Question about Panasonic DP-C213 Color Copier
My panasonic DP-C213 is laying down too much cyan. The prints are coming out with a cyan "haze" over everything.. any clue as to what to clean first?
  • 6 Answers
You can clean the drum glass first (rod should be attached inside the door for it). Small hole under the drum visible after taking the waste toner container out. Stick the rod with the spongy side of it in there and push it in - pull it out couple of times. ( :) )
Other than that I#d change the drum or dev...it depends on the type of the "haze".
Be sure you are using _original_ toner. If not, change developer _and_ toner to original - the copier might not able to calibrate by factory standards.
Posted on Apr 23, 2015
  • 224 Answers
SOURCE: I need an Instruction manual for Panasonic model DP-C213
the drum must not be touched when inserting into device, this releases a flag and the u29 code will still appear. try another drum where the "flag" at the rear is in it's correct position.
Posted on Mar 30, 2010
JackHeath
  • 1049 Answers
SOURCE: E02-02 - what does this error mean for a DP-C213?
E2-02 means there is an error with the lifting motor assembly for tray #2. You will not be able to use your tray #2 until it's fixed. You can check it, sometimes there's just paper clogged at the rear of the paper tray. Remove your 2nd tray to see if there is a paper clogged inside.
Otherwise the cover/case of the lifting motor is damaged and you will need a service technician to fix and replace it.
Posted on May 07, 2010
Testimonial: "Thank you. You'd think you'd be able to search for this answer on Panasonic's Industrial site, but I couldn't even find the model number let alone the error code. Thanks for your help. "
  • 21 Answers
SOURCE: My Panasonic dp c213 says
There are two Drums for this unit, one for black color ( DQ-UHN36K) and one for color (DQ-UHS30).
For step to step instruction to change the drum see this link...
ftp://ftp.panasonic.com/pub/Panasonic/business/office/op_manuals/op_man_printer_multi/OM_DP-C354Series_BasicOps.pdf
You will find instruction on page 80 and 81.
Posted on Feb 28, 2011
SOURCE: i need to istall my
You can get the postscript printer driver here, assuming your printer has the postscript option installed. Also other note is that this driver only supports up to the Leopard operating system (10.5). No drivers yet for Snow Leopard (10.6). The installer crashes when trying to install on 10.6
http://panasonic.net/pcc/support/mfp/dp-c354/ps/download.html#02-3
Posted on Mar 08, 2011
ercupa190
  • 12223 Answers
SOURCE: panasonic DP-C213 color copier key operator code
go to www.2manuals.com or www.copierrepair.com or www.eserviceinfo.com or www.retrevo.com or www.servicemanual.net
God bless you
Posted on May 10, 2012
My Panasonic dp c213 says I need to replace the drum unit. Are ther more than one and how do I replace it?
Feb 28, 2011 | Panasonic DP-C213 Color Copier
I need to istall my panasonic dp-c213 printer to my macbook...we dont have any software for this
Sep 07, 2010 | Panasonic DP-C213 Color Copier
May 07, 2010 | Panasonic DP-C213 Color Copier
Apr 25, 2009 | Panasonic DP-C213 Color Copier
DP-C213 Panasonic Copier
The DP-C213 is still a current model for Panasonic. Go to Panasonic's website and find a local dealer to help you. --
To clarify, what company did you purchase or lease the mfp from?
Feb 18, 2009 | Panasonic DP-C213 Color Copier
Stopping and clearing printing jobs
From the control panel, lower right corner, select "output queue", select "print" tab, select the job you wish to cancel, select OK.
Dec 17, 2008 | Panasonic DP-C213 Color Copier
Panasonic DP-C213 Color Copier Logo
60 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
