Question about Dryers
My dryer has power and is stuck on sensing. I have replaced the Thermal Fuse assembly (two parts) and still have the same issue. What else could be wrong with it?
  • Brian Binash
    Brian Binash Apr 09, 2015
    Thank you Steve. I will check and see. I may be to the point where I will need to hire a technician if this does not work.
  • 960 Answers
Without knowing what make / model, pretty hard to determine. Most sensor dryers have the sensor pickup on the inside of the door, or near where the air outlet is. The sensor may be dirty, damaged or broken. There may also be a problem with the electronic control board
Posted on Apr 09, 2015
AEQB6000ES2 dryer wont heat
There are 4 things that can cause this issue: 1. Thermal Fuse (Protects the dryer from overheating and fires) if this is blown, the drum will still turn but you will have no heat. {Cheapest Fix} 2. Heating Element Assembly {Third Cheapest} 3. High Limit Thermostat (if this is stuck OPEN, the dryer will not heat) {Second Cheapest but rare issue} 4. Main Control Board (Check all the other parts first as this is not cheap and there is no way to test it, if the other parts do not fix the issue, replace this. Not a common issue but can be a manufacturer defective item)
Feb 27, 2013 | Kitchen Appliances - Others
Dryer will not turn on after button is pushed.
HI, check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer or control board
Replace if defective (note: uncommon problem).
**The most common issue here will be a defective Thermal fuse
Jan 08, 2010 | Magic Chef CYE4000AWW Electric Dryer
Kenmore 97478100 dryer will not start (not a heating issue)
3. Thermal fuse
Oct 08, 2009 | Kenmore Dryers
Dryer doesn't start
3. Thermal fuse
Oct 04, 2009 | GE Dryers
Why is my gew9868kq0 not starting?
3. Thermal fuse
Sep 15, 2009 | Whirlpool GEW9868K Electric Dryer
Dryer will not start when button is pushed. Maytag model # DE 610
3. Thermal fuse
4. Timer
Aug 18, 2009 | Dryers
My dryer wont turn on at all, is there a internal fuse?
3. Thermal fuse
4. Timer
**(((The most common issue here will be a defective Thermal fuse)))
Jul 30, 2009 | Dryers
White knight 44aw not spinning and no heat
3. Thermal fuse
4. Timer
Jul 26, 2009 | Dryers
Our whirlpool 6th sense dryer model awz3413 will not turn on
3. Thermal fuse
4. Timer
Jul 21, 2009 | Whirlpool ET8CHEXSQ Dryer
Whirlpool electric dryer (Model # LER4634DQO). Dryer won't come on when we push the start button.
The dryer would not start with a broken door switch. Replace the door switch if found defective.
3. Thermal fuse
4. Timer
Jul 08, 2009 | Whirlpool Dryers
Dryers Logo
53 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
