Question about Hamilton Beach 49995 FlexBrew Single Serve K-Cup Coffeemaker Bundle
I always have coffee grounds in my coffee when I brew a K-cup. Why is that, and how do I make it stop?
  • 3 Answers
The K-cup must be getting pierced on the top, where it lets the coffee grounds out into the cup during the brewing process. This usually means the K-cup isn't seated properly in the basket.
Posted on Apr 10, 2015
Coffee rounds in tray after brewing
is just normal after you brew coffee that the used coffee pucks get off the machine
Jan 19, 2016 | Saeco Vienna SuperAutomatica Coffee...
It leaks water under the right side of the brew basket.
Leaks water when brewing ground coffee with a My K-Cup ...
https://www.ifixit.com/.../Leaks+water+when+brewing+ground+cof...
iFixitWhen I use the My K-Cup filter to add my own ground coffee and brew it, after it ... the machine starts leaking water at the same time, so typically the mug beneath the ... in the lid that has the needle opening in it (half sphere perforated basket below it). ... thewater could simply flow over the coffee, and go right down the sides.
Stop Leaks - www.My-Cap.com © 2015
www.my-cap.com/stop-leaks.html
Jan 01, 2016 | Coffee Makers & Espresso Machines
Why cant I get a full cup of coffee
Brewing a Partial Cup
If the brewer is not brewing the full amount selected, it may be caused by the following:
  • The exit needle is clogged by coffee grounds or cocoa mix. Please refer to the K-Cup Holder cleaning instructions.
  • The brewer needs to be descaled. Please refer to the descaling instructions.
  • The removable water reservoir was removed during brewing. Place the water reservoir back onto the brewer and perform a cleansing brew without a K-Cup pack.
Jul 27, 2014 | Keurig B60 Coffee Maker
Is there a way to stop coffee from spraying?
There is a little part that sells on ebay for $2 that slides into the Keurig brewer lid and stops coffee from spraying from reusable K-cups. It works great and is guaranteed or money back. Here is the link:
http://www.ebay.com/itm/EASY-FIX-STOP-COFFEE-LEAKS-FROM-REUSEABLE-K-CUP-EKOBREW-SOLOFILL-CAFE-KEURIG-/271239290594?ssPageName=STRK:MESE:IT
Nov 14, 2011 | Keurig B70 Coffee Maker
45 cup coffee urn How much water and how much coffee?
20 cups of coffee needs 2 cups of coffee grounds
30 cups of coffee needs 2 1/2 cups if grounds
40 cups of coffee needs 3 cups of grounds
45 cups of coffee needs 3 1/2 cups of grounds
1 cup brewed coffee = 5 fluid ounces
* use standard measuring cups
Oct 22, 2010 | Salton Melitta MEU45 Stainless Steel -...
My mr coffee pot will not stop brewing when I pour a cup of coffee while it is still brewing. My model has the brew/pause feature
There may be grounds stuck in the spring loaded gadget next to the pot's pour spout - Remove all interior parts and rinse under water.
Sep 29, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
When I brew a cup of coffee there are coffee grounds in the coffee?
Take your K-cup out and it splits into two pieces. The buttom half has a chamber where coffee grounds that slip out can sit. When it builds up you tend to see allot of grounds in your coffee.
Also check that your top needle seat is there and in good condition.
If you need assistance further my email is help@igotsweetdeals.com and my site which sells keurig parts is http://wwww.Igotsweetdeals.com/
Hope I helped you!
May 12, 2010 | Keurig B60 Coffee Maker
Coffee grounds in bottom of commercail size coffee maker
If you will call 800-286-6070 we can help you with this.
Nov 01, 2009 | Bunn 10 Cup Home Coffee Brewer
My cuisinart grind and brew model dgb-700bc shuts off right before it is done brewing and i am getting coffee grounds in my coffee pot
Too much grounds or not running through fast enough. Right filters? basket flow hole vlesr? Sounds like it's backing up and flooding causing the grounds to get by yje filter. If you dare, **** the hole out just a tad. with the end of a sharp knife. not too much. You can always take out mor. This is called consuner calibration. Good Luck -Ned-
Sep 19, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Beans ground but continuous grinding but not brewing
The grind switch is stuck. Try to free it and clean it.
Mar 15, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Hamilton Beach 49995 FlexBrew Single Serve K-Cup Coffeemaker Bundle Logo
510 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
Greg Cann
Greg Cann
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
