance. The smell is not coming from inside the frig,...
Some of them do have a drip pan under them ,at the bottom of the frig there is a cover that will come off may be screwed on may snap off when you pull on it.Take a flashlight and shine under it after you get plate off you should see it .You can put a cap full of bleach in it should take care of your problem.
Sep 20, 2017 | Whirlpool GX5FHTXT Bottom Freezer French...
I have a Whirlpool refrigerator 21TFA that may have a drain problem or a clog. It drains in the evening, but this morning when I woke up, it smelled bad from the bottom of the refrigerator. Any advice?
Hi and Welcome to FixYa I am Kelly,
A bad smell from under the refrigerator is a result of either a dead rodent or.. dirt and lint accumulation in the plastic drip pan / catch basin and then the defrost cycle water wets it 2 to 3 times a day intensifying the smell.
Unplug the unit
Remove the rear fiberboard cover that covers the compressor area
Use a shop vac and rags to clean out the drip pan / catch basin. (These can be VERY foul if they have never been cleaned!) Make sure to clean the condenser coils and condenser fan area also. Inspect for varmits / rodents (deceased) with a flashlight. You can wash the drip pan using a rag with vinegar and water then soap and water.
Lastly... make sure the END of the drain tube that terminates in the drip pan is clean. If there was lint build up that caused a muck pool in your drip pan the muck often clogs the end of the drain line.
You never know what your going to find under a refrigerator! I could expound but it is not pleasant and only you will be able to discover the secrets of your refrigerators' "underside life." All I will say is.. it is always a... revealing experience.
Thanks for choosing FixYa,
Kelly
Mar 21, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
There is a terrible smell from the oven
I would need to be there to verify but if it is not an electrical odor then I would suspect a dead rodent, or if you have pets a mouse could have packed the space between the liner and the frame with pet food. I had one that had stored 20 pounds of dog food in there.
Eric
Mar 10, 2010 | Frigidaire (FEB30S7D) Oven
Funky smell coming from bottom of frig when running
Is it a musty smell or that of something / (rodent) decomposing? If you only smell it when it is running then look for BLACK gunk that will probably appear almost like a paste. Even things like cat or dog hair will collect in damp areas. There should be a white plastic drip pan under your unit. Look for the freezer white plastic drain hose on the rear bottom of your unit on the freezer side and follow that hose to the drip pan. It catches water every time the unit defrosts which is 3 - 4 times a day depending on which defrost timer your unit has.
Usually there is a build up in the drip pan that gets mucky and then stinks like mold. It will of course need cleaned.
Also look at the fan area for the coils. Sometimes there are unwanterd home critters that attempt to get through the running fan blades and end dead up inside the cooling coil metal radiator area.
Feb 03, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
When motor comes on there is a stale,odor
check around the compressor area and the drain pan there might be a mouse or something dead under there make sure to unplug the fridge before you go messing around back there
Jul 11, 2009 | Kenmore 50522 / 50524 Side by Side...
Foul odor from beneath the frige!
You have a couple possibilities. Either something spilled in the frig and ran down into the drip pan or you have a dead critter under there. The pan is not removable and cleaning it is a pain. take a good look under there from the back and the front.
Eric
Jun 24, 2009 | Refrigerators
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
