Question about Miscellaneous
My Wacker plate compactor runs great for 20 seconds and Completely shuts off, then I start it right back up again with no problems and it shuts off again, the oil is full and the carburetor is changed
  • 3,519 Answers
Sounds like fuel flow is a probable cause of the problem.
Try draining the carb just in case there's some contaminates in it. Also try the fuel tank. Turn the fuel valve off.... disconnect the fuel line and point it into a glass jar, then turn the valve on and allow 1/2 cup or so to drain. Have a look at the fuel for grit, rust, water, etc. If there is a fuel filter make sure it is clean.
Hook it all back up and give 'er a go! Cheers it it does!
Posted on Apr 09, 2015
chiquititas
  • 1010 Answers
SOURCE: 1997 ford crown victoria starting problems
Sounds like you're on the right track. A bad TPS and ISC motor sensor will cause the problems you're experiencing. Your ECM relies on the readings it gets from the TPS to be sure there is enough air getting to the engine. If the ECM gets a bad reading and thinks not enough air is getting to the engine, it will cut the fuel supply, hence causing your engine to die. Your ISC relies on the reading from the TPS as well. It detects from the ECM if the throttle plate is closed or not. If it thinks the throttle plate is fully closed, it will start allowing air to enter the engine and bypass the throttle plate. If your ECM starts seeing some unmeasured air coming from ISC and detects the throttle plate is open (which it may not be due to a bad TPS reading), the ECM will again cut the fuel supply to avoid the risk of detonation.
So, replace your TPS first and see if that cures your problem. Also, check the resistence readings of your ISC to be sure that is within spec. If your problem still occurs, check your Intake Air Temperature (IAT) sensor in your air filter housing. Be sure your spark plugs, plug wires, and distributor are all in good shape as well. Replace your fuel filter if you haven't done so in the past 2-3 years.
Posted on Jun 23, 2008
SOURCE: runs ,then loses power after driving for 30-60 minutes.
AIR IN THE GAS TALK
Posted on Aug 06, 2008
SOURCE: the van starts right up but shuts right back off
you might have a regular key instead of a microchip key. the micro chip key sends the signal to the computer. If you have a regular key it will start and a couple of seconds it will shut off and do it over and over again.
Posted on Oct 12, 2008
SOURCE: 1999 4.0L Jeep Grand Cherokee shuts down after 20-30 minutes.
I'd suggest the ignition control module, however I'd have a certified mechanic check it out just in case...
Posted on Feb 01, 2009
SOURCE: Have a 95 Camaro Z28 LTI, after starting the
i and my buddy had the same problem. After findin i had bad ignition wires and spending over 1000 we found a guy that told us that the distrbutor goes bad on these cars. and he replaced at least a 100 of those things. GM is aware of problem and made and improved OPTI SPARK distrbutor. IT will probably cost u a good 600 easily but never had the problem again.
Posted on Sep 17, 2009
How do I choose the right compactor for the job I'm planning to do?
It all really depends on what you want to do. There are three main types of plate compactors.
1. single-plate compactors only go in the forward direction, this is good for a small project like a laying asphalt.
2. Reversible plates are able to go forward and backwards.
3. High performance and heavy duty plate compactors which are usually used for deeper compaction projects.
For your at home project you should be fine with a single-plate compactor.
Nov 11, 2013 | Tools & Hardware - Others
What does a plate compactor do?
a plate compactor uses vibrations and pounding to flatten out land so that you can pour pavement or start preparing for landscaping.
My plate compactor won't start, what could be the problem?
are you using the choke? do you have the throttle on at least a little bit? if these things are ok, you probably need to add oil to the engine
Jan 16, 2013 | Tools & Hardware - Others
I have a new plate compactor with a honda motor ,it ran for 5 mimutes then stoped, now the pull start doesnt pull, is it seized? wat should i do
First, remove the spark plug and try turning the engine over. If it is new, it probably didn't seize unless there was no oil in it. Even if so, under the right care, it can be made to run again if it isn't too badl If it was run completely dry, I don't see how it would last for 5 minutes even. If you still can't turn it over, remove the engine cover to access the flywheel cover. Remove that to get to the top of the engine. The starter/recoil unit will be there. Inspect and/or remove if it still doesn't turn engine. Then, grasp the flywheel (gloves will help) and try to turn it (either left or right, no matter). If this doesn't work, squirt some penetrating oil (Liquid Wrench or PB Blaster) into the spark plug hole. Give it a couple good shots. Let it soak a little while and then try turning engine by hand again. If this was a mower, you would be able to grab the blade to attempt to turn the engine over. Plate compactors have none. Post back if you need more help.
Jan 28, 2011 | Husqvarna 160 CC Honda OHC Engine 21 in
2004 Polaris Sportsman 400 Only idles, quits Electrical Problem?
Sounds like the battery may have a bad cell. The reason it quits dying is that there isn't enough juice in the battery to fire the plugs. On older pull start vehicles the stator put out the power to run the coils. On atv's with batteries, the power output is sent to the battery, and then to everything else. If the battery is bad or just dead, it eats up the current and leaves nothing to run the motor. The dash lights go out because it completely drains all current until even those lights go out. Once the motor quits runnung, there is enough current to get those lights back on again. Hope this helps...
Oct 08, 2009 | 1970 kawasaki Mach III H 1A
Have a Viking trash compactor VUC181 that will not open. Appears latch is broke. How can I get it open?
I have had this same problem and found two causes. Latch was never the problem.
#1 - Ram not in full up position. To check remove top plate and attempt to run compactor - depressing microswitch when ram is at the top. If compactor will not run you can check the ram position by turning the primary screw drive with a ratchet wrench. When ram is at the top position attempt to open the compactor drawer. The stop microswitch seems to frequently bend out of alignment - check the microswitch positioning before resecuring top plate and adjust if necessary.
#2 - Can (or other debris) is wedged in between ram and drawer. Remove back cover and carefully inspect insides of the unit - use a flashlight. Pry out any debris that may impede the drawer from opening. Attempt to open the compactor drawer.
Good luck,
Jon B.
jbroccoli@aol.com
Oct 10, 2008 | Viking 24 in. Professional Series VUD141...
Trash compactor problem
I have had this problem on my GE Monogram. The 'smasher' is near the bottom and does not move anymore, even though the motor is working.
What I did was to get a crowbar that would fit through the crack and hook the underneath side of the bottom plate. You also have to hold the switch so the motor runs with the door open and pull up on the plate until the drawer can be slide out. The trunnion nut (a plastic nut) was cracked. I replaced it 3 years ago, and it just cracked again. They now make it out of metal, so maybe it will last longer. Ordered it from appliancepartspros.com.
Jan 11, 2008 | GE Profile GCG1580LSS 15" Built-In Trash...
Trash Compactor Problem
Had a similar problem with mine. I took it apart and found that the nut that is on the bottom end of the ram screw was loose. I tightened it and it fixed the problem. That was about a month ago. Now it is doing it again. I'm going to tighten it again this weekend and apply Loc-tite to the threads.
To get to the nut, you have to lay the compactor on its side and remove the plate from the bottom. You'll see a chain that goes around the motor sprocket and both ram screws. You need to tighten the nuts on the ram screws.
Hope this helps.
Steve
Nov 20, 2007 | KitchenAid 24 in. KUDS02FRSS Stainless...
Miscellaneous Logo
151 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
