Question about Sony Audio Players & Recorders
I came across a Sony str-vx1 stereo receiver.The only problem I have found is lots of static when you try and turn up or down the volume.any help would be appreciated.thanx in advance
    Top Expert:
  • Sony Master
  • 41,412 Answers
Try contact cleaner on the volume dial and run it back and forth many times .
Posted on Apr 09, 2015
djnick989
  • 1067 Answers
SOURCE: No audio through speakers and no light on volume dial of Sony STR-D865
unplug it back in went into safe mode it sounds like gotta watch those kids lol unplug from wall 10 min try pluging back in ok if not blow fuse inside
Posted on Jan 24, 2008
  • 395 Answers
SOURCE: Sony STR-DE135: No audio output
first, at turn on you should hear a relay click then a few seconds later a second click. if you should hear the two relay clicks then check to see if you have both A and B speakers on, if you do shut B speaker off. next check the tape monitor switch make sure that it is off. if you should not hear the second relay click you have a problem with the unit and needs to be repaired.
Posted on Feb 17, 2008
gman63b
  • 9 Answers
SOURCE: Sony STR-DE635 Receiver-no sound at all
Turn your volume down,press the tape monitor button.then turn up?
Posted on Mar 21, 2008
  • 4234 Answers
SOURCE: Low volume on left channel of Sony STR-GX4ES
The headphone is tapped before the final stage of the amp, so knowing that those work properly helps to isolate the problem. I think that this model uses an IC for the voltage amp section prior to the final amp stage. That being said, the IC is probably an UPC2598 (if memory serves). I'll confirm tonight. Try resoldering any connections that appear to be grainy or have rings. Let me know what you find.
Dan
Posted on May 08, 2008
ginko
  • 19396 Answers
SOURCE: Sony STR-D665
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
Posted on May 29, 2009
Sony receiver stR se-501 found fuse burned after replaced turned on the flashing massage PROTECT come on . Did I miss anything?
Protect typically means that the fuse blew because something in your receiver went bad. It's now protecting your speakers from that badness. You need to get the receiver fixed or replaced.
Jun 16, 2015 | Sony Str-Se501 Stereo Receivers
How do i connect an ipod to my sony str-de310 receiver
Connecting to a home stereo
  1. For most home stereo systems, connect iPod to your amplifier's sound input using a 3.5 mm mini stereo to RCA adapter cable.
  2. Adjust the volume on iPod to less than half to prevent overdriving your amplifier. Adjust the listening volume using your stereo's controls.
    Note: Depending on your stereo, iPod may need to be set higher than half in order to get a proper volume through external speakers.
http://support.apple.com/kb/ht2167
Mar 12, 2011 | Sony STR-DE310
I was playing some music pretty loud today on my Sony STR-DB790 and then no bang no crackling just strait to protect mode turned stereo off thinking nothing of it and now every time I turn it on strait to...
There is an output load causing the protect to engage, turn unit off and dis-connect the speaker wires from the back of the receiver, this will reset the processor ic. Now power on and turn volume right down, if the word protect stays off it means there is a short in the wires or one or more of the speakers. But if the word protect comes on with the "speakers and wires dis-connected" it indicates a short in one or more audio output ic's and will need a tech to address the extent of damage and cost.
Feb 06, 2011 | Sony STR-DB790 Receiver
Str-gx800es sony receiver problem- right channel speaker sound is 'static', low and distorted. I have checked checked all speaker and output/input source cable connections with no luck. All left channel...
If you have checked the speakers and wiring, the right channel has a audio driver or output problem, which explains the low volume, static, and distortion. A service technician will be required to fix the receiver so it will balance the left side.
Jan 10, 2011 | Sony STR-GX800ES Receiver
Receiver clicks and rear speakers stop working
Maybe, it worked for me. my rear speakers workt ramdomly, often not. so i re solder the relay for the rear speakers, now it works fine everytime, a hole movie and some random on and offs, it can't do any harme to try=)
Dec 09, 2008 | Sony STR-DE635 Receiver
Volume change, followed by slight static playback.
I believe you have dry joints in output drive it require a qualifier Technician the do this you need special soldering station with anti static you are dealing with surface mount components if you shorted some thing in output drive it could damage to the output they are expensive to replace, now is not too bad you should bring in to Sony or servicce center Sony to repair it
Cheers
Dec 04, 2008 | Sony STR-DB1070 Receiver
Sony Receiver STR-D550Z
Any luck with this Brian? I've got the same problem with a Sony STR-D550Z stereo receiver.
Mar 23, 2008 | Audio Players & Recorders
Mar 20, 2008 | Sony STR-DE635 Receiver
Feb 17, 2008 | Sony STR-DE135 Receiver
Sony STR-DE545 receiver
You should have access to receiver's format from remote or front panel. If the unit was moved around a lot and for a long period, the micro-processor may have locked due to ambient static electricity. Try unplugging unit for seversl hours, then re-try
Aug 19, 2007 | Sony STR-DE545 Receiver
110 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
