Question about Refrigerators
Why has the water dispenser stopped working all of a sudden. Do the lines freeze up or is there an on off function on the control panel
  • 998 Answers
Without knowing what make / model fridge it is nearly impossible to say , however, most domestic fridge have a water tank in the base of the food compartment which stores the water before going into the freezer dispenser. Have a look behind the crisper drawers for it. If the food compartment is too cold, this tank can freeze up and stop water from going into the dispenser. Is it still making ice? If so, the water valve which is normally 2 parts (1 for ice making and the other for water dispensing) may have failed.
Posted on Apr 09, 2015
catriver
  • 878 Answers
SOURCE: Water and ice dispenser and panel light stopped working.
Oakescreek, start with simple things first. Check the freezer door light interlock switch. This has to be closed to send power to the dispenser. If that is working ok, check the harness coming from the bottom of the freezer door for cracked or split wires. Check the harness plug itself to make sure it is completely connected. If these things check out ok, we will need to verify that we are getting voltage to the dispenser selection switch. If we are and it is still not operating..then I would suspect that to be the problem. I'll keep and eye peeled for a reply. Catriver.
Posted on Jun 05, 2007
the dr
  • 447 Answers
SOURCE: water dispenser won't work
see my posts in my solved solutions on water line freezing. I can email you a bulletin for a heater kit.
Posted on Dec 06, 2007
maklean
  • 1665 Answers
SOURCE: Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Posted on Jul 04, 2008
SOURCE: ice/water dispenser control panel
@ Scootertramp
You tell us about this board or that board but never tell us where to located or get at these boards. Would you please clarify that?
My ice and water started dispensing sporadically, though the lights were working fine. After I removed the kick board at the bottom, cleaned out the little connector and put it back together, nothing on the door works. All else works fine.
Posted on Sep 08, 2008
Water freezing in bottom freezer
The drain line is clogged, unplug. Remove the back panel being very careful not to cut yourself or damage the evaporator. Remove the ice not sharp or pointed objects for this, just hot water. Lay towels down and start pouring hot water until you hear it go down the drain.
Mar 14, 2015 | Samsung Refrigerators
FGHB2844LF water dispenser not working
Turn the temp down on the refrigerator side but not below freezing. Some frigs have a "trap" set up for the water dispenser. its located behind a panel in the frig and it is there to help chill the water before it dispenses. if the frig setting is too cold then it can freeze the water .
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Dec 08, 2013 | Frigidaire FGHB2844LF Gallery 27.8 Cu. Ft....
Water dispenser on fridge not working - water pressure fine, could the line be frozen and why would that start happening all of a sudden?
Check to see if the water reservoir in the bottom of the frig is frozen. If it is, you will need to turn the frig temp down.
Dec 04, 2012 | Refrigerators
Electrolux 23 cu ft refrigerator (EW23CS65GS1) Water dispenser problem. The water dispenser on the freezer door does not dispense water but the ice dispenser is working fine. I turned off my refrigerator...
the line is freezing up if you pull the bottom drawer out of ref side you will see a rolled up plastic line they use it as a resovoir tank so you get cold water if you have a vent in bottom left side close it i have put insulation over coil that fixed problem and turn down thermostat if milk and other stuff is freezing you will have to replace cold control
Oct 17, 2011 | KitchenAid 20.3 cu.ft. Counter-Depth...
Water dispensor stoppedworking
If the light and ice dispenser on the front panel works and If your fridge is 4 years old or older, the insulation in the freezer door has most likely deteriorated and the water in the tube feeding the water dispenser has probably frozen. Open the freezer door, put a blanket over the food to keep it from defrosting, and use a blow dryer to defrost the door. Blow the hot air on the flat panel inside the door (the backside of the water dispenser). Close the door about every 5 minutes to check to see if the water works. Once the water begins to flow, you have successfully defrosted the ice in the tube. Defrosting the door works for about 12 hours until it freezes again. To solve this problem, I placed a 10" weedeater line up thorugh the dispenser nozzle leaving about 1/8 of an inch sticking out. When the line freezes again, pull out the weedeater line, dispense water to free the ice, and then reinsert the weadeater line. I keep the line in all the time...it works great! If the light or ice dispenser do not work, the problem may be *********** board.
Mar 17, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Water has stopped dispensing. was working fine yesterday. GE Profile ARCTICA
Could be in the door dispenser panel, Sol valve, main control board, water line freezing in freezer door? Call a qualified service company.
Ge refrigerator repair
Oct 22, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE refrig/freezer dispenser makes ice, but no dispensing of water
The dispensor water line , is probably trying to freeze , inside the door . raise the freezer control slightly warmer , to keep this from happening . May take 2 or 3 raisings to find the proper temp . Also , you can order a dispensor heat kit , pt # WR49X10173 , which comes with installation instructions .
Oct 05, 2009 | GE Refrigerators
Water dispenser freezing on viking refrig
One thing that can cause this s the removal of the styrofoam block that surrounds the water reservoir. A lot of people think this is just for shipping but it is necessary to prevent the water freezing.
If it is missing it ill need to be replaced.
Jan 31, 2009 | Viking DFSB483 Side by Side Refrigerator
Ge refridgerator model gsl25jfpe bs
I have a gsl25jfpe bs ge regrigerator and the baffle motor that controls air flow from the freezer to the refrigerator is out. This had been causing everthing in the fridge to freeze and cause the water to stop working due to water freezing in the storage tank. The baffle is in the back top of the fridge covered with a plastic cover. Remove plastic cover to check baffle function.
Jul 19, 2008 | Refrigerators
Water stopped running in the dispenser
i ihave a side by side samsung rsh1dbbp with ice and water dispenser but the water has stopped working i was wondering if you could tell me how to get the front panel off to check the switches
Mar 16, 2008 | GE GSL25JFPBS Side by Side Refrigerator
Refrigerators Logo
148 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
