Question about Emerson Microwave Ovens
The door no longer pops open when the latch button is pushed. How do I fix this?
The door no longer pops open when the latch button is pushed. So far it can be pulled open, IF you have a free hand to pull it open while pushing the button. And the problem is not absolutely consistent, but even when it does pop open pushing the button doesn't feel the same as it used to.
  • 973 Answers
One of the door latch arms or the latching mechanism inside the oven have broken. you may have to buy a complete door lock / latching assembly . Might not be worth it. Check with your nearest parts supplier.
Posted on Apr 09, 2015
Rival rgst902 microwave. Door won't open.
verify that door is perfectly aligned with frame edge , sometimes in busy kitchens the door gets bumped and it no longer aligns with frame , if one forces it shut the mild spring that pops it open cant overcome the friction of frame hitting and it wont open requiring one to "HELP" it to open while holding down open button , look at latch carefully when open to see if any parts look bent or "not quite right "
Sep 17, 2015 | Rival Microwave Ovens
NN-T994SFR. Inclosed light stays on and the indicator states the door is open.
It is micro switch when you close the door, the door latch push in a button on the micro switch take lid off open and close the door and see if you can spot a button not popping out properly or the latch not in line with the switch
Oct 04, 2013 | Panasonic NN-T994SF Microwave Oven
I have a Panasonic Model #NN-S255 microwave oven. The button you push to open the door does not open the door. It's like there is no resistance when you push the button therefore it does not push up...
Hello,To get the door open and salvage your dinner, take a long thin blade ( I used a frosting spreader) and insert from the bottom between the door and the oven frame on the side with the latches (usually next to the control panel). You may have to pry the bottom of the door open just a bit. The object is to push up the lower door latch (which is connected to the upper door latch) and manually open the door. You may have to try a few times but this worked perfectly for me and saved dinner. Obviously the door latch needs to be repaired but this solves the immediate problem of dinner being held hostage by a recalcitrant microwave.
wish you good luck,
take care.
Aug 02, 2011 | Panasonic NN-S255 Microwave Oven
Can not open the door in microwave the release button springs seem to not working can that be fixed. Have opened the release button but cannot see the problem
Do not pry the door open since there is an easier remedy which will lead you in the direction that you need to fix your problem. Take the cover off after you disconnect the power to it. Once you have taken the cover off (only a few screws) you will be able to see the two latches that hold the door closed and the link that opens both of them. You can just lift both latches at the same time and it will open. After you have done that take a good look and press in on the open door button and you will see where you have the problem of the door hanging. That button should push a linkage that pushes up on both latches at once to open the door. It is spring loaded so that it comes back down so that when you close the door it will hold the door close.You need to take the cover off the microwave so that you can pull both of the latches that hold the door closed up. When you push the button in it engages a linkage that pushes both taches up at the same time to open the door. It is springloaded and will come back down during normal operation to hold the door closed when you close it again. That area is where your problem is. By looking at what happens when you press the open door button you should be able to readily see where the problem lies in that linkage
Feb 12, 2011 | Sharp R-1610 Microwave Oven
Broken door opener button
sounds like the door latch hook is broken you will have to seek a repair man for this
Feb 12, 2010 | Whirlpool GT4185SK Microwave Oven
Sharp Microwave model R-1850A door won't open
buy a boddle of WD-40 and try spray some in the raded spots.Im not a big specialist in microwaves.hope it helps
May 10, 2009 | Sharp R-930AK Convection/Microwave Oven
Won't whut off when open door
The microwave running with the door open can be dangerous.
It's most likely the switch in the door stuck in the closed position. Or it has failed/broken in the closed position.
Sometimes the switch is just a button sticking out of the cabinet where the door pushes on it when closed -- sometimes the door latch pushes on a switch inside the latch receiver in the cabinet.
If cleaning around that switch doesn't solve the problem, you should take it to a repair shop.
Apr 28, 2009 | Microwave Ovens
I cannot open the door of my Panasonic NN-T543W microwave
Well do not pry the door open since there is an easier remedy which will lead you in the direction that you need to fix your problem. Take the cover off after you disconnect the power to it. Once you have taken the cover off (only a few screws) you will be able to see the two latches that hold the door closed and the link that opens both of them. You can just lift both latches at the same time and it will open. After you have done that take a good look and press in on the open door button and you will see where you have the problem of the door hanging. That button should push a linkage that pushes up on both latches at once to open the door. It is spring loaded so that it comes back down so that when you close the door it will hold the door closed. Anyway that is where your problem is. Let me know if you need more hlep.
Feb 09, 2009 | Panasonic NN-S251 Microwave Oven
Hi ,there are two posibility to repair . 1. by ordering parts to the web site of sharp .
2. You may check from shop same type of part bring sample or in the appliances center near you.
Jan 14, 2008 | Sharp R-1850A Convection/Microwave Oven
Microwave Ovens Logo
254 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
