Question about Panasonic Office Equipment & Supplies
I have a Panasonic PT-AE3000U projector. Replaced the lamp unit 11/14. The projector turns on,I can hear it. However it nothing else other than an awful burning smell
There is another odd issue and that is that I cannot get the lamp unit out. I have loosen all screws and it's like it's stuck and I can't seem to get 2/3 screws to come all the way out. I am so frustrated!
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 729 Answers
It's stuck on the connector of the lamp
pull the housing ,pull the connector
I have a Panasonic PT-AE3000U projector.  Replaced - 25636225-mp1bdm1odek32ursngm0ykfo-1-0.jpg
Posted on Jul 22, 2015
Marrie
  • 563 Answers
SOURCE: Benq PB6200 projector lamp or other problem
Hi there
I replaced a Mainboard on a BenQ PB6210 just yesterday - had all the same symtoms.
No LED lights coming on but the rest of the buttons has light.
Tried every other component from the lamp to the colourwheel , but the Mainboard replacement fixed it in the end.
You'll be looking at about $95 for the part
Posted on Apr 10, 2008
SOURCE: Replace Panasonic PT-60DL54J Lamp (TY-LA2004)
This is a link to AVS for Panny PT-50LC (LCD) which I assume must be the same for the DLP.
With the TV powered off (make sure it's off for a few minutes before trying this, or you'll wait for the customary cooldown period before anything happens if you turn the set off and try this stuff immediately), press and hold both the "VOLUME Down" button on the TV itself and the TV/VIDEO key on the remote control simultaneously for about 7 seconds. The TV will be turned on and it will have a screen of status data atop an active TV channel. To get out of this mode TURN OFF your TV.
This initial "SERVICE MODE 1/3" screen shows -
LAMP OPERATION TIME
TOTAL :
CURRENT LAMP:
OSD DISPLAY :
LON COUNT :
Posted on May 12, 2008
00Steven
  • 6 Answers
SOURCE: set lamp timer
Jerico, If you will go on dlp lamps .com I believe they answer that question in their FAQ. You can also give them a call. Look on their site for number. All I know is that they make the whole process really easy.
Posted on Sep 27, 2008
quang123
  • 107 Answers
SOURCE: Lamp hour reset
I don't thing that because you were not reset the time lamp used now your LCD projector stop function
What was exact the unit did? no power at all or some LED light up or flashing. In any case to reset the lamp time use you must enter when unit is on
As you mentioned you did replaced the new lamp, You should check again if you reinstalled properly the lamp and lamp cover because under the lamp cover it had a safety switch if this SW not active then the unit will be in protection mode
I sugges you to remove again the lamp and reinsert properly and secure the lamp cover and try it again and if it still is not go then let me know what are the status of the 2 LED
Cheers
Posted on Jan 15, 2009
  • 56 Answers
SOURCE: Lamp Timer Reset procedure Panasonic Projector PT-L759E
Greetings!
It's been a while since I did one of these, but if I remember correctly:
- Turn on the set
- Push volume down on remote and at the same time....
- Push Split on the remote and hold both for 5 seconds
This should do it. The display should reset to "0".
Rob
Posted on Mar 09, 2009
Panasonic pt- ae3000e HDMI Inputs won't work
interface of the inputs is defective
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip,color wheel, motherboard, powersupply ... with high quality and competitive price.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Feb 17, 2014 | Panasonic PT-AE3000U LCD Projector
Hi there, I'm having a strange problem that has really confused me and I'm sure it's something simple that's tripping me up but I can't figure this out. -Im not getting an image from any of my HDMI...
if you can select the hdmi inputs ok
and swap them around without a good result
if no image etc
you would expect there to be a default no signal message or error something on the viewing screen
if a total blank
could be possible the Projector unit has a internal board failure
Panasonic PT-AE3000U Operating Instructions Manual - ManualsLib
https://www.manualslib.com/manual/246284/Panasonic-Pt-Ae3000u.htm
Apr 01, 2017 | Panasonic PT-AE3000U LCD Projector
Panasonic 3000u projector overheating
it depends after how long the temperature indication comes
if it comes immediately as soon as the projector comes on[say in 1 min] then the ballast circuit has to be replaced.
if the temperature comes after say 5 mins , it could be that one of the exhaust fans is not moving freely and needs to be replaced!
Jan 13, 2013 | Panasonic PT-AE3000U LCD Projector
Projector turn off into two minutes and do not turn on
If the Panasonic Logo comes and then the projectors turns off, the main board of the projector requires replacement!
Dec 27, 2012 | Panasonic PT-AE3000U LCD Projector
When we turn on our PT-AE3000U it will power up until the blue screen with "PANASONIC" written across it appears and then it will just shut off. WHy is this?? We have changed to lamp in it...
if it abruptly turns off the thermal sensor could be worn out and triggering to shutdown, other than this it may be software related.
be sure that the projector is receiving a signal in the correct input form a DVD player or something to ensure that its not just on the standby screen.
Feb 10, 2011 | Panasonic PT-AE3000U LCD Projector
PT-AX100U-EC DLP Projector: I replaced the bulb on the Panasonic PT-F1000NT pr...
1.Press the MENU button to display the menu screen, and
then press the F or G button to select the OPTION menu.
2. Press the ENTER button, and then press the F or G button
to select LAMP RUNTIME.
3. Press and hold the ENTER button for approximately
3 seconds. The confirmation screen, “LAMP RUNTIME
RESET.
” is displayed and select OK.
4. Turn off the power.
�� This will reset the cumulative usage time for the lamp
unit to zero.
***Here you go and best of luck!***
May 07, 2010 | Panasonic PT-AX100U-EC DLP Projector
My panasonic projector pt-ae3000u is not seeing my ps3
Should work right away, are selecting the correct HDMI input? (1,2 or 3?)
Do you have a way of checking the cable?
Jan 13, 2010 | Panasonic PT-AE3000U LCD Projector
1. short lamp live 2. overheating
First, make sure you've cleaned any dust filters on the unit!! That in itself will usually stop overheating (think of someone closing off your nose and mouth) that's what happens when the dust filter gets clogged--the unit strangles for cool air and rapidly overheats--this not only shortens lamp life dramatically, but also shortens the life of ALL components in the unit, especially delicate LCD panels or the display chip in a DLP projector!
Sep 07, 2009 | Panasonic PT-AE3000U LCD Projector
Panasonic PTAE 900U with new lamp and counter reset shut off
Reseat the lamp.  I had a similar problem.  Replaced the lamp and everything worked for about 3 hours.  Then, turned the projector off.  Next morning, when I turned it on, nothing.  Stanby/On light flashed green for a minute then the lamp light came on and the projector went into standby.
Jan 27, 2009 | Panasonic PT-AE900U Multimedia Projector
411 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
