Question about Amana NTW4651BQ NTW4651BQ 27" Top Load Washer with 3.6 cu. ft. Capacity 9 Wash Cycles Advanced Suspension System Automatic Temperature Control Cycle Status Bar and Rinse & Spin Cycle in White
I was once told a way to spin the dial on my amana washer to reset the motor. Could anyone please tell the correct sequence again?
    Genius:
  • Amana Master
  • 1,585 Answers
Unplug for 15mins
Posted on Apr 27, 2015
  • 185 Answers
SOURCE: my amana washer top load
check the motor coupler
Posted on Mar 26, 2008
jumptrout51
  • 3361 Answers
SOURCE: Amana top load clothes washer dial malfunction
Bad timer. Replace it.
Posted on Jun 08, 2009
  • 14 Answers
SOURCE: Washer wont work.
try putting it on spi - do you hear anything? could be a broken belt - very easy to fix.
Posted on Aug 26, 2009
TheMobilian
  • 8220 Answers
SOURCE: amana washer will not agitate or spin.
Pump Locked Up
Posted on Sep 09, 2009
SOURCE: amana front load washer door locked with door open
To get the front off. (All screws look to be #2 Phillips Screws)
1. You have to unscrew (2) phillips screws from the back that holds the top on.
2. Slide the top off. (slide towards the back)
3. Then where the control panel is there is about 4-6 screws holding that plastic piece on, take those out this will allow you to pull the control panel up and out of the way.
4. At this point you can unscrew the 4-6 screws in the door area that holds the front of the washer on, once you unscrew those screws there is a tab that you have to lift the front over to pull the front off. This will allow you access to the locking mechanism.
5. There are only 2 screws holding te locking mechanism on.
Posted on Nov 18, 2010
Need a reset code
Search Google for "Amana washer code"
Dec 15, 2013 | Amana NFW7300WW Washer
Wash will not drain
Hi, When the cycle goes into drain, do you hear the motor humming at all? If the motor does not hum, check the lid switch.
If the washer agitates, there must be a problem with lid switch ot timer. The lid switch is most common.
Please let me know if this helps or if I can assist you further.
Vic
Jun 20, 2009 | Kenmore 22422 Top Load Washer
My Amana LWA60AW washing machine won't agitate.
Some timer dials will not turn all the time they will sit for awhile then advance . If it don't move for a long time sounds like you have a bad timer motor.
Some motors can be replaced and some you have to replace the complete timer.
Jun 10, 2009 | Washing Machines
Still wet clothes
It sounds like the high speed of your motor is not functioning which tells me it is either burnt and needs to be replaced, or that the control dial is malfunctioning. Because those motors have two or three speeds, usually one of the speeds of the motor is malfunctioning. Always check connections too, and see if it functions in the spin on another cycle. Best of luck. C
Mar 01, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Amana dlw330 washer belt burned & broke again after I replaced it
well if hte washer belt is "burning off"" that tells me the motor is trying to spin at full speed buthte transmision pulley is holding it back, can be a few issues, either the brake is notreleasing correctly or, the transmission is locking up .
Feb 26, 2009 | Amana 3.2 cu. ft. Top-Load Washer
GE washer (WHDRR418GWW)(14 MO. OLD)HAS STOPPED AGITATING.WHERE TO LOOK? WHAT TO TRY?
My washer would fill/drain ok but would not agitate or spin. I unplugged the washer and listened for the motor to click. When the motor clicked I plugged the washer back in. Then I opened and closed the lid 10 times. I turned the washer to the drain/spin position and turned it on. The belt moved back and forth several times and then went into a fast spin.
Sep 26, 2008 | Washing Machines
Kenmore washer
ckd wires to motor ..next timer slim chance could be water level switch most likely motor wire
Jul 21, 2008 | Kenmore 24032\24036 Top Load Washer
Getting error code#06 Lr Locked Rotor
I too had the Lr problem on my Maytag MAH5500B. We had it fixed once when it was still under warranty but when it appeared again this summer, I was told that it would cost at least $500 to repair -- in other words, get a new one.
With nothing to lose, I simply unplugged the unit, opened the front and reset (as in pull out and re-insert) the jumpers to the control unit on the bottom right. It's been working fine since and I run it at least twice a week. I noticed that the Lr error would appear when I interrupt the wash cycle once it begins. When the error message appears, I simply unplug it, wait a few minutes and start it up again.
It is after all, a computer...and all computer could use a reset once in a while.
Feb 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
How can I fix my whirlpool thin twin washer?
It almost sounds like your motor is kicking out on overload. The fact that it starts agitating after the fill can rule out the pressure switch. You have installed a new timer so we should be able to rule that out. It's possible that your pump is binding, which is attached directly to your motor and causing it to overheat. To tell for sure you would have to check the motor to see if it's getting power when it cuts out. Check your terminal block where the power cord comes in to see if all connections are secure. Other possibilities could be the clutch and brake assy. With out being there too see the problem, this is where I would start.
Apr 27, 2006 | Whirlpool LTE5243D Top Load Stacked...
Amana NTW4651BQ NTW4651BQ 27" Top Load Washer with 3.6 cu. ft. Capacity 9 Wash Cycles Advanced Suspension System Automatic Temperature Control Cycle Status Bar and Rinse & Spin Cycle in White Logo
509 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
