Question about Bunn Ultra-2 HP High Performance Slushy / Granita Frozen Drink Machine with 2 Hoppers - Black & Stainless Steel 120V 34000.0081
Bunn Ultra 2 oily discharge
A thick greasy/oily fluid is coming out of the bottom of the machine
3 Suggested Answers
projdoc
  • 2236 Answers
SOURCE: I have an Ultra 2 bunn slush machine. One hopper
make sure it's mixed properly. if there is toomuch water, it'll freeze solid. if the mix is too rich, ice will form on the outside of the bowls. you may also have a low refrigerant level.
Posted on Feb 13, 2011
EsWorld
  • 1618 Answers
SOURCE: why does my ultra bunn 2 slushy machine throw off
Check the filter in the back of the machine that and the coils are covered with dust.
Posted on Feb 19, 2011
Left side of Bunn Ultra "ice" mode is in lower case but right side "ICE" mode is in upper case?
upper case means it is still trying to slush. lower case means it has reached designated slush thickness
Jun 15, 2014 | Bunn Margarita Machine Ultra 2 Slush...
I have bunn slush ultra 2. 1 side freezes 1/2 way, like slushy a little bit but still watery, other side is only chill. both are set to 16 thickness.
make sure both say "ICE" on the display. press the snowflake buttons on the front to get it there. also, make sure you are mixing the product properly. if still an issue, you may have a small refrigeration leak that should be looked at by a professional
Aug 26, 2013 | Bunn Margarita Machine Ultra 2 Slush...
Bunn ultra 2 where is the ultra button
the words ultra, gourmet, and ice above the display are buttons.
Apr 05, 2013 | Bunn Margarita Machine Ultra 2 Slush...
Bunn ultra 2 says hold ultra button
Why can't you use Pepsi or Coke in a Bunn Ultra 2 machine
the brix level (syrup to water ratio) may be too low, which will cause it to ice too quickly and cause damage.
Dec 03, 2012 | Bunn Margarita Machine Ultra 2 Slush...
Ice forming on outside of Ultra 11 bowls. Is there something that can be coated on outside to prevent?
put the machine on a defrost cycle and make sure the mix is correct. to rich (not enough water) and the temp will drop until it gets to the right thickness, thus freezing the condensation on the bowls.
Oct 20, 2012 | Bunn Margarita Machine Ultra 2 Slush...
I have a bunn ultra 2 flat lid ice machine, manual failed to come with the machine. it needs cleaning, the 'clean due now' is always on the screen, followed the info on the side of it to clean and even let...
Can go to the Bunn website.Go to commercial section,then manual index and then specialty drinks.You can find :Illustrated parts,operating service,service,repair and programming.
Oct 16, 2010 | Bunn Black Flat Lid Ultra 2 Ultra Gourmet...
I have a 2 hopper bunn slush machine.One hopper freezes the second one does not
May 22, 2010 | Bunn Margarita Machine Ultra 2 Slush...
Greasy oil and water is leaking from under the washing machine?
Hello, the good news is the water is coming from the pump and is easily replaced, the bad news is if you are seeing a yellow oily substance your transmission has a leak and will go bad at some stage soon. The question here you need to ask yourself is do you want to spend $35 on a new pump when your going to need to buy a new washer? If so pull the machine out and puch it back so it leans against the wall umder it's own weight. wedge some thing underneath the washer so you can access the bottom without the washer falling on you. you will see the pump attached to the motor which is attached to the transmission. remove the 2 clips and 2 pipes from the pump, remove the pump and replace it, reassemble in reverse order, you should be able to see where the leak came from the pump at the point where the motor shaft connected to the pump. Also while you are under there look at the base of the transmission, you should see some oily residue where the transmission fluid is leaking. Hope this helps! if you have any other questions please feel free to comment again. Good Luck!! Mike
Jul 21, 2009 | Whirlpool LSR5132PQ Top Load Washer
Bunn Ultra-2 HP High Performance Slushy / Granita Frozen Drink Machine with 2 Hoppers - Black & Stainless Steel 120V 34000.0081 Logo
731 people viewed this question
Top Bunn Cooking Experts
Tom Chichester
ray gallant
Are you a Bunn Cooking Expert? Answer questions, earn points and help others
