Question about Furniture
How to fix leak from compressor - Furniture
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 147 Answers
The compressor has copper tubing which is soldered together, so if you discover a leak, it needs to soldered. The system has to be evacuated with a vacuum pump, then refilled with the correct amount of oil & freon.
Posted on Apr 09, 2015
    Passionate:
    Visited the website for 10 consecutive days.
  • 114 Answers
We posted a video about how to handle small leaks in your wine cooler.
https://www.youtube.com/watch?v=XOGfOaFe_y0
Posted on Jun 03, 2015
Ge icemaker zdis15css - Leaking. Compressor might be leaking as that's where its dripping from & water on side of compressor but not on top. Is there cleaning or fix or is it a replacement issue?
leaking what? I hope the compressor isn't leaking water, compressors will sweat but excessive sweating usually points to an overcharged system. it's unlikely it's leaking refrigerant AT the compressor, try bubbles to locate leak if you don't have leak detector
Oct 01, 2017 | GE Heating & Cooling
2008 x5 air compressor makes loud noise when pumping up rear leaks down over nite
that sounds like an air leak at the rear airbags or a faulty valve on the lines from compressor to rear suspension compressor is working to hard thats why its noisy
Jul 03, 2016 | 2008 BMW X5 3.0si
A/C compressor front seal leaks 134a. Can the can of 134a with leak sealer really seal the leak?
No, the stop leak is designed to seal a leaky O-Ring. I have never seen anything fix a compressor seal other than replacement.
May 17, 2016 | 1997 Ford Expedition
How to fix air conditioner in 1985 toyota hiace
My 1986 would leak. The HP and LP hose coonections to the compressor where lose. Tightened up and stopped most leaking. I added leak detector and found the LP fill connection Schrader valve seat was bad. Put in a new Schrader valve (bought off ebay for cheap- but a couple of extras) and all leaks stopped. Night not be compressor itself. Have a pro check the system for leaks.
Jan 29, 2014 | 1985 Toyota Pickup
Compressor leaks at pressure switch
The diaphragm in the pressure switch is leaking. A new pressure switch is the only way to fix it
Feb 19, 2013 | Senco PC1130 Compressor, 1.5-Horsepower
Campbell hausfeld 60 gallon sight glass oil leak
Try here http://www.about-air-compressors.com/campbell-hausfeld-air-compressors.html
Jul 30, 2012 | Campbell Hausfeld Air Tools & Compressors
Pop off valve on return line leaking compressor keeps running turn compressor off stops leaking whats up?
Once the pop off valve reaches its opening point, it will stay open as long as the pressure is above that point. When you shut the compressor off, the pressure leaks down until the pop off valve closes. Sounds like the pressure regulator is set a little too high. If you can turn the regulator switch down, it should fix it.
Cabinetman54
Nov 18, 2009 | Air Tools & Compressors
1998 GMC Jimmy A/C Compressor Leak
If the leak is in the hi/lo refrigerant lines replace the washer seals. If it is coming from the shaft behind the clutch,replace the compressor.
Aug 15, 2009 | Goodman CKL36AR36 Air Conditioner
Compressor does not quick in when a/c is turned on
Your R13 may be so low that the compressor does not kick on. This is a protective design becasue when the R13, which lubricates the compressor as well as cools it runs out the compressor will seize. Depenmding on the age of the car, add more refrigerant or have the system evacuated, pressure tested, repaired and refilled. A lot of times the evaporator leaks first
Jul 20, 2008 | 2007 Mercedes-Benz S-Class
Furniture Logo
461 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
