Question about Sewing Machines
How do i disconect the drive to wind a bobbin
  • Sewing Machines Master
  • 634 Answers
To "disconnect" means the sewing needle and feed dog is not functional if I understand your issue.
1. Disconnect: On the hand wheel there is a small outside ring in the center. Loosen it by turning towards yourself.
2. Take the thread from the sewing spool to the front gadget (round tension) and run around it in a figure eight appearance and run it to the bobbin.
3. Place the thread to enter the bobbin in the center with part going upwards into one of the holes to temporarily hold the thread until the bobbin is revolving. The bobbin must be pushed to the right to get the bobbin revolving.
Posted on Apr 09, 2015
Bobbin winder is engaged and shows up on screen correctly, but sewing mode is still engaged and bobbin winding keeps stopping.
check the drive knob on the end of the machine
it should be loose when winding a bobbin
if it is tight or seized then that will drive the needle
Sep 20, 2015 | Janome Sewing Machines
I can't remember how to wind a new bobbin
there should be a spare thread holder on the machine and a bobbin mount near the drive wheel of the machine. The bobbin goes on the bobbin mount which is pushed onto the drive wheel in order that it is rotated. the thread should be wound onto the bobbin and the the motor should be actuated. This should wind the bobbin. This is usually done with the thread out of the needle.
May 25, 2015 | Sewing Machines
The machine will not turn the spindle to wind cotton onto the bobbin.
What model Bernina is it? Most operate on a simple system where a rubber wheel on the bobbin winder comes into contact with the handwheel (under the cover) ... the handwheel is disengaged so the needle has no drive.......
Apr 13, 2014 | Bernina Sewing Machines
Wind bobbin frister rossman 420
Hi - if I understand your questions you're trying to wind a bobbin on the top, and haven't got as far as sewing yet.
To do this you usually have to put the bobbin on the top spool for it, and move that into position so that it turns.
To disengage the needle so it doesn't go up and down whilst you wind the bobbin up, on most machines you have part of the main drive wheel (on the far right) which turns against the rest of it, disengaging the part of the drive which powers the needle going up and down.
Or at least that's how it works on most machines.
Jan 28, 2013 | Sewing Machines
My Model # 1120 Singer sewing machine needle will not go up and down when motor is pressed. The bobbin winder, however, spins.
It sounds like your machine is set to wind the bobbin right now, so the drive is disengaged. That would explain why the bobbin winder pin is the only part moving. Check your manual for how to reset the machine when you are finished winding the bobbin.
Most machines have a way to disengage the drive for the needle while filling the bobbin. Then once the bobbin is filled, you re-engage the drive. Some machines have a separate, smaller hand-wheel that turns and clicks into place. Some machines automatically reengage the drive once the bobbin pin snaps into place away from the drive belt.
I hope this helps!
Mar 29, 2011 | Singer 1120 Mechanical Sewing Machine
I just received my Juki 8700. I new to industrial machines. How do I wind the thread onto the bobbin?
There should be a bobbin winding device next too and slighlty behind the drive belt.
Should be like this bobbin winder.
Mar 11, 2011 | Juki DDL-8700
I just purchased a Tacsew T111-155 sewing machine with a bobbin rewinder. Since the bobbin rewinder runs off the drive belt, how do you rewind the bobbin without the needle moving? Is there a button or a...
Hi Diane...you can wind bobbins while you are sewing your product, or you can wind them seperately. To wind them seperately, pull out the bobbin case, lift the presser feet up and lock them in the up position, undo the threading beyond the tension assembly. The takeup will create a birdsnest if you don;t pull the thread from it. Wind your bobbins, the re-thread your machine, insert your bobbin case, drop the presser feet, pick up the bobbin thread and sew away. If you need any other input, call me at 888-283-9640.
Robert with National Sewing Supply
Jan 01, 2011 | Sewing Machines
Require rubbber wheel for perished bobbin winding
There are lots of different rubber bobbin winder rings (tires), bring the machine to a shop and they will give you the correct one for about 1 dollar.
Feb 11, 2010 | Sewing Machines
Singer 2517---loading bobbin?
Threading the bobbin - winding thread onto the bobbin.
Position the new empty bobbin onto the vertical bobbin rod next to the end wheel. Click the rod to the right to engage drive. Hold the outer end wheel with left hand, and rotate the inner wheel anticlockwise by about a 1/2 turn (it stops) this removes drive from the foot and needle mechanism.
(** See note below -)
From a spool of thread on the top, thread to a loop/post on the left on the top. Then back to the bobbin you want to wind. Thread through a hole from the inside-out. Hold the thread vertically above the bobbin while you depress the footswitch to start winding. Let go when it's turned a few times.
Move bobbin shaft left, and tighten end wheel after winding enough.
Fitting bobbin-
Move footplate towards you, insert bobbin in hole so that bobbin rotates anticlockwise when thread is pulled, then pull thread into the fine notch towards you. After this position thread away from you, and slide the footplate closed.
To start / load thread. Hold the end 3" of the thread through the needle behind the sewing foot. hand crank towards you to sew first stitch in air. This should retrieve the lower thread - which you can catch with a handy pair of scissors. Then pull both threads rearwards - ready to sew.
**Note -
If the threading spindle is on the top, push to the right to engage, On the earlier versions, you have to thread it through a wire hook, then down and around a plate with two slots near the bottom right, before winding around the bobbin which is held horizontally as a direct drive off the handwheel.
Hope this helps - If so rate as Fixya!
Otherwise we'll try again for you.
Thanks for using Fixya!
Jun 13, 2008 | Sewing Machines
Fitting bobbin-
Jun 11, 2008 | Singer 5050 Mechanical Sewing Machine
Sewing Machines Logo
37 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
