Question about Panasonic Office Equipment & Supplies
I have a Panasonic PT-AE3000U projector. Replaced the lamp unit 11/14. The projector turns on,I can hear it. However it nothing else other than an awful burning smell
There is another odd issue and that is that I cannot get the lamp unit out. I have loosen all screws and it's like it's stuck and I can't seem to get 2/3 screws to come all the way out. I am so frustrated!
  • 3 Answers
SOURCE: Projector won't turn on after I replaced the lamp
re insert the lamp and check your connection. if that does not work then replace lamp or have lamp checked.
Posted on Jan 13, 2008
dhiman
  • 115 Answers
SOURCE: Panasonic PT-AX100
Hello
Check the process of Power supply and the outputs. powerup the projector the replace the faulty gear assy or repair the same.
viren
Rave Services India
Posted on Feb 07, 2008
  • 221 Answers
SOURCE: PT-L785U Projector
if the lamp warning light is flashing, this indicates a defective ballast (lamp power module). if the lamp warning light is lit steadily, then the lamp would be at fault.
Posted on Oct 31, 2008
SOURCE: Panasonic PT-AE900U Projector Lamp stops working (intermittent)
since it has worked 1200 hours or even more since u have been resetting the counter! just change the lamp, resetting the counter does not make the lamp work or not work , it is only a reminder for the user to change the bulb when it should be & that u have some balance hours left to procure a new lamp!
if the brightness is adequate, then it is a ballast problem & not lamp problem!
buy a new lamp as u will anyway need to , fit it & it may solve ur problems permanently!
Posted on Feb 08, 2009
SOURCE: Panasonic projector PT-L78 lamp reset
Press the MENU button. Use the < > arrows to get to the OPTION menu. Press the ENTER button. Select LAMP RUN TIME. Press and hold the ENTER button for about 3 seconds. The 'lamp time reset' will display. Press OK and press the ENTER button. This will reset the lamp hours as well as turn off the projector.
Posted on Feb 25, 2009
Panasonic pt- ae3000e HDMI Inputs won't work
interface of the inputs is defective
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip,color wheel, motherboard, powersupply ... with high quality and competitive price.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Feb 17, 2014 | Panasonic PT-AE3000U LCD Projector
Hi there, I'm having a strange problem that has really confused me and I'm sure it's something simple that's tripping me up but I can't figure this out. -Im not getting an image from any of my HDMI...
if you can select the hdmi inputs ok
and swap them around without a good result
if no image etc
you would expect there to be a default no signal message or error something on the viewing screen
if a total blank
could be possible the Projector unit has a internal board failure
Panasonic PT-AE3000U Operating Instructions Manual - ManualsLib
https://www.manualslib.com/manual/246284/Panasonic-Pt-Ae3000u.htm
Apr 01, 2017 | Panasonic PT-AE3000U LCD Projector
Panasonic 3000u projector overheating
it depends after how long the temperature indication comes
if it comes immediately as soon as the projector comes on[say in 1 min] then the ballast circuit has to be replaced.
if the temperature comes after say 5 mins , it could be that one of the exhaust fans is not moving freely and needs to be replaced!
Jan 13, 2013 | Panasonic PT-AE3000U LCD Projector
Projector turn off into two minutes and do not turn on
If the Panasonic Logo comes and then the projectors turns off, the main board of the projector requires replacement!
Dec 27, 2012 | Panasonic PT-AE3000U LCD Projector
When we turn on our PT-AE3000U it will power up until the blue screen with "PANASONIC" written across it appears and then it will just shut off. WHy is this?? We have changed to lamp in it...
if it abruptly turns off the thermal sensor could be worn out and triggering to shutdown, other than this it may be software related.
be sure that the projector is receiving a signal in the correct input form a DVD player or something to ensure that its not just on the standby screen.
Feb 10, 2011 | Panasonic PT-AE3000U LCD Projector
PT-AX100U-EC DLP Projector: I replaced the bulb on the Panasonic PT-F1000NT pr...
1.Press the MENU button to display the menu screen, and
then press the F or G button to select the OPTION menu.
2. Press the ENTER button, and then press the F or G button
to select LAMP RUNTIME.
3. Press and hold the ENTER button for approximately
3 seconds. The confirmation screen, “LAMP RUNTIME
RESET.
” is displayed and select OK.
4. Turn off the power.
�� This will reset the cumulative usage time for the lamp
unit to zero.
***Here you go and best of luck!***
May 07, 2010 | Panasonic PT-AX100U-EC DLP Projector
My panasonic projector pt-ae3000u is not seeing my ps3
Should work right away, are selecting the correct HDMI input? (1,2 or 3?)
Do you have a way of checking the cable?
Jan 13, 2010 | Panasonic PT-AE3000U LCD Projector
1. short lamp live 2. overheating
First, make sure you've cleaned any dust filters on the unit!! That in itself will usually stop overheating (think of someone closing off your nose and mouth) that's what happens when the dust filter gets clogged--the unit strangles for cool air and rapidly overheats--this not only shortens lamp life dramatically, but also shortens the life of ALL components in the unit, especially delicate LCD panels or the display chip in a DLP projector!
Sep 07, 2009 | Panasonic PT-AE3000U LCD Projector
64 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
