Question about LG Washing Machines
My LG TROMM Front Loading washer that turns off randomly in the middle of a cycle???
Model #61WD6770. It has full 120v to the power cord, 120v through the filter board and 120v at the main board. It passes all of the QC tests. I've tried a different wall outlet to no avail. There is no specific time that it turns off either... a couple of times it makes it through the entire cycle... others within minutes. All capacitors look fine and there are no burnt/black spots on any of the boards.
  • Tedowen Apr 09, 2015
    Hi Joshua Payne, I want to help you with your question, but I need more information from you. Can you please supply the exact LG Model number?
  • Joshua Payne
    Joshua Payne Apr 09, 2015
    61WD6770
    Prodigy:
    An expert who has answered 500 questions.
  • LG Expert
  • 536 Answers
Sounds like a main control board problem.
Posted on Apr 16, 2015
  • 10 Answers
SOURCE: Tromm Washer Model # WM2277HW by LG
will it spin after it washes if it does not then your belt might be broke
Posted on Feb 12, 2008
Karthik316
  • 187 Answers
SOURCE: Front bottom leak from my LG TROMM HE Washer
  • Hi
  • Try these:
  1. Inspect the water supply connections
  2. Inspect the drain hose
  3. Inspect the water pump
  4. Inspect outer tub for cracks or corrosion
  5. Inspect the tub seal
  6. Inspect the tub bearing
please rate my suggestion...
Posted on May 22, 2009
SOURCE: LG front loading washer is turning itself on,then off
You have a fault microprocessor, or the "Brain" is sporadically faulting... You need to get this looked at... it isn't a minor thing unfortunately... look get a firm "Quote" from a reliable service center man
Posted on Feb 01, 2010
skimbot
  • 5 Answers
SOURCE: LG Tromm will not turn on.
I have put mine on a surge protector. It is a computer after all. It is hard to say whether or not you have suffered damage to the motherboard. Trial and error testing to see if you have power at your outlet. Hopefully you can repower and all will be well.
Posted on May 30, 2010
  • 472 Answers
SOURCE: My lg Tromm front load
these units have had alot of problems especially if it is on a pedistal ...they won't admit this is a problem but i have been a lg servicer for over 4 years now and see it everyday ...the unit has a stator on the rear of the tub and on the stator is a device called a hall sensor that goes bad very often... it is what controls the spped and balance of the tub..if the load starts getting unbalanced the hall sensor will tell the motor controller to slow the speed down... most likely this is your problem.... good luck please vote
Posted on Jan 03, 2011
LG Tromm washer powers on but turns off a second or two later. I don't see any error code since it turns off right awat. What can be the problem?
Try using another outlet. Connect an extension cord to another outlet away from the room you are in and see if that will resolve the issue. If it does, you will need to call an electrician to resolve the electrical outlet problem. If the machine continues to shut off, you will need to have the control board on the washer replaced.
Good luck
Jun 16, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG TROMM WM3431HW(?) soaks clothes in Dry Cycle
LG says to unplug unit. Or remove power by tripping circuit breaker. Wait a minute and plug back in. Good luck.
Mar 25, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My washer say LG what dose that mean
My washer stopped and displayed the LE error code. I turned off the power button and tried again, but after a few seconds it want back to LE. Finally, I unplugged the power cord, plugged it back in, and the washer ran normally.
Dec 21, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Drum does not spin
We have an LG TROMM with the same problem, 3 years old as well. We bought the extended warranty (Huge waste of $$$$).  So far they have determined it is not the motor or either of the control boards.  We think it might be a relay switch or possibly the brake.  Good luck with yours, we just went out and bought a new washer.
Jun 22, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Tromm WM2496HWM Washer - stops mid cycle
use only HE (high efficiency ) soap,try not to use too much ,run tub clean cycle with a little bleach to kill smell
Jun 12, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
66 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
