Question about Radio Communications
Where can I find operatiog manual for Regency Monitoradio/Executive Scanner?
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 10 Answers
Since they haven't made this model for decades it would be a tough call. My advice to you is check out radioreference.com and post there...you may have better luck in that forum. This is a crystal controlled radio as well so sourcing out the crystals for it will be your next task.
Posted on May 03, 2015
Where can I buy an antenna for a Regency model R1070 scanner
search ebay for "regency r1070 scanner antenna" and many will pop up. Also Radio shack..
Jul 09, 2012 | Uniden Radio Communications
How to read engine light codes on a 1988 Oldsmobile Regency without using a OBD Scanner?
An auto repair manual such as haynes or cylmer will show you how to jump the terminals and count the flashes and the code explanation
Sep 11, 2009 | 1988 Oldsmobile Regency
Regency dx3000 programmable scanner need manual
I did a quick search and only found the manual for sale. Here is a link that i found. The manual will cost $10.
elijam1
http://www.scannermaster.com/?Click=37131
Jan 07, 2009 | Uniden BC72XLT Handheld Scanner
Regency 1099
Hello tpayne28, mail an order for a R1099 manual to; Mr Scanner, P.O.Box291918, Kettering,Ohio 45429. Include a payment of $6.00. Regency was bought by Bearcat.
Nov 05, 2008 | Radio Communications
How to program an old regency 1060 scanner
I'm not too sure about this particular model, but other Regency variations require you to push the "Manual" button, enter the channel number you want to set (usually 01-09 for single digits) and then enter the frequency you want. On some you may need to enter the frequency first and then the channel number.
Oct 11, 2008 | Uniden BC72XLT Handheld Scanner
Regency Touch K500
Yes, go to http://www.radiopics.com/1.%20Manuals/Regency/Regency_Touch%20K500%20(Manual).pdf
You can download the pdf format from that website, however you must have Adobe Acrobat Reader.
Hope this Helps!
Aug 23, 2008 | Radio Communications
Manual
That model was the first prototype of the Uniden Bearcat Electra BC780XLT-PPKL88 otherwise known as the BC780XLT. That manual that you got for the XLT model should work just fine, the only difference is that the XLT has more features than the HLT. The HLT came with its own manual, but it wasn't very accurate either, just try to make due with the manual you've got. If you want a scanner that is easier to use, you should get a Regency Touch K500. The Touch K500 can scan up to the 900MHz range and has VHF/UHF/FM/AM/CB/WX/AIR scanning capabilities. It even comes pre-programmed with international channels. It also has an automatic Weather Alert Notifier Bank already programmed into its internal memory. In short, the K500 is the ultimate scanner. However it will be hard to find because Regency went out of business a while back.
Good Luck!
Jun 25, 2008 | Radio Communications
Uniden sc230 scanner
The lock out function is a common problem in scanners, to override the lockout command, you can press and hold the lock out button, or punch in the frequency that you locked out and unlock it by pressing the appropriate buttons depending on the model of your scanner. Here is a suggestion, for easy scanning I recommend a Regency Touch K500 Scanner. It may be hard to find one though, Regency went out of business a while back, but I had the K500 and it was the best scanner I ever had.
Mar 22, 2008 | Uniden BC72XLT Handheld Scanner
Programming
Most Regency Scanners have the same basic programming setup.
Try the following.
Press "Manual"
One of the channels will show up in the display, probably channel 1.
Enter the frequency you want to enter, example 162.550
Press "Enter"
The channel number will flash,
Enter the channel number you want to put that frequency in, example to put that frequency into channel 4 enter the number 4.
Note that on some models for channels 1-9 you must enter the channel as a 2 digit number so enter 04 for channel 4.
You can repeat this process to enter all the frequecy's you want and just change the channel number.
Also check out
http://www.w7fg.com/index.html
for scanner and old radio manuals.
from WikiAnswers
good luck
-voodoomox
Dec 06, 2007 | HP PSC 1410v All-in-One Printer
Radio Communications Logo
340 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
